12-23-2021, 05:12 PM | #1 |
Rep 6,593
Specs:
Motorsport Hardware 5-Lug (14 x 1.25 to 14 x 1.5 Thread Conversion) 78mm Black Bullet Nose Stud Kit (F / G Series BMW & A90 Supra) |
12-23-2021, 07:42 PM | #4 |
Rep 243
12-23-2021, 08:27 PM | #6 | |
Rep 17,393
If you're a wheel whore and like to change them up often or track, it comes in handy. |
forza19763399.00 |
12-23-2021, 09:01 PM | #7 | ||
Rep 243
https://motorsporthardware.com/produ...-14x125-14x15/ |
12-23-2021, 10:56 PM | #8 |
Rep 1,682
I use this pin instead to help take wheels on and off. It came handy when I was installing spacers. Just replace one of the bolts with the pin. Once wheel is mounted, replace the pin with the bolt.
BMWRacer5232520.50 Cas29312.50 |
12-24-2021, 12:19 AM | #9 |
Rep 42
That's a neat trick. Thanks for sharing. Do you have more info or a link please?
12-24-2021, 12:39 AM | #10 |
Rep 6,593
12-24-2021, 12:40 AM | #11 | ||
Rep 6,593
evoi191546.00 |
12-24-2021, 11:19 AM | #12 | |
Rep 1,682
https://www.amazon.com/dp/B07RP2V97S...P77VY8MN?psc=1 |
12-24-2021, 02:38 PM | #13 |
Rep 1,367
I found the pin things to be almost more difficult to install wheel, especially when being low to the ground like on jack stands. Would be beneficial if the car was up in the air for sure.
I'd love to convert to studs, but those nice titanium ones are like $500. The black zinc or oxide ones you have already look like they're rusting a big on the ends.
2021 ///M3
2019 X3 |
12-24-2021, 07:38 PM | #14 |
Rep 1,740
Those were my Motorsport Hardware nuts after less than a year of use on my M2C. Beware not to overtorque and rust. If I was buying again, I would go with some higher quality Titanium ones
12-24-2021, 07:42 PM | #15 | |
Rep 1,682
12-24-2021, 11:51 PM | #16 | |
Rep 1,367
As far needing em for spacers…that’s one of the big reasons I went with future classics. They include new hub bolts. So no worrying about the spacer falling off or alignment when taking wheel off. |
BMWRacer5232520.50 |
12-25-2021, 07:52 AM | #17 |
Rep 1,773
You don't need studs for spacers as long as you get longer lug bolts. But I do much prefer studs for quick and each wheel changes at the track. Plan to install a set in the spring. I was thinking of going with future classic as I have their spacers but these maybe another option. Thanks for the post!
forza19763399.00 |
12-25-2021, 10:49 AM | #18 | |
Rep 6,593
Good advise however |
12-25-2021, 02:03 PM | #20 |
Rep 1,740
