02-03-2022, 02:51 PM | #1 |
Rep 1,934
KW V3 or Ohlins? And Camber plates
The Ask:
Anyone running Millway camber plates with V3s? Background: I currently have some off brand "clubsport" style coilovers that I thought I would give a try. The amount of features for the cost seemed too good to pass (at the time). I believed I could adjust away anything I didn't like about them. Well I am regretting that decision. They perform well at autocross, but daily driving is quite stressful. I am in full body clench and watch the road closely as to not hit anything too bad. Night driving is even more stressful. When I DO hit a bump, it hurts my soul as the car sounds like the frame is hitting the ground or something. Not sure if it's just hitting the internal bump stops, as the tires do not show contact, and it isn't a metal on metal sound as you'd hear from spring bind. The car still has about a two finger gap on all corners, and I am at 14-16 clicks out of 20. They are as high as the directions said they could support. Rates are linear 350F/950R. Detail: As the title shows, I am deciding between V3 and Ohlins for my xdrive. I am also leaning towards compliance over sheer performance in the twisties, hence the ask about V3s. I am afraid that the Ohlins will be about as harsh a ride as I have now, albeit HOPEFULLY without the front end BANG over the oddest bumps in the road. Our Macan S eats the same road imperfections on our commutes without batting an eye (road work, train tracks, divots, manhole covers, etc), and it is on simple base suspension. I'd like more of that. NVH is not a problem here as I've already had setups with the standard ball bearings with steel camber plates on two cars (including this one). Autox will definitely continue this year, and planning to hit a couple road courses. Am I wrong about the ohlins?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
02-03-2022, 05:17 PM | #2 |
Rep 1,233
Not an expert on the F30 platform yet, but I run Ohlins R&T on my Cayman and I went 10% softer on the spring rates than they provide, and I run in the comfort setting of the coilover. The ride is well controlled and it "eats" bumps very quickly. It's hard to describe, you can tell the spring rates have gone up vs stock, but it's somehow more comfortable.
The challenge you will have is trying to come up with a setup that is good at AutoX as well as street - those are diverging needs. End of the day it will be a compromise regardless. There's no magic solution to fit all needs equally well unfortunately. |
02-03-2022, 05:22 PM | #3 | |
Rep 1,934
Do the cayman ohlins support PASM? You said that you keep them on comfort. This would be like the EDC on these cars.
02-03-2022, 09:05 PM | #4 | |
Rep 1,233
Talk to Barry @ 3DM Motorsports, he is a licensed Ohlins distributor and he can customize the set for you by choosing a softer spring, as well as re-valving the shocks to match if need be. He does that as part of his sale, and he's pretty knowledgeable about BMWs. The Ohlins (and other high quality systems) really shine through in dampening sophistication, and given you can customize the rates to match your needs and then still adjust the shocks easily is what you want. You can dial them up for HPDE, and dial them back for the street. Last edited by asbrr; 02-03-2022 at 09:34 PM.. |
alohasurftoad3132.00 |
02-04-2022, 03:50 AM | #6 | |
Rep 3,958
Logicoeur993.50 |
02-05-2022, 10:12 AM | #7 |
Rep 320
both are very good setups and will meet you're requirements but this is coming for someone who prefers a harsher ride.
i like the ohlins since they are rebuildable and the feedback on them is very good at the dual purpose application. I wonder if you can get them without the springs... Last edited by brigade24; 02-05-2022 at 10:12 AM.. Reason: claritin clarity |
02-05-2022, 10:31 AM | #8 | |
Rep 1,934
02-05-2022, 01:54 PM | #9 |
Rep 8,524
I posted multiple reviews/comments regarding Ohlins R&T.
is your friend... Quality is always worth paying for, IMO.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-05-2022, 02:07 PM | #10 | |
Rep 1,934
02-05-2022, 05:12 PM | #11 | ||
Rep 8,524
KW V3 were/are the basis of AC Schnitzer RS suspension - also not a huge number of people who made this choice (premium price product), but the RS kit has a good rep.
02-07-2022, 06:23 AM | #12 |
Rep 220
So I finally ran the KW V3’s in a track environment. The initial settings from KW were rubbish. Added more bump front a rear to stiffen the setup and it was amazing. Very neutral, deals with kerbs and bumps well and confidence inspiring in the corners. Really rate them
Logicoeur993.50 |
02-07-2022, 08:31 AM | #13 | |
Rep 1,934
02-07-2022, 05:48 PM | #14 |
Rep 220
Drove it home on the same track settings, and was actually quite comfortable. I do get a few noises from the camber tops though.
I did 3 more clicks hard on the front (compared to KW recommended) and 2 on the rear. I think it may need just a tad more on the rear to get more rotation mid corner. but this is now personal preference. |
Logicoeur993.50 |
02-08-2022, 09:47 AM | #15 |
Rep 320
02-08-2022, 09:54 AM | #16 | |
Rep 1,934
I am currently on 350lb/950lb with my setup, and first time ever at autox it held up pretty well, and it was pretty wet out. Not much body roll, but I did also have an lsd, new ECS summers, and a strut bar. I'd like to not go steps backwards in performance, but just increase the regular compliance for daily driving. There is just no compression at all on the coilovers I am running. And rather than spend more time and money with springs on these I'm just going to start with an already good setup.
02-08-2022, 10:06 AM | #17 |
Rep 320
I don't blame you. that's a good approach and will save you money.
Those are good rates...very balanced. right now im at 450in/lb up front and 1200in/lb in the back. those rates are set for the tires i run but i have a few sets that I can swap in and out depending on the tires im running but those rates seem to hit the grip limit before having to do a revalve. I already have a set of new BC dampers that will be revalved if I can find someone to do it. otherwise, it will be MCS or ohlins. |
Logicoeur993.50 |
03-17-2022, 08:13 PM | #18 |
Rep 1,934
Update: V3s and Millway street camber plates ordered. Hope to have everything installed before April's end to start the autox season.
04-18-2022, 10:50 PM | #19 | |
Rep 1,372
There was a suggestion above to go beyond the recommended settings, that might be a next easy step as removing bumpstops is going to be a multi-hour job. Please post your impressions of the V3. I've be going down the damper-bump-spring road for the last 6-8 months and while I find it interesting it's not for the faint of heart. The quest for the best all-round suspension can be long and difficult depending on the roads you face.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
04-19-2022, 01:12 AM | #20 |
Rep 220
Update, so i have the millway, V3's and just did the KW swaybar.... sway bar makes a huge difference..... worth every dollar and all the blood sweat and tears putting it in.
Still need to do the rear bar though, but want to go to an event on May 1st to see how the current setup feels at the limit |
Logicoeur993.50 |
04-19-2022, 06:47 AM | #21 | |
Rep 1,934
