12-12-2021, 09:50 PM | #1 |
Rep 64
Winter Tires For Stock 19"/20" 825M Wheels - 2022 M4 Comp xDrive
My 2022 M4 Competition xDrive came stock with the 19"/20" 825M wheels, as well as the 'Michelin Pilot Sport 4S' summer tires with the following dimensions:
Front: 19x9.5, 275/35 R19 Rear: 20x10.5, 285/30 R20 I do not want to change the wheels or rims, but I need to buy winter tires (or all-season tires). I have been doing research online and it looks like one of my only options for the 825M wheels is the 'Pirelli Winter Sottozero 3' tires. What is confusing me is that some of the people who have gotten these 'Pirelli Winter Sottozero 3' tires for these 825M wheels chose widths that are 10 millimeters less than the stock 'Michelin Pilot Sport 4S' summer tires. What is the benefit to getting a smaller width for the winter tires compared to the summer tires? Should I follow this guidance, or keep the winter tire dimensions the same as the summer tires? What about the aspect ratio? Last edited by StephenF92; 12-14-2021 at 09:12 PM.. |
12-13-2021, 11:44 AM | #2 |
Rep 1,360
If you're driving through a lot of packed snow on the ground, "thinner" tires help cut through the snow easier. Plus it's sometimes easier to find certain winter tires in certain sizes. If you're driving through mostly dry (but extremely cold) conditions, then the OEM sizes are fine IMO.
Where are you seeing the Pirelli's in stock? I don't see anything on TireRack. |
12-13-2021, 12:15 PM | #4 | |
Rep 453
These days, especially with huge brakes, you can't really do a small winter wheel anymore, so you're effectively limited to oem sizes (or very close to it...I don't consider the difference of 10mm of width to be anything really significant). On the G8x platform, many of us are running 275/35/19 snow tires on all 4 corners. The 10mm narrower width in back may make a small difference, but more importantly (to me) it allows them to be rotated (to try and get extra life out of the set). That also happens to be BMW's recommended winter set-up for tire sizing. Many of us are running them on 19x9.5 wheels all around too. From what I'm hearing for this winter, everything is pretty much sold out until next spring/summer in terms of true winter tires, so you may need to compromise. Personally, if I was sticking with the oem rear 20x10.5 wheels for winter, I'd probably just do an oem-width rear tire too. There are some write-ups on this forum (and links to professional write-ups) of how well some of the modern all season, hi performance tires can do in winter weather conditions. Even those all seasons should be MUCH better for winter than the stock summer tires, which will be unsafe and useless in cold, snow or ice (and will also damage themselves driving in those conditions, even if you're lucky enough to keep your car from getting damaged). |
6speedNJ58.50 |
12-13-2021, 01:04 PM | #5 | |
Rep 64
I do not want to buy new wheels. I simply want to buy the proper winter tires for my current wheels. thanks |
12-13-2021, 02:17 PM | #6 | |
Rep 1,360
If you're looking to just swap rubber and keep the OEM wheels, one option which I'm also looking it, is to run 275s in the rear vs 285. It will give it a bit of a stretch but it's such a minor difference that it shouldn't matter, either from a looks or functionality standpoint. Back on my F80 I ran 255s in the rear in the winter (stock wheel was 275) and it was fine. And looking at TireRack right now, one option which I've seen another user mention, is using Michelin Alpin PA5 at 275/35/19 in the front, and the Alpin PA4 at 275/30/20 in the rear. Unfortunately, Michelin does not make the PA5 in 20s, but this user claimed TireRack said it was ok to mix/match the PA4 and PA5. Not ideal, but these are unusual circumstances with all of the shortages. Might need to get creative.
2022 M3 Competition xDrive Portimao Blue
12-13-2021, 02:20 PM | #7 | |
Rep 453
Note, many (most?) true winter tires are directional these days, so in that case, you may not even be able to rotate side to side on the same axle. But at least being x-drive, the wear should hopefully be a bit more even front and rear. |
12-13-2021, 02:28 PM | #8 | |
Rep 453
12-13-2021, 08:22 PM | #9 | |
Rep 1,661
12-14-2021, 01:46 AM | #10 |
i can haz horsepowr ??
