12-06-2021, 12:37 PM | #1 |
Rep 723
Drives: BMW M3 xDrive
Local Winter Wheel Seller
19x9.5 ET34, would this cause problems for jsut a winter setup? I don't honestly care about appearance, more function. I found a local seller selling some wheels with tires with those specs and 255/35/19 blizzak lm-32. Thoughts?
12-06-2021, 01:49 PM | #2 |
Rep 6,593
Do a test fit will end all FUD, is the bolt pattern and center bore correct for the G8x platform?
12-06-2021, 01:51 PM | #3 |
Rep 723
12-06-2021, 02:40 PM | #4 |
Rep 1,661
The additional 14mm offset reduces INNER clearance, which is easily rectified by 12mm or 15mm spacers. Assuming the center bore and bolt pattern match, you should be good to go (with spacers).
