01-25-2022, 04:34 PM | #1 |
BimmerPost Supporting Vendor
9599
Rep 10,891
IND | 3D Design G8X M3 / M4 Carbon Front Lip Install Guide
Tools Required: For Bumper Removal:
For Lip Install:
STEP 1: Remove front bumper: Remove push-pins securing front weather stripping panel and remove. Loosen front section of front fender liners by removing 10mm bolts; unfasten corners of bumper from fenders by removing x2 8mm screws. Remove T25 screws,10mm bolts, and push pins securing bumper cover and remove from car. Be sure to detach any electrical connectors housed inside bumper cover prior to removal. STEP 2: Begin by loosening the support panels on each side of the inner bumper cover; remove x2 8mm bolts on back of panel and unclip the 4 outer tabs. STEP 3: Detach corner splitters from bumper cover by removing 8mm screw and detaching 3 tabs. STEP 4: Transfer plastic speed nuts from factory corner splitters to 3D Design front lip. STEP 5: Apply ~15" of supplied adhesive tape to the center portion of the 3D Design front lip and create pull tabs at each end. STEP 6: Fit 3D Design Lip to bumper cover by pressing in 3 tabs on each end and fasten 8mm screws; be sure that adhesive tape pull tabs are accessible beneath front grille. STEP 7: Re-attach 4 tabs on inner support panels and re-secure 2x 8mm screws STEP 8: Pull off adhesive tape backing and press lip firmly to bumper. STEP 9: Locate 4x small holes on underside of lip and carefully use 5/32" bit to drill holes into bottom of bumper cover. STEP 10: The new holes should be just large enough to screw in included phillips-head screws. After placing screws, use 7mm open-end wrench to secure included nuts to screws. STEP 11: The 3D Design Lip is now secured to bumper cover, complete install by re-attaching bumper cover to car. Installation is reverse of removal.
FISH225413.50 Laguna01///M31400.50 chicagofan0019270.50 DMD471.50 GDBimmer44.50 playswcars3675.50 Saywhat4118475.50 |
01-25-2022, 06:52 PM | #3 |
Rep 2,030
Drives: G80 M3 Competition
Easily the best lip available.
IND-Distribution9599.00 |
01-25-2022, 08:21 PM | #4 |
i can haz horsepowr ??
3851
Rep 1,938
If I didn't love how aggressive the Vorsteiner lip matched the Vorsteiner front grille, I'd have happily purchased the 3d design lip.
Agreed with above - it's a perfect blend of RSC and M Performance, so if you're struggling to choose between those two - get the 3d design!
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 |
01-25-2022, 11:42 PM | #6 | |
Rep 911
Drives: 2022 G80 Comp x-drive
Maybe there will be a “replica” version that is inexpensive enough to paint? Based on the MPerf replicas they should be somewhere under half the original price, problem is, this is an expensive splitter to start! Haha
2022 G80 comp X-drive:San Marino Blue/ Silverstone, 826 bicolor, cf roof; exec pkg; shadow lasers; carbon pack; MSS HAS; spacers (15/12); Burger intakes; Unit17 front lip/CS Style spoiler; TLG flappies; full xpel ppf + 15% tint; AWE switchpath exhaust w/mid-pipes; csl strut brace; Eventuri cf engine cover
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335 |
G8ighty246.50 |
01-26-2022, 04:52 AM | #8 |
Rep 2,538
I know that this is a stupid question but I’m pretty ignorant about these things. Can the lip handle this vehicles TopSpeed of 180mph+? I imagine it would be a violent experience if the thing ripped off at that speed.
01-26-2022, 06:19 AM | #9 |
Rep 585
It’s bolted onto the bumper so yes it should be fine. But is it really necessary to do something like that?
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
01-26-2022, 04:37 PM | #10 |
Rep 2,538
Good point. I guess it’s not necessary but I just think it would look cool. I’m doing the carbon fiber rockers on the side so I thought the front might look nice in carbon fiber also.
01-26-2022, 10:17 PM | #11 | |
Rep 911
It should be fine up to any reasonable speed you can actually achieve on a public road if installed correctly. No idea about track use, but as mentioned it is attached with adhesive and bolts that are through the bumper with a nut on the inside.
M_Adaptive1769.00 |
01-26-2022, 10:26 PM | #12 | |
Rep 585
IG: Adaptiive_M
01-27-2022, 03:36 AM | #13 | |
Rep 2,538
It’s only fair. Now let’s address my question please. Are you telling me the lip could handle 180 mph? That’s how fast the car can go. Actually it can go faster than that but it’s locked past 180 mph. Is the lip rated for that or not? |
01-27-2022, 07:57 AM | #14 |
24362
Rep 191,163
Looks great!
02-07-2022, 07:43 AM | #15 |
///M-Thusiast
3676
Rep 952
Drives: '23 X5 M50i
I wish that lip was legal in Europe, sigh...
Current: 2023 G05 X5 M50i xDrive
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i |
02-07-2022, 07:53 AM | #16 |
Rep 2,538
02-07-2022, 08:20 AM | #17 | |
///M-Thusiast
3676
Rep 952
Drives: '23 X5 M50i
If I put that lip on my G80 and drive around, it's impound city for me.
Soon: 2024 G87 M2 Past: G80 M3x, G80 M3, G05 X5, F82 M4, F87 M2C, F20 M140i Last edited by playswcars; 02-07-2022 at 08:20 AM.. Reason: typo |
02-07-2022, 08:33 AM | #18 |
Rep 2,538
02-07-2022, 08:54 AM | #19 | |
///M-Thusiast
3676
Rep 952
Drives: '23 X5 M50i
It can be made legal, that however means crashing several lips in front impact testing, material testing, and pedestrian crash testing. Given the somewhat small market, that makes no financial sense, as a 3D Design lip retails for like 2k$. I'm not sure I can comment on the "logic" of it all, as often times, there just is none. The above goes for any aftermarket addon part btw.
Patton2502939.50 |
02-07-2022, 09:14 AM | #20 | |
Rep 2,538
playswcars3675.50 |
