dme problem
12-03-2021, 09:35 AM | #1 |
Rep 11
dme problem
I just did my spark plugs, swapped coils, replaced my injectors with index 10s, did low pressure fuel pump too, just added my upgraded ETS intercooler and then went from mhd stage one to stage 1+ did a couple pulls felt good then I drove home on the freeway driving normal for about 5 mins then down shifted and gassed it a little then it just started driving rough badly and not accurating fast so I pulled over and stopped driving and then got these codes
30bb - injectors 4,5,6 or DME internal fault missfires cylinder 4,5,6 [IMG]undefined[/IMG] |
12-03-2021, 11:07 AM | #3 | ||
Rep 11
so this problem could only be injectors or bad mosfets right? so I don't have to worry about anything else |
12-03-2021, 11:12 AM | #4 | |
Rep 1,232
I had a similar issue to you under high boost, which turned out to be an issue with the teflon seal having failed and was losing compression thru the teflon seal. Also new injectors require coding to tell the engine computer what the values are for each of the injectors, did you enter the values into the DME? |
12-03-2021, 11:13 AM | #5 | |
Rep 2,020
The first logical step is generally to test the dme mosfets. If the mosfets show short then great, upgrade them. Another rare possibility is just the injectors. There could be cases (as indicated by bmw tsb) that a faulty injector(s) can cause 30bb. So there is a chance. So if one has the luxury of replacing bank 2 w known working injectors that could be done. in my experience it is mostly the dme if you get 30bb cant see in the shitty pic but is it I8Aos or Ijeos? So there...
335i e92 TPC 19Ts
Albertn550.00 |
12-03-2021, 12:55 PM | #6 | ||
Rep 11
12-03-2021, 02:19 PM | #7 | |
Rep 3,219
You could swap the injectors round from one bank to the other to see if the misfires follow, if it does than injectors at fault. At least you'd be able to rule them out this way |
Albertn550.00 |
