Misfiring on cold starts with new index 12 injectors
12-22-2021, 02:56 PM | #1 |
Rep 1,794
I just replaced my injectors and my car is still misfiring on several cylinders during cold starts. Once the rpms settle down, the engine is nice and smooth. I tried resetting adaptations hoping that would resolve it, but the rough idle is still happening specifically during cold starts. Ignition coils and spark plugs were replaced ~100 miles before injectors were replaced. Any ideas?
12-22-2021, 03:01 PM | #2 | |
Rep 2,287
12-22-2021, 03:51 PM | #3 |
Rep 1,794
Yes, injectors were coded with protool. It does look like the last value for several of the injectors changed after coding, but apparently that's normal behavior.
12-22-2021, 05:37 PM | #4 |
Rep 9,209
Did you perform synchronization per cylinder? Reset Lamba too? This might not be an injector issue at all. Not sure why you replaced them.
12-22-2021, 06:43 PM | #5 | |
Rep 884
2013 335is - sold
2011 335d |
12-22-2021, 07:28 PM | #6 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Bosch plugs or gapped NGK's?
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
12-22-2021, 08:26 PM | #7 | |
Rep 1,794
12-22-2021, 08:42 PM | #9 |
Rep 4,203
How cold is the weather for you? Stock turbos? I'm gapped to .022 on stock turbos and cold start disabled, still have had a stumble last 2/4 cold starts from plugs. I am most likely switching to stock plugs for colder weather soon while still on stock turbos
12-22-2021, 10:02 PM | #10 | |
Rep 1,794
12-22-2021, 11:37 PM | #11 |
Rep 9,209
I don’t know if is part form protocol but after replacing many injectors have had issues when misfire continues at idle and high revs under boost unless the synchronization per cylinder is performed. I think it has to to do with long term trims. There is a good article, European I think, because is on n53. Try to find it. I do it in Inpa.
12-23-2021, 11:24 AM | #12 | |
Rep 884
2013 335is - sold
2011 335d |
12-23-2021, 06:38 PM | #13 |
Rep 9,209
12-23-2021, 07:17 PM | #14 |
Rep 1,200
Sounds to me like a small vacuum leak or even boost leak. When your car is in open loop on start up, the car is using DME values to target fuel trims until it goes into closed loop and uses the o2 values. If there is unmetered air getting in then it can cause this stumble.
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
12-24-2021, 02:49 AM | #15 | |
Rep 884
2013 335is - sold
2011 335d |
12-24-2021, 07:24 AM | #16 | ||
Rep 1,200
2009 BMW 335i 6MT
_N54299.50 |
12-24-2021, 10:49 AM | #17 |
Rep 884
Well hopefully the new one over the weekend resolves my cold start issue
2013 335is - sold
2011 335d |
12-26-2021, 06:37 PM | #19 |
Rep 884
I replaced my entire valve cover today with a new OEM. The car did not misfire on the first cold start so well find out tomorrow if its really fixed. Its actually driving a lot better now I'm pretty sure the internals were plugged or something was going on. The other thing I noticed was a small amount of smoke coming out the VTT oil filler breather cap I'm running with the engine hot even with it removed just wasn't sure if its condensation or if its normal to have a little bit of smoke coming out. Checking the VTT oil filter cap for the 2nd time, the smoke appears to have disappeared after doing another quick run and a couple of WOT pulls.
2013 335is - sold
2011 335d Last edited by _N54; 12-26-2021 at 08:27 PM.. |
Soden82483.00 |
01-02-2022, 03:05 AM | #20 |
solus operandi
Rep 37
This is interesting.. I have index 12s on my car that were swapped over from the previous motor. I was under the impression that they may be leaking and causing stumbles on cold start. Upon checking for codes on MHD today I was warmly greeted by a 2C9D code. I’m certain my primary o2 sensor is toast.
Going to replace that, change VC gasket, coils, and try the MHD cold start option mentioned here before buying new outrageously priced injectors. |
01-02-2022, 08:42 AM | #21 | |
Rep 3,732
The numbers on the injectors is what need to show on ProTool when you look at injector calibration numbers. If those numbers don't match what's printed on the injectors, something went wrong....code them in again. |
01-02-2022, 10:29 AM | #22 | ||
Rep 1,200
2009 BMW 335i 6MT
