01-02-2022, 11:12 AM | #1 |
Rep 605
Are all wheel spacers created equal?
As the title states. What's the best brand in terms of quality? Does it matter?
I saw that the preferred setup on ind website is 12/15 but also spoke to an expert who said depending on the tire lottery 10/15 may be better. What do you have and post pics! Thanks in advance! |
01-02-2022, 11:56 AM | #2 |
Rep 1,773
I believe IND sells the Future Classic spacers. I have the FC 12mm all around right now with Michelins and no rubbing. I am not lowered yet. Will do that in the spring.
01-02-2022, 02:30 PM | #5 |
Rep 897
I have both BMS 10mm and MS (Macht Schnell) 10/12mm. They both seem well made although the MS 10mm are actually a tad more than that (or BMS are less). When set on a flat surface next to each other the MS 10s are fractionally taller.
Also, and not sure if it matters, the BMS are larger in diameter and cover more of the wheel hub than the MS. |
JDUNITNOW3579.00 |
01-03-2022, 09:47 AM | #6 |
BimmerPost Supporting Vendor
24350
Rep 191,156
There is no best, just get a proven brand. I recommend BMS, Future Classic
01-03-2022, 11:54 AM | #8 |
Rep 10,193
There are better, but most are 6061 aluminum which is enough but there are spacers that exceed that level of structure/strength.
The most important piece (once meeting and exceeding 6061)is proper fitment AND install. I have: H&R on my R8, C63s BS, M8, and M3 I can not use spacers on my Porsche.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
01-04-2022, 09:12 AM | #10 |
Rep 605
01-04-2022, 09:28 AM | #11 |
24350
Rep 191,156
I forgot H&R in my post, another proven brand
01-04-2022, 09:42 AM | #12 | |
Rep 1,683
01-04-2022, 12:36 PM | #13 | ||
Rep 605
01-04-2022, 12:42 PM | #14 |
8265
Rep 18,849
Exclusively Macht Schnell wheel spacers on all our install for the last 13 years.
01-05-2022, 09:41 AM | #15 |
Rep 1,700
I have Macht Schnell from EAS with one of the more extreme setups, 18F/15R on Pirellis. Be aware that there is some trimming required with the setup otherwise you get some very obnoxious rubbing noises. The tires rub on the plastic fins behind the radiators breaking off one side. That leads to the fins vibrating when the tire rubs, typically when backing out of parking spaces.
Below is a pic of the trimming on my car FF885D65-5F10-4D7A-92DA-20DC156169BE_1_105_c by Sales Punk, on Flickr 6E8E2A7F-F798-4242-B158-C0B16CAB34A4_1_105_c by Sales Punk, on Flickr And here is the stance with KW HAS Untitled by Sales Punk, on Flickr Last edited by Salespunk; 01-05-2022 at 09:58 AM.. |
tom @ eas8265.00 |
01-06-2022, 08:08 AM | #16 |
Rep 597
Running Future Classics (15f/12/r) on the G80 M3 with KW HAS on 20” wheels with the Pirellis and have some rubbing at the front left when reversing toward passenger side. Rear is fine. Car is set to one half turn short of lowest setting up front and one full turn short of highest setting at the near. I’ve read and am hopefully once I switch the Michelin tires it will resolve the rubbing up front.
01-07-2022, 11:30 AM | #17 |
Rep 75
I have seen a couple videos on youtube of guys running 12's in the front & 15's in the back...can anyone chime in here? Why does this seem to be such a rare set up? I understand its all preference but this seems to be very out of consensus.
01-07-2022, 08:51 PM | #18 |
Rep 605
Ind recommends this as most popular setup on their website
01-08-2022, 06:10 PM | #20 |
Rep 597
Likely because the front wheels are inset more into the fenders than the rears from the factory. Most people seem to prefer the setup reversed (15 front/12 rear, or some similar configuration) so the wider spacers are used up front to make all the wheels appear more flush with the fenders.
01-08-2022, 06:13 PM | #21 |
Rep 597
According to their thread they actually recommend the opposite (15mm front / 12mm rear).
https://g80.bimmerpost.com/forums/showthread.php?t=1808816 Last edited by spicoli024; 01-08-2022 at 06:26 PM.. |
01-08-2022, 06:25 PM | #22 |
Rep 605