3851
Rep 1,938
There are two options left right now that'll fit your stock wheels:
Michelin Pilot Alpin PA4 265/35/19 and 275/30/20 Pirelli Sottozero 3 275/35/19 and 295/30/20 10mm won't mean much and your speedo will be slightly off because of the rolling diameter difference, as well as a few other possibilities, but at this point: these are it. The benefit to thinner tyres is cutting through the snow better, but again - you're going 10mm narrower/wider here because there are no other choices. You could do all seasons if your roads are decently plowed, but that's a gamble. I'm leaning towards PA4's myself as they served me quite well in the past. I'm getting my car towards the end of the snow season so I'm trying to wait and see if it's worth it now or waiting until this upcoming summer to get the ideal tyres/wheels. Ideal for me: set of 19's flow forged, with 275/35/19 square Michelin Alpin 5 or Nokian Hakkapeliita R3's.
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 |
OF Hero1133.00 |
12-14-2021, 11:56 AM | #11 |
///M-Thusiast
3677
Rep 952
Drives: '23 X5 M50i
There is another option: Hankook Winter i*cept evo3 W330
Just ordered a set in the OEM sizes 275/35/19 and 285/30/20
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
12-14-2021, 02:08 PM | #12 | |
Rep 1,360
I too will be likely taking delivery mid or late March, so I just need something passable for 4-6 weeks and then will worry about a legit winter setup for 2022. I thought about a set of good all-seasons and just avoid driving in the snow those last few weeks. Luckily most of our snow is done by the time I'll be taking delivery, so hopefully just cold dry days to deal with. |
12-14-2021, 02:40 PM | #13 | |
///M-Thusiast
3677
Rep 952
Drives: '23 X5 M50i
12-14-2021, 08:26 PM | #15 |
Rep 1,661
FWIW, the stance with matching 9.5 x 19" 825Ms on Michelin Pilot Alpin 5s. Rears have 12mm spacers to restore OEM outer clearance to fender. Come summer, 15mm spacers will go on the fronts and 12mm spacers will stay on (with the 10.5 x 20" rims).
OF Hero1133.00 BMWRacer5232520.50 |
12-14-2021, 08:47 PM | #16 |
Rep 16
I wanted to stay with stock sizes, also. I was able to get the Pilot Alpin 5 for the fronts and PA4 for the rear. Tire Rack and Michelin claimed it's ok to mismatch. I ordered them the beginning of November and got them mounted on a spare set of 826 wheels last week. Car will arrive to the dealer later this, so I'm ready. That's assuming winter weather ever hits the Kansas City area. It's been very mild this year, so far.
12-14-2021, 09:17 PM | #17 | |
Rep 1,360
I might go for that, but at this point I am actually hoping my car is delayed a little so that I can take delivery in April LOL.
AhsanU3850.50 |
12-14-2021, 09:37 PM | #18 | |
3851
Rep 1,938
I got stupidly lucky with an allocation that was set for week 47, then opted for an individual paint that should've set me back at least a month.. looks like it only set me back 3 weeks as the allocation got pushed to week 50. Now the car is complete, is out of the factory, and is on its way to the port to get to me.. I wasn't expecting a car until March/April but now a late January delivery is looking very possible, so I'm hunting for winter tyres Definitely first world problems and I am eternally grateful to be getting the car sooner, but I 100% wasn't planning on it and spent a vast sum of money on other car parts already, so I might be screwed.
Dakar Yellow G80 M3
OF Hero1133.00 |
12-14-2021, 09:41 PM | #19 | |
Rep 1,360
I'm debating between the smaller PA4s or just going with a "good" all-season for the last few weeks of winter and just avoiding the snow. The PA4s are probably a better bet as I can just remount next winter on a set of dedicated winter wheels.
