12-06-2021, 10:28 AM | #1 |
Rep 167
Drives: 2019 X3 M40i
Battery Problems
My 2019 X3 M40i battery is 38 months old. The other day I got a weird speedometer and tachometer offset where there were two side by side images that were blinking. After driving for 35 miles, I measured the battery voltage at 12.25 vdc, about 40% charged. I put a trickle charger on overnite and the voltage came up to 12.8 vdc. Display works OK now. About a week ago I got a message that indicated a drivetrain issue. That went away when I restarted the car. Took another 25 mile drive and the voltage was then at 12.5 vdc. Only 7000 miles on the clock. Anyone have any history on longevity of these agm batteries? My neighbor’s X5 battery died at 36 months, so I have a real concern. Low battery voltage on my other cars seems to cause odd gremlins to show up and then go away.
Last edited by Radar314; 12-06-2021 at 10:36 AM.. Reason: Forgot to explain a couple things |
12-06-2021, 11:54 AM | #2 |
Rep 15,858
Could be influenced by your driving profile. 7,000 miles... you are indicating little use. Energy management doesn't charge in a conventional way, requires more miles than we may first think, to keep up with energy demands, with little regular use.
As to how old before issues? How long is a piece of string? My AGM battery was was showing its age at 10-years old. |
12-06-2021, 12:31 PM | #3 | |
Rep 263
Drives: 2019 G01 & G05
Good luck!
'19 X3 xDrive 30i Dark Graphite Metallic/Cognac Dakota Leather (his)
'19 X5 xDrive 40i Phytonic Blue Metallic/Ivory White Vernasca Leather (hers) '19 Mini Cooper S Countryman All4 Melting Silver Metallic/Carbon Black (kids') Life is short, drive what you want. |
12-06-2021, 12:55 PM | #4 |
Rep 167
Several of my neighbors have bmw ,benz or trucks. All have been having battery issues starting shortly after covid. None of us do a daily commute, so we do not put on a lot of miles. Most trips are 5 miles out and 5 miles back. I do plan to discuss this with the SA before the four years are up.
12-06-2021, 01:11 PM | #5 |
Rep 318
battery is a wear and tear item, like brakes. Some last longer some not so much. Depends how you drive your car a lot too. Replace and move on with your life.
12-06-2021, 01:53 PM | #8 |
Rep 167
Does anyone know if it is OK to use a battery load tester at the under the hood battery jump location? Seems like if you can jump the car from there you should be able to load test from there also.
Seems like it is time to get another Ctek charger for the BMW. Always keep one connected to the C7. |
12-06-2021, 02:32 PM | #9 | |
Rep 318
12-06-2021, 02:51 PM | #10 |
Rep 1,417
Longevity.
For me current cars 4 and 5 yrs no issues. Use trickle charger as low mileage. BMW Canada covers new batteries for two years. So is the life say less than 3 years. SA said warranty will not cover low miles/km. |
12-06-2021, 06:41 PM | #11 |
Rep 1,560
Drives: 2022 X4M40i, retired ‘11 X3
My 2011 X3 battery lasted me 10 years. When I wasn’t driving the vehicle as much, I would throw it on a trickle charger because I would get the battery discharge warning and certain accessories would be turned off until it was fully charged. I’ll do the same with my new X4.
DD69461.50 |
12-08-2021, 09:26 PM | #12 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3561
Rep 4,246
Drivetrain malfunction needs to be diagnosed based on fault codes. |
12-08-2021, 09:27 PM | #13 | |
3561
Rep 4,246
12-12-2021, 03:43 PM | #14 |
Rep 167
Just bought a digital battery tester. (Foxwell BT-705) It seems to use conductance rather than resistance to measure the CCA state of the battery. A bit pricey compared to old type load testers and the manual indicates you can use remote posts since there is no big current draw as in the carbon pile load testers. I will post results after I do the test. Does anyone know if the OEM battery was rated at 900 CCA? The tester needs to know that parameter.
Seems like a nice tool since it also tests the entire charging system. Having 6 lead acid 12v batteries to maintain, hope it works out. Last edited by Radar314; 12-12-2021 at 03:48 PM.. Reason: Spelling |
