12-28-2021, 08:04 PM | #1 |
Rep 3
Should I charge my iX3 to 100% at home via the BMW wallbox(AC charging)
Just wondering if it is okay to charged to 100% at home using the AC wallbox. Understand that the recommendation for DC charging is to 80% as the remaining 20% will take a long time. However, there is no charging time issue at home and not sure if charging to 100% at home will cause any harm to the battery.
Appreciate advice! |
12-29-2021, 02:58 AM | #2 | |
Rep 852
Most of my journeys are fairly short, but charging to 100% means I only need to charge once a week. So I will continue charging to 100%. |
12-29-2021, 03:06 AM | #3 |
Rep 188
Agree with the above and to add, I would certainly charge to 100% if you are using the car regularly however if it’s going to sit unused up to a week and over then charge to 80%
12-29-2021, 05:28 PM | #5 |
Rep 67
There is no issue with charging to 100%, and if the software is the same as the i3 (no idea as BMW haven't said) your battery could benefit from leaving it plugged in at 100%...
The only thing that could be a problem is leaving it at 100% for a time without using it. |
12-29-2021, 07:12 PM | #6 |
Rep 3
Thanks all for the great advices. As in the current covid situation and I am working from home most of the time, maybe I will only do the 100% before weekend and leave the car at 80% for the rest of the week!
Happy new year to all! |
