2021 Upgraded turbos
11-22-2021, 09:37 PM | #1 |
Rep 107
What is the most reliable/ Best company for upgraded twins today.
I decided to go with upgraded twins instead of ST.. Any information will be perfect thanks in advance |
11-22-2021, 11:13 PM | #2 |
Rep 3,219
11-23-2021, 02:09 PM | #3 | |
Rep 3,732
All of the other "china" turbos...DAW, Vargas, Frankenturbo, ebay, etc, etc....are partially or entirely machined, assembled, and balanced (not sure to what spec) overseas, and although some people have luck with them, most don't. RB, or Pure are the only options if you want reliable aftermarket turbos.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
11-23-2021, 07:05 PM | #4 |
Rep 88
Pure stage 2 hiflows or hydra 650/800's , would be my picks.
Although considered a smaller stage 2 when put up against the 'hyped' offerings from DAW / VTT , chinas and others , pure stage 2s consistently produce not only dyno numbers at 25psi but, also track times and terminal speeds to back them up. Mine have ran 10s @131mph 24psi. Currently do 28psi duties on E85 Just remember , these stage 2s can end a stock engines life , so not only do you need to lop off the torque in the tune but, also ensure all the supporting mods are there. Starting with tyres and drive train, fueling etc. |
11-24-2021, 06:07 AM | #6 | |
Rep 107
11-24-2021, 06:59 AM | #7 | |
Rep 3,732
If you want more power than that, you're going to have to step up to a PI setup....and then you can get well up into the mid/high 600hp range.
dyllan1213.00 |
11-26-2021, 08:01 PM | #8 | ||
Rep 6,968
Drives: 2007 Black/Black 335i e90
When you start to approach 575+ HP, the idea of upgraded coils, HPFP, LPFP stage 3, transmissions and the like get more and more real. RB 2's are rated at 475-525hp / $2099 RB 2+ are rated at 525-575hp / $2399 Are RB turbos under rated? Probably…. I'd choose between those two, if you are looking to maximize what you currently have without having to upgrade coils, HPFP's etc… https://www.rbturbo.com/products/335i |
dyllan1213.00 |
11-26-2021, 08:05 PM | #9 | |||
Rep 107
Now I honestly think it means "Left or right hand drive" But as I search, I seen some people say it's the difference in turbos |
11-26-2021, 11:55 PM | #10 |
Rep 884
I have the RB Game Finisher turbos with the standard flow 17T TD04. These turbos are awesome. I don't think the N54 needs larger than 17T turbos when sticking to twins.
2013 335is - sold
2011 335d |
11-27-2021, 02:56 AM | #11 | ||||
Rep 6,968
11-27-2021, 08:50 AM | #12 | |
Rep 3,732
Yes...they are underated. Rob told me that my RB TWO's should be making close to 575 on an E40 mix and 27psi boost. Of course the harder you push them, the less life you get out of them.....like anything else. On 93 at 25psi they should be right at 500hp. |
11-27-2021, 05:03 PM | #13 | |
Rep 97
how big of a difference is the throttle response/ lag on the GF 17t vs stock twins? these are looking to be my next mod. Last edited by alex35i; 11-27-2021 at 05:03 PM.. Reason: typo |
11-27-2021, 06:18 PM | #14 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
I'm still in between RB ones or oem billets
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
11-27-2021, 06:31 PM | #15 | ||
Rep 884
2013 335is - sold
2011 335d |
11-27-2021, 06:33 PM | #16 | |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Stay the hell away from VTT, Franken, DAW, etc. I base the on the horror stories that have accompanied these companies. VTT being the worst of the bunch. Better off burning you money. |
Luper5258.50 |
11-28-2021, 07:11 PM | #18 |
Rep 6,968
11-28-2021, 10:31 PM | #19 |
Rep 6,319
Oh wow 500 whp no ethanol? What other mods you have? That's my goal no ethanol.
11-29-2021, 06:59 AM | #20 |
Rep 3,732
Just the standard FBO bolt-on stuff, RB TWO's, and a good custom tune making 25psi.
11-29-2021, 09:42 AM | #21 | |
BimmerPost Supporting Vendor
24503
Rep 191,503
Get the most reliable turbo, push it over its recommended limit, and it'll fail. I recommend you first set your HP goals and then research which options within that range are the most highly rated.
11-29-2021, 10:55 AM | #22 |
Rep 79
I've purchased a set of (new) Pure St. 2 for my N54 335is, but the shop installing them now ran into an overboost issue. The factory wastegate adjustment is too tight and the whole shebang is overboosting like hell. I've read about the issue also in the 1-series forum.
Now the shop is going to pull the turbos out again (argh) Sounds familiar to anybody? |
