Oil cooler thermostat seal
01-29-2022, 03:28 PM | #1 |
Rep 1,165
Drives: 09 E92 335i 6MT
How often are you guys swapping this seal out?
I replaced mine about a year ago. A month later it was leaking, figured okay I fucked something up or bad seal, whatever. Now here I am again, and it's leaking. Both times I used the Elring brand seal (I have read about them not having nubs which help keep it seated but I know my last seal had them).
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
01-29-2022, 06:08 PM | #3 |
Rep 1,165
I'm aware, they're both good. I've dealt with those leaks before, they're both dry but i'll be doing them again with the larger gasket this weekend.
01-29-2022, 10:59 PM | #5 | |
Rep 1,165
They are not leaking. https://www.fcpeuro.com/products/bmw...ng-11428637820 This is leaking. It's seeping in the little crevice on the right side by the oil filter cap.
01-29-2022, 11:11 PM | #6 | |
Rep 384
01-29-2022, 11:14 PM | #7 | ||
Rep 1,165
01-30-2022, 02:05 PM | #9 |
Rep 1,165
I run the Molygen oil for purposes like this. It's definitely just seeping from the gasket. Just was wondering if anyone else seems to have this issue somewhat commonly.
01-31-2022, 03:02 PM | #11 | |
Rep 1,165
01-31-2022, 04:48 PM | #12 | |
Rep 6,317
Not sure if you checked that to. |
01-31-2022, 05:04 PM | #13 | ||
Rep 1,165
02-05-2022, 12:56 PM | #14 |
Rep 1,165
Replaced the gasket last night. Drove for about 30min, stopped and checked, there were no leaks.
Drove 30min back, checked and no leaks. Start it up this morning, drive about 10min and parked it. Checked, and there was a small puddle of oil in the same place!! I cleaned it up, drove 40 minutes and no leak! To me it seems that it's only leaking when below freezing, and stops leaking once warmed up. Could this be an issue with my thermostat housing?
02-05-2022, 08:11 PM | #15 | |
Rep 3,560
02-05-2022, 09:47 PM | #16 | ||
Rep 1,165
As explained earlier. That is not leaking. It is leaking exactly like the attached photo (not my photo, from google search). And no, it's not from the oil filter cap.
Wolf 3352371.50 |
02-05-2022, 09:54 PM | #17 |
Rep 6,317
Wait... usually leaking like that is because of the O ring from the oil filter cap. Maybe that's it?
02-05-2022, 09:57 PM | #18 | |
Rep 1,165
I have now covered ~150mi since I replaced the gasket yesterday. It has only leaked once in that time :
02-06-2022, 03:21 AM | #19 | ||
Rep 483
Speedtech Top Mount 6766 2009 335i
VF Supercharged 2003 540i msport https://www.instagram.com/schwarz.e92/ |
Dave92N54530.00 |
02-06-2022, 10:04 AM | #20 | |||
Rep 1,165
02-06-2022, 05:21 PM | #22 | |
Rep 1,165
Just odd to me this gasket sealed perfectly for a year and then the new one leaks in the cold too. It's an easy enough swap, an hour max so maybe i'll give the BMW a go. My Elring is on warranty so can offset the cost of the BMW a bit.
