N54 Vanos issues...
12-03-2021, 06:24 AM | #1 |
Rep 15
N54 Vanos issues...
Hi, I'm chasing a Vanos issue in my newly purchased N54 335i (59 plate). The code I'm getting (2A98) relates to the intake side. So far I've changed oil, filter, oil filter cap with cage, vanos check valves, and finally vanos solenoids. I've also swapped camshaft sensors, but the code has always stayed on the intake side.
The car did have a new head gasket & timing chain kit fitted in April-21 (before I bought it), fitted by a BMW specialist. I noted when I took the valve cover off that the Vanos gears on the end of the camshafts are aftermarket. I've spoken to the garage who carried out all the work, they remembered the car and said yes, they used aftermarket Vanos gears as part of the timing kit, but they use these alot and have never had any issues or failures. The garage reckons that an oil passageway in the head might be clogged, and need blowing out. I believe the oil passageway for the Vanos feeds directly into the camshaft ledge, so I would need to remove the camshaft to access this? The 2A98 code came on suddenly, and appears immediately after turning the car on (or once the revs have settled to idle). The car drives fine (despite being in limp mode), and there's no weird noises, just a very rough idle. The sudden appearance makes me think it's not the camshaft bearing ledges, as this would have been a more gradual failure. The code reappears immediately after clearing, and doesn't disappear after the car heats up. Any thoughts on this? I'm thinking I've got no option now but to pull the camshaft out and take a look. Possibly just chuck an OEM Vanos gear in to make sure that's not the issue, but they are about £400 from BMW, so I don't want to replace unless they are actually the fault. |
12-06-2021, 08:43 PM | #3 |
Rep 517
Never heard of aftermarket cam gears…but this sounds like cam ledge issues, do some research and see if this sounds right. If you are an earlier build date it's very possible, had the problem myself on an 08.
12-07-2021, 12:04 PM | #4 | |
Rep 1,165
Drives: 09 E92 335i 6MT
OP I'm guessing they're Dorman?
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
12-09-2021, 10:41 AM | #5 | |
Rep 15
The car is an 09, but I'm based in the UK so I don't think we got any revised cam parts on the later model cars. I've ordered a timing kit, so I'm going to pull the camshaft out either way and inspect the ledges. I've ordered a used OEM vanos gear too, and will chuck that in for good measure while the cam is out. Cam ledge is the obvious issue, but it just doesn't make sense that it would be a sudden failure? |
12-09-2021, 10:42 AM | #6 | |
Rep 15
I'm based in the UK though, so probably not parts from ECS. I can't find any aftermarket Vanos units available through reputable websites in the UK, only via Autodoc which is imported from Germany. |
Dave92N54530.00 |
12-10-2021, 02:47 AM | #8 |
Rep 53
My money would be on ledges. Unfortunately they keep getting more expensive parts wise for some reason. Maybe they stopped making them?
2007 E90 335xi 6MT w/Sport pkg - Monaco Blue on Saddle Brown - Completely Stock (Changing Soon)
12-13-2021, 06:32 AM | #9 |
Rep 15
All sorted now: the timing had slipped...
I took the valve cover off on Saturday, lined the cams up and the locking tool fit nicely. Went to put the crank locking tool in, but it wouldn't go in. I took the cam locking tools off, and had to rotate the engine again until the crank pin finally went in. Went back to put the cam locking tool on, and both cams were out! Both still slightly pointed to the left... I assume the exhaust vanos has slightly more movement than the intake vanos, hence why I was only getting in an intake camshaft error. I've retimed it now and everything is running perfectly now. Obviously the big worry is why did it slip? I wasn't pushing it that hard when the error came up, it was the second day I'd owned the car and I was taking my Dad for a test drive, so a few full throttle applications, but nothing crazy? Car dyno'd at 350hp, so again nothing crazy there. It did have a timing kit fitted back in April this year, maybe it was just fitted incorrectly? I would have thought that the code would appeared much sooner though. If the timing has slipped, then it might be an issue with the crank bolt? |
12-13-2021, 01:15 PM | #10 |
Rep 1,165
Try to do some searching, I can't remember what I did to come across it but came across a thread almost exactly like this. Someone fitted new cam gears, rode fine for a bit and then bam timing was off just a tad.
12-13-2021, 01:29 PM | #11 |
Rep 15
Interesting - I hadn't thought that aftermarket cam gears could somehow relate to timing going out - I'll do a bit of googling to see if I can come up with anything. I've got a set of OEM vanos gears that I purchased second hand, but I reused the aftermarket ones as they appeared to be in very good condition when removing them. They are a fairly simple design to be honest, so I can't quite wrap my head around how I could lose timing due to the gears.
Dave92N54530.00 |
12-14-2021, 11:30 AM | #12 |
Rep 498
I mean the car just had the timing chain done could be installer error on something? I'd go over everything related to the timing system and double check torque ect
12-17-2021, 11:57 PM | #13 | |
Rep 53
As mentioned, it could just be that the timing was not set correctly when the service was performed, however if you have been using the vehicle regularly since, this would seem unlikely, as its been many months, for the issue to just now be ocurring.
12-19-2021, 05:02 PM | #15 |
Rep 1,165
Ouch. That's rough man. Sad to hear.
12-21-2021, 03:47 AM | #16 |
Rep 15
Thanks, I'm going to make the most of a bad situation by fitting new turbos and downpipes while the engine is out.
Reason for failure is a reused crank bolt - now I've taken it out it's clearly the original, and not a 6 month old part. Takes the p*ss a garage can charge £500 for a timing kit (just for the parts), and not replace a stretch bolt that is torqued 100NM + 360 degrees. |
Dave92N54530.00 |
