01-17-2022, 10:49 AM | #1 |
Rep 1,682
Uneven Ride Height
I was planning on installing my MSS kit on my G80 and took measurements before the drop and noticed a difference of 3/16" between the driver side and passenger side for both front and rear. Driver side is higher.
I figured after installing the springs it may even out, granted they are still settling since it's a new install. After driving about 50 miles the difference is still 3/16". Is this unevenness normal, and should I adjust either side to match one another? Is the passenger side heavier on our cars? |
01-17-2022, 12:28 PM | #3 |
Rep 167
I was watching a video from whatsyourforte. He was lowering his g80 and took measurements and talks about this. Definitely worth the watch. Hope that helps
01-17-2022, 01:00 PM | #4 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Could be urban legend but read once a long time ago its intended to roughly compensate for driver weight.
Have no idea if its true or not.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
01-17-2022, 01:51 PM | #5 |
Rep 830
This may well be…there are tolerances on all the body parts, so it may be that the car height is even, but when measuring u notice a difference…u often notice that even more when corner balancing a car…
But what is interesting here that it's the same front and back…so could well be to compensate the driver weight |
01-17-2022, 01:52 PM | #6 | ||
Rep 1,682
I will go take a look at his video. Thanks! |
01-17-2022, 02:27 PM | #7 |
Rep 2,138
I did the measurement on my G82 before the MSS install.
I was surprised to find out that the height was exactly the same on driver's side vs. the passenger's side. Measured from bottom of the wheels to fender: Front: 25-3/16" Rear: 25-3/4" |
01-17-2022, 02:55 PM | #8 |
Rep 14,131
Drives: G82 M4C X-Drive
This could very well be compensating for driver weight, however I didn't know they did this out of the factory.
When corner balancing my car, I often sit in the driver's seat while they do it. While height does play a role in balancing the car, it's more of a product of weight over each wheel that determines how the weight is distributed and the suspension setting for each corner.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
