bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      01-20-2022, 02:07 PM   #1
Ruebarb
Ruebarb's Avatar
380
Drives: BMW G42 M240i
Bimmercode
I asked about the G42 M240I support.
Whenever my build comes in, I'll update this thread on what works.
I plan on using this adapter, https://www.kiesmotorsports.com/prod...39538241929301
Hi,
you may be able to connect to the car using the G20 selection and some of the options may be available, but it is not officially supported yet.
Kind regards / Schöne Grüße
Stephan Gauch
SG Software GmbH & Co. KG
Linsenäcker 18/1, 72379 Hechingen
Amtsgericht Stuttgart HRA 735678, Sitz: Hechingen
Persönlich haftende Gesellschafterin: SG Software Verwaltungs-GmbH
Amtsgericht Stuttgart HRB 769559, Sitz: Hechingen
Geschäftsführer: Stephan Gauch
DaveDee532.00
      01-20-2022, 02:33 PM   #2
Hpirx
Drives: 2022 M240 xDrive, BGM
Thanks! Have this available from my F22. Worked very well. I was wondering about using it for the G42 as well. When mine arrives (hopefully next week). I will check it out
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also"
Ruebarb380.00
      01-20-2022, 10:28 PM   #3
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
For what it’s worth
I recently bought the modBMW adaptor and it works flawlessly, not only that it has an ethernet port just in case you want to use a hardwire connection.
I had a couple of tech questions and he answered in minutes despite the conflicting time zones
When someone offers great service they are worth a mention
Svetlin Chokov
Programa LTD.
26A Vasil Aprilov blvd.
4000 Plovdiv, Bulgaria
phone: +359899871828
support@modbmw.com
modBMW.com
      01-21-2022, 07:49 AM   #4
Vudumonkey25
Vudumonkey25's Avatar
Drives: BMW M240i x Mercedes CLS550
I'm curious what options will be available. Something I will probably grab in the future.
      01-21-2022, 09:17 PM   #5
DaveDee
DaveDee's Avatar
532
Having used this app for about a year on a daily driver it’s a must have
For G42 (according to Bimmercode) before they update the app the following functions are available if the control module is fitted.
https://bimmercode.app/cars/g20/
Convenience things like stop start memory (if you have auto stop start in the USA) removal of the navigation nag screen and ability to start in sport individual (or anything else) are alone worth the cost of the app.
      01-22-2022, 07:53 AM   #6
Good 4 2 reasons
Good 4 2 reasons's Avatar
472
Drives: '22 G42 m240ix, '18 X5 35d
Which OBD module do you use? Looks like the "built for bimmercode" one is out of stock everywhere.
-Nicholas
2022 BMW m240i x-drive
2018 BMW X5 35d x-drive
2015 VW Golf 1.8t 5-speed (sold)
2004 Chevy Cavalier (hopefully crushed by now)
      01-22-2022, 01:49 PM   #7
DaveDee
DaveDee's Avatar
532
I have both the modBMW wireless and the OBDLINK® CX ("built for bimmercode") The modBMW wireless (and ethernet) adaptor is much better and much faster but they are compatible with the F G and i series BMW only where the OBDLINK® CX can be used with virtually everything, the OBDLINK® CX is bluetooth and is really slow, the modBMW is as fast as a straight ethernet connection.
I prefer to use an iPad as there is no carplay conflict as the ipad does not have the embedded carplay app.
To use wireless its best to use flight mode to avoid conflicts
I mentioned the suppler above for the modBMW adaptor, just above as he has awesome service and is quite a lot less expensive than others who all supply the similar adaptor with their own firmware and branding
      01-22-2022, 06:25 PM   #8
Good 4 2 reasons
472
I mentioned the suppler above for the modBMW adaptor, just above as he has awesome service and is quite a lot less expensive than others who all supply the same generic adaptor
Thanks for that. I ordered the modBMW one. Accounting for conversion from Euros to USD, it's only $75 delivered on DHL. Appreciate the advice!
