01-15-2022, 11:51 AM | #1 |
Rep 22
M3/M4 xdrive problem after lowering
Hi has anyone had any check control issues with messages appearing occasionally on the drive screen such as an issue with the 4wd system after lowering? Only ever came on today and was only lowered last night. Does anyone have any ideas what it could be without taking it to bmw
01-15-2022, 12:17 PM | #2 |
Rep 10,192
None here after 4 months plus of lowering; what exactly are the messages?
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
01-15-2022, 03:45 PM | #4 |
Rep 22
Tried putting it on the computer to see if there was any stored codes etc as it's not happened again since, no codes and not done it again. Not had the alignment done as of yet could this or the spacers be causing it as if it was a sensor it would have stayed on and came on every time surely?
01-15-2022, 04:09 PM | #7 |
Rep 1,084
This may have occurred if the ignition was on for any reason when they disconnected the sensors during installation so it threw the code. Should not come back if all the old codes are cleared. Can have a similar scenario when installing a JB4 for example. Different codes of course.
01-15-2022, 05:20 PM | #9 | |
Rep 22
01-15-2022, 05:22 PM | #10 |
Rep 22
01-15-2022, 06:19 PM | #11 |
Rep 1,084
I would put 100 miles on and let them settle. That's what I did. You won't get much deleterious wear. These are not stanced Hondas.
10-24-2022, 01:58 PM | #12 |
Rep 92
Just had this happen to me today while driving on the OEM wheels and pirellis in the rain. The steering got stiffer too. But restarted and the error went away. Did you ever have it pop up again or figure out what the cause was?
10-24-2022, 04:25 PM | #13 |
Rep 78
10-25-2022, 12:14 AM | #14 | |
Rep 92
10-30-2022, 01:03 PM | #15 |
Rep 413
Drives: BMW F30 335i xdrive
Hey,
In the past I had "same issue" on mu 335i xdrive msport lowered on Dinan springs. But I have never assumed its related to the fact of the car being lowered. In my case it was temp sensor on the ventilator and drive malfunction is more of the preventive in same cases notification , or final results of the problem vs root cause. You need to read all the codes and not rely only what the computer is leaving you with. BTW: when I did restart the car, codes were going away but where coming back after few weeks. Then it was a days and then it stopped going away. In my case power was cut down also and max rpms like 3000 if i remember right. Im not the expert, sharing my experience and I do always read all codes. Dealer may be able read codes for free if you know them well. Good luck guys! |
