Silicon Inlets - 12 hour fitting needed?
01-11-2022, 08:32 AM | #1 |
Rep 75
I just received my Masata silicon inlets today and was looking for quotes to fit them - most of them quoted me in the 12 hour range.
Has anyone had experience fitting them and does it normally take that long? Just a bit shocked that it would take so long, but perhaps I am missing something. |
01-11-2022, 09:31 AM | #2 | |
Rep 3,732
Do you have stock turbos? If so....wait to do inlets until you upgrade the turbos, they are a waste of time with the stock ones.....and it will be much easier to get the inlets in if you are already working on replacing the turbos.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
01-11-2022, 12:39 PM | #3 |
Rep 120
It sounds like they are using all the lube they saved on you for the inlet
2011 335is 6spd - White with Black Base : 5in VRSF IC / BMS CP Raceport BOV / Arm DP / RB Inlets / JB4 w/ MHD BEF Race / Meth cm10 / Modified CDV / BMS DCI / Stage 2 LPFP / Spec 3+ Clutch / - RB 2+ Turbos SHE LIVES \ Ew @ Comic Sans
1992 NA6 Smurf miata - pretty much dead / parting out 2005 Ex 250 ninja |
01-11-2022, 12:42 PM | #4 |
Rep 3,732
HaHa!!!
01-11-2022, 02:22 PM | #5 |
Rep 940
no one will charge you 4hrs for the job, even if they can do it in 4. You are probably looking at an 8 hr bill.
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
01-11-2022, 10:02 PM | #7 |
Rep 884
Use some dish soap on the rear inlets and it'll slip right in. I've only experienced installing silicone relocated inlets twice and it wasn't so bad so I can't imagine oem location inlets being any more annoying, but I have been a Diesel Mechanic for over 10 years so my tool use experience is on a different level. If you take your time it's possible to get it done and it will be a fun cursing weekend job…. I even swapped out my twin turbos with the subframe in place.
2013 335is - sold
2011 335d |
01-12-2022, 09:50 AM | #8 | |
BimmerPost Supporting Vendor
24491
Rep 191,486
it takes 4 hours, but most mechanics charge around 8 hours for this job
01-12-2022, 08:40 PM | #9 | |
Rep 75
4 hours!! Feel like I am getting scammed think it's time for me to start haggling with them too Changing both together probably makes sense, might even save up a bit on fitting since they are in the same area I reckon. |
01-12-2022, 08:42 PM | #10 |
Rep 75
01-12-2022, 08:44 PM | #11 | |
Rep 75
01-12-2022, 09:14 PM | #12 |
Rep 3,732
Well the good thing about owning a 335i is that it forces you to learn how to work on cars....these things need constant maintenance and attention.
Jaronbwall284.50 |
01-13-2022, 07:47 AM | #13 | |
Rep 120
01-13-2022, 05:05 PM | #14 | ||
Rep 517
01-14-2022, 08:11 AM | #15 | |
Rep 304
Navykiller68.00 |
01-17-2022, 07:41 AM | #16 |
Rep 120
I had the same thoughts when I did the water pump and hoses on a jackstand. Then I put some on and went "OHHHHHHHHHHHHHHH THATS SO MUCH EASIER"
haaken675101.00 |
01-17-2022, 08:04 AM | #17 |
Rep 3,732
When I did mine I tied a heavy piece of electrical wire around the end of the rear inlet.......got under the car and just pulled it down behind the motor. Not super easy, but much easier than trying to push that inlet back down behind the block.
01-17-2022, 09:24 AM | #18 |
Rep 884
You can also remove the intake manifold and it will help with getting the rear inlet on. Takes only 15 minutes or so to remove the intake manifold.
2013 335is - sold
2011 335d |
01-17-2022, 09:31 AM | #19 |
Rep 216
Did mine last spring. I cussed and fussed, walked away from it, came back to it cussed and fussed some more. Lube is definitely your friend as well as YouTube videos showing you some of the simple tricks to make it easier. 12hrs by most shops will cost you $800, which is about the cost for a decent set of down pipes, front mount intercooler, charge pipe and blow off valve. Add another $400, get a fuel pump upgrade with an MHD stage 2 plus tune along with a cheap Walmart tablet for $39.99. You're all set !
01-17-2022, 12:22 PM | #20 | |
Rep 3,732
But I agree.....paying for inlets (including install) is a waste of money on stock turbos. Spend the money on some better mods.
01-17-2022, 04:27 PM | #21 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Has anyone even asked what stage OP is at? FBO already or still needing other mods?
I mean my dp's alone were more than $800 so I'd never say anyone has a blanket case. I spent the $300 for inlets on my stocks and did the install myself, at 110k miles they will only help them out to squeeze the life outta them (I'm not street racing here) and have no other power mods left to do either. Ya the install sucked but hey, that's what I do once every 6 months or so, I usually save a few mods and do them together, like vacuum lines and fluid changes along with. Not a waste of time or money for me.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete Last edited by BSM n54iS; 01-17-2022 at 04:35 PM.. |
01-17-2022, 07:16 PM | #22 | |
Rep 3,732
Jaronbwall284.50 |
