12-29-2021, 08:18 AM | #1 |
Rep 96
Best tire option for x drive ? (22 m3)
Sorry in advance , but for some reason my search bar won't work on the app . It keeps giving me an Error . I know the factory tires are the Michelins , I was wondering what the most cost effective replacement tire would be after these wear out? Obviously i don't want to get something that comprises the drive of the car , but I won't ever see the track either . I know the tire life is shortened due to the staggered setup . What's a realistic expectation for tire life assuming I drive very conservatively ( most of the time )? I drive about 15k Miles a year so I'm already banking in about once per year . Anything more than that get a little upsetting at that point
12-29-2021, 12:23 PM | #2 |
Rep 14,135
Drives: G82 M4C X-Drive
Tire life is only slightly slightly shortened because you can't cross rotate, but you can still rotate on the same axle. MPS4S are a good tire so I would stick with those.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
