02-15-2022, 10:54 AM | #1 |
Rep 5
larger brakes option
5.15
Can you give more detailed information about the parameters and other differences in the braking systems? Does anyone know the part numbers for the larger calipers (although in the video I did not see any differences in the calipers, but the disks are clearly larger) and discs? |
03-03-2022, 02:01 PM | #2 | |
Rep 63
03-04-2022, 12:54 PM | #3 |
Enthusiast
292
Rep 287
Drives: 2022 230i M Sport
Ha, perfect. I've been meaning to pull off rotors and measure, now I don't need to. Thanks (again)! I am surprised the rears are bigger...hell, I'd be surprised if even the same. I think that'd be BMW taking the staggered tire set up just too far, IMO.
03-06-2022, 12:19 PM | #5 |
Rep 446
Bigger discs in the rear are not that surprising. On the F22, the standard fronts are 340mm, and the rears are 345mm. The rears are a bit thinner (24mm vs 30mm front), so can handle less heat.
The non-stock 'big brake' M-Performance aftermarket option (not what came on the M235/M240), were 370mm. The 4-piston caliper for the M-Perf brake is the same size as the standard brake, but the mounting ears are offset to accommodate the bigger rotor. They could be doing a similar thing with the different rotor sizes on the G42. I don't have any idea of the actual size on the G42 though. Just starting to monitor these forums for a likely upgrade of my F22. |
03-14-2022, 09:30 AM | #6 |
Enthusiast
292
Rep 287
In my mind, only a 911, maybe mid-engine cars, should have rears that are of a same size as the fronts...but again, I think tire set ups factor in. 911s have huge rear tires compared to their fronts, and they stay flatter under braking too, give that rear axle more braking grip than is usual. The only think I can think of keeping that front smaller is for un-sprung weight. In all front engine cars, and vehicles in general, those fronts do most of the work stopping the car.
I am curious why BMW would put rears on that are bigger in diameter than the fronts. In any case, I ain't changing it, just want to understand it. |
03-16-2022, 04:30 PM | #8 | |
Rep 132
Regardless of where the engine is located, even on a motorcycle, weight always transfers to the front on braking, and the fronts are always designed to dissipate more heat. You will probably see that the front rotors, though smaller in diameter are double the thickness and have more mass, to manage the heat and not warp. The fronts have to also deal with more clamping force (friction) from the more powerful calipers. The master cylinder will be be designed to divert more force to the fronts as well. Not sure if that is helpful to you, but its not uncommon at all. I am positive the front rotors are heavier than the rears and that the calipers are also much more powerful. The rear is wider, but thinner as well. |
03-17-2022, 04:08 PM | #9 | |
Enthusiast
292
Rep 287
I the case of our BMWs, I can see the extra force is done via stronger caliper, and the wider rotor handles heat, but a larger diameter is avoided to resist handling liabilities of that un-sprung weight brings. And, to your points, then, the fronts remain much stronger than the back all the same. |
03-22-2022, 07:54 AM | #10 |
Rep 614
Drives: BMW 120d e82 M Sportpaket
In the end, do we have any idea of the stock discs diameters versus the "sport" version (ticked as an option or in th ZTK package) ? Same question for the calipers.
I hope BMW doesn't charge us hundred of bucks only for the colour
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
04-13-2022, 04:06 PM | #12 |
Rep 232
ZTK Package Rotors F 374x36 & R 345x24
YT: Conrad B
IG: conradb_93 |
05-07-2022, 01:36 PM | #13 |
Rep 38
So does the M240i without ZTK have slightly smaller front rotors? Maybe 355mm? I saw one thread debating whether the calipers themselves were bigger but it may literally just be the mounting point idk…
05-17-2022, 03:53 PM | #14 |
Rep 706
From what i can figure from other posts and following this topic in various posts for months, yes the M240i w/o ZTK option has 348 front and 355mm rear rotors. So yes slightly smaller front rotors. On the other hand i have never had it confirmed if the calipers themselves were larger on the ZTK option...i suspect not but have never seen it confirmed. A number of folks have asked this but i have never seen it positively confirmed. Looking at picts are not a reliable means of determining.
05-18-2022, 07:05 AM | #16 |
Rep 38
That looks pretty definitive to me. The inside edge of the caliper on the ZTK pack looks very straight whereas the standard caliper bows towards the hub and back out towards the ends of the caliper. Otherwise they look like scale versions of each other and very similar in overall design.
05-18-2022, 07:10 AM | #17 |
Rep 200
Drives: 2022 BMW M240i
They are bigger. Had a sales advisor tell me straight up. They're better for continued braking compared to the smaller M sport ones but if you want the best brakes get the M Performance Brake Upgrade Kit from BMW. Those are great.
05-18-2022, 08:17 AM | #18 |
Rep 1,961
For daily driver people like me I think m perf would be overkill. I'm happy with the slightly larger setup that comes with ZTK.
Brett_C_F30_G42381.00 |
05-19-2022, 11:45 AM | #19 |
Rep 232
I just received my 240 with the "ZTK" package would you like to see anything that will help you ?
YT: Conrad B
IG: conradb_93 |
05-19-2022, 12:07 PM | #20 |
Rep 1,961
If you can remove a front wheel and measure the caliper, that would be ideal. Or measure it somehow with the wheel on the car. Maybe slide a tape measure in and measure tip to tip and snap a picture. We can get someone with a non ZTK to do the same
Thanks for offering! Last edited by MPR; 05-19-2022 at 12:16 PM.. |
05-19-2022, 12:56 PM | #21 |
Rep 355
so the standard brakes are "M Sport" and the ZTK package is just a slightly larger "M Sport" front brakes? then there is the "M Performance" BBK? tbh, the names are so similar it gets confusing lol
