12-20-2021, 05:49 PM | #1 |
Rep 17
New custom staggered setup question
I have a 2020 X3 M40i. Getting rid of the 21's and ordered 20's
Fronts 245/45ZR20 Wheels 20X9 Offset 25mm Rears 275/40ZR20 Wheels 20X10.5 Offfset 40mm I used a calculator I found online. It onlt says the scrub radius will be 5 mm positive on the fronts and 3 mm positive on the rears. Everything else came up that it would work. I just wanted some thoughts on this scrub radius??? Thanks |
12-20-2021, 06:06 PM | #2 |
Rep 596
That's fine. Slightly positive promotes toe-in under load; you don't want toe-out (negative scrub radius) Dynamic toe should be about zero, which is just about perfect for the street.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
12-26-2021, 10:56 AM | #5 |
Rep 17
12-26-2021, 02:52 PM | #7 |
Rep 596
If you've never had the alignment checked, now would be a good time to do so. I've *NEVER* seen any of my 19 new BMW's come from the factory with the alignment in spec.
Ask for the "before and after" sheet showing all 4 wheels and thrust line. Dealership wont be cheap, but they generally do okay on alignment work and have the right equipment and specs. Really nice looking X3!
12-31-2021, 04:25 AM | #8 |
Rep 106
definitely have the alignment checked. I didn't on mine and wore out a set of front tires in less than 13k miles. The morons at the tire shop didn't pay any attention to the fact I had spacers on. They paid to replace the left side, which for some reason was much worse than the right. Went back to BMW and paid them for a proper alignment.
