12-28-2021, 04:26 PM | #1 |
Rep 52
My BMW APP fuel percentage???
I picked up the G05 40i 3 weeks ago, The first-day low-fuel pump had an issue and was replaced by the dealer. Everything is fine so far, I filled the gas for the first time on this x5 and found out the app shows the remaining fuel is not 100%. Or even 99%? Now it's 96 or 95
1) Would replacing the low-fuel pump affect the accuracy of the tank level? 2) Or is it possible that the app itself is inaccurate? 3) BTW, the fuel cap on the G05 appears to be slightly movable (after turning the cap back to the car, I feel it's a little loose overall). Normal? Thanks (updates: I searched online and it seems like the "Filler Cap" is not fixed very very tightly but a little bit movable? Thanks. https://www.bmwpartsdeal.com/parts/b...117470341.html Last edited by neverstopfly; 12-28-2021 at 08:07 PM.. |
12-28-2021, 05:25 PM | #2 |
Rep 6,946
The auto shutoff sensor on some pumps is a bit sensitive, so it could be not quite full, or, the sensor may be miscalibrated. Hard to tell from here.
thereef5101169.00 |
12-28-2021, 05:33 PM | #3 |
Rep 52
12-29-2021, 12:40 PM | #4 |
Rep 1,780
I don't think i've ever had it shown as 100% and I always get a full tank at the gas station. it also never has shown the same range as I saw when the filled the tank at spartanburg
12-29-2021, 04:27 PM | #7 |
Rep 810
I get 99% or 100% after filling.
Don't stop pumping fuel after the 1st click, try filling to the 3rd or 4th click on the pump, the auto-stop can be over sensitive sometimes. |
12-29-2021, 05:31 PM | #9 |
Rep 1,780
I've been told this is not good, that it overfills the tank and then there's a overflow valve that lets the fuel out of the tank which wastes gas. I always was told to stop at the first click
12-29-2021, 08:48 PM | #10 | |
Rep 6,946
But, if you never get to 100%, the sensor may be miscalibrated. Range to empty is not a constant as discussed elsewhere...it varies based on how you've driven in the past 18-miles or so and can easily change, sometimes by large amounts. |
thereef5101169.00 |
12-29-2021, 09:13 PM | #11 | |
Rep 810
Its an 80-litre tank, so the difference between 95% and 100% is 4-litres, really not worth debating tbh. The other thing that can effect fill capacity is ground angle. I always try to pick the most level ground at the gas station, but sometimes you get areas that have slight inclines/gradients which I know can effect how much you can get into the tank too. Again we're talking a few litres, which again is the difference between 95-100%. |
thereef5101169.00 |
01-03-2022, 10:15 AM | #13 |
Rep 52
01-03-2022, 10:18 AM | #14 |
Rep 52
01-03-2022, 10:20 AM | #15 | |
Rep 52
Thank you! Good to know! |
