UpSolute Chip for E90 330i
05-02-2006, 11:58 AM | #1 |
Rep 242
Drives: E92 328, BS CB, CA, Nav, PDC
I just spoke to the Upsolute dealer in Miami and he said that the ECU chip for the 330i just became available and produces gains of around 15 horsepower. He said its $375, and would take 1-2 days as he needs the module. Does this sound like a good deal?
05-02-2006, 12:04 PM | #2 |
Rep 473
Do a search for "upsolute" and you'll find this thread http://www.e90post.com/forums/showthread.php?t=7120
It's 10 pages long and the conclusion is, that chip hasn't been proven to give any gains. So unless they can produce a dyno showing 15 hp gain, I'd stay away. |
05-02-2006, 12:11 PM | #4 |
Rep 2,232
Drives: 2016 M3
here we go again
2016 M3
2016 Audi Q5 3.0T |
05-02-2006, 12:20 PM | #5 | |
Rep 10,411
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
05-02-2006, 12:37 PM | #6 | |
Rep 349
05-02-2006, 01:25 PM | #7 | |
Rep 158
Any chip that is going to be worthwhile will come from Turner Motorsport and if they do release one at all it is at least a year away based off the time it took to release software for the E46 engines. |
05-02-2006, 02:01 PM | #9 |
Rep 349
[QUOTE=325Driver]You are talking forced induction vs. naturally aspirated. Two TOTALLY different realms in the world of engine tuning.QUOTE]
You're correct- thanks for the correction.. |
05-23-2006, 08:21 PM | #11 |
Rep 463
Are there any major risks associated with chipping the car? I'm thinking of chipping it and then running a dyno for all of you to see whether it really does increase HP or not.
06-04-2006, 06:32 PM | #14 | |
Rep 1,516
Well, the right way would be to run a stock basline dyno first. Install the chip. Return to the same exact dyno machine, see if any gains or losses were had. If you did this, you'd definitely be doing the E90 community a great service. If you had gains, I'd definitely be buying one the next day. |
06-04-2006, 07:34 PM | #15 |
Rep 2,366
Drives: 1 M Coupe
anything revo i would do right away. my friend has a a4 2.0T and he revod it and wow that thing is seriously a bullet. gained of 50+ hp
06-04-2006, 07:52 PM | #16 | |
Not Stock
160
Rep 2,774
Also the 330i has the same motor as the 325i. It's going to be much harder for companies to squeeze HP out of the 330i motor as it is already tuned from BMW, 15hp is harder to get out of the 330i then the 325i. |
06-04-2006, 08:32 PM | #17 |
Rep 840
I ran REVO in my R32 and it was pretty crazy definitely have to worry about running good fuel because it becomes very sensitive to octane and you get nice ping.
But in a nutshell, chipping a NA they remove the speed limiter and bump up the timing (dont know how they'll do that with valvetronic though as it's supposed to be optimized for that anyway) |
06-05-2006, 04:36 PM | #18 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
yip, I htink the 325i would probably fare better than the 330i
06-05-2006, 04:37 PM | #19 | |
148
Rep 10,455
like others have pointed out, not fair to compare a TURBO to a naturally aspirated engine