-Nicholas
      01-24-2022, 12:52 PM   #9
G42Bama
G42Bama's Avatar
Drives: G42
So I used the Kies wireless adapter and was able to use both BimmerCode and BimmerLink. When signing into BimmerCode I chose the 3 Series instead of the 2. And to my surprise it worked. Just to test it out I coded the Bowers Wilks option on the audio. Then I went into BimmerLink and it worked as well. The exhaust Flap is worth the money alone. I will say doing all that made me quite anxious since none specifically state it's for our cars. But so far… no harm, no foul.
Ruebarb380.00
      01-24-2022, 01:33 PM   #10
Ruebarb
Ruebarb's Avatar
380
Thanks for being a 1st . So you chose the G20 option for the 3 series? I don't see the exhaust as an option, https://bimmercode.app/cars/g20/
G42Bama402.50
      01-24-2022, 01:46 PM   #11
G42Bama
G42Bama's Avatar
Drives: G42
Yes I did. And I didn't use BimmerCode for the Exhaust. I used BimmerLink
Ruebarb380.00
      01-24-2022, 02:28 PM   #12
SupraCooper
SupraCooper's Avatar
Drives: 94 6spd turbo Supra
This is awesome! Had a feeling some g20 would work. Can you code ambient lighting?
      01-24-2022, 03:05 PM   #13
G42Bama
G42Bama's Avatar
Drives: G42
It was an option. But it's my first experience with BimmerCode. And I was having some slight connection issues (after following the manual). When I get off work I'm going to try and spend a little more time with it.
      01-27-2022, 01:38 PM   #14
Good 4 2 reasons
472
By some modern shipping miracle, DHL dropped off my modBMW obd2 scanner last night. Considering the scanner was picked up in Sofia, Bulgaria Monday afternoon its incredible it made it here in 2 days, for roughly $25 for shipping.
I used bimmercode and already coded the default driving mode to sport individual, which I figure takes care of start stop plus driving mode all in one configuration change.
I am tempted to try out some of the coding options for instrument cluster displays. IIRC from reading some g20 forums, they were not able to do much with the ambient lighting settings. I know some 5 series that were successful, but sadly these cars have as few "chips" as possible in the new era.
-Nicholas
      01-27-2022, 03:57 PM   #15
tubingchamp
tubingchamp's Avatar
103
Drives: 2023 G87 M2
Does bimmercode have any effect on warranty?
      01-27-2022, 04:19 PM   #16
DaveDee
DaveDee's Avatar
532
Not sure of US consumer law but you are not changing any OE equipment and not modifying any hardware, you are simply choosing one of the options provided by BMW so I don’t see how it could void warranty. Afterall access is via an unrestricted OBD2 port
      01-27-2022, 04:49 PM   #17
jpcoop
Drives: 2022 M240i xDrive
US law generally prohibits them from denying you warranty coverage unless a modification is directly related to the problem, e.g. they can't refuse to repair your radio because you put new wheels on the car. But if you were to tune your engine and it blows up, that's on you. Of course, just because the law says something doesn't guarantee you won't have to fight with the dealer.
That being said, I've made coding changes on my last two BMWs and they never once even mentioned it. The problem you're most likely to encounter is: you take it in, they have to update the software to fix your problem, and they wipe your changes out in the process. So you have to code it again when you get home.
      01-27-2022, 06:20 PM   #18
randomusername
Drives: 2022 BMW m240i (in production)
Do you have to keep the OBD plugged in for the coding to “stick”? Or do you just need to have plugged in to change settings then you can remove?
      01-27-2022, 06:35 PM   #19
Hpirx
Coding "sticks" even after you remove the device.
      02-24-2022, 08:19 AM   #20
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
Was able to code a few things myself with Toyota Supra and 2 series options with no problem. I will try the G20 today to at least start in Sport or above mode than Comfort.
      03-02-2022, 09:58 PM   #21
xcelir8bmw
xcelir8bmw's Avatar
I can't figure a way to turn off auto start stop and comfort mode any ideas?
      03-02-2022, 11:05 PM   #22
240idax
in bimmercode use 3 series -> Auto Start Stop function
and Driving Mode
(https://bimmercode.app/cars/g20/)
g87
