bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      02-15-2022, 01:58 PM   #1
iMnot
Drives: 2
Uniden r7 help
Anybody using mirror tap? Pls share thanks! I have mine plugged in the lighter adapter routed under the pillars
      02-15-2022, 03:25 PM   #2
240idax
Drives: 2022 BMW m240i
I haven't received my car yet, but willing to bet it would be very similar to this
https://g20.bimmerpost.com/forums/sh....php?t=1663910
Caerus534.50
Sonic RR127.50
      02-15-2022, 04:31 PM   #3
jpcoop
Drives: 2022 M240i xDrive
Yep, I used that thread to install the mirrortap for my Escort Redline and the directions worked fine. The mirror assembly is probably the same exact part. or at least very close.
      02-23-2022, 02:36 PM   #4
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
Doing mine tonight!
      02-25-2022, 03:24 PM   #5
xcelir8bmw
xcelir8bmw's Avatar
Install was easy peasy but I had to order a blend mount to install today. Pics soon.
      02-28-2022, 06:20 PM   #6
xcelir8bmw
xcelir8bmw's Avatar
Installed
Caerus534.50
VegasG42381.00
      03-28-2022, 10:20 AM   #7
jbazz
Drives: 2019 x3 30i , 1990 Miata Turbo
Which blendmount did you get for your R7? the site lists 2 options.
      03-28-2022, 12:08 PM   #8
xcelir8bmw
xcelir8bmw's Avatar
BR7-2001R
jbazz256.50
VegasG42381.00
      08-08-2022, 11:42 AM   #9
iMnot
Drives: 2
Did you connect to the mirror or rain sensor? Thanks
      08-08-2022, 04:52 PM   #10
jpcoop
Scroll up and follow the directions linked in the 2nd post
      08-08-2022, 09:02 PM   #11
G42Enjoyer
Drives: 2022 m240i
From previous thread:
Originally Posted by G42Enjoyer View Post
Just wanted to post a picture of my setup and add a little info. There's great info and install pictures in this G20 thread.
Basically what I found out is that the upper purple connector for the rain sensor is always on, which is okay if your radar detector shuts off, but not good if you have something that doesn't power off like the Escort dash cam. Mine was taking video of my garage for hours.
It seems like bigger connector below the purple one is a better place to tap because it actually switches off after a while. I locked the car and took a 7-8 minute walk and it was powered down. It turned on automatically when I opened the car door.
Also FYI, if your devices do not work with the 12v cigarette lighter outlet by the cupholders, that is probably due to the metal contact screw at the bottom of the socket being too short. I've seen other threads where BMW has replaced the contact screw with a longer one so your 12v plugs will work.
Blendmount used
Wiretap used
Escort dashcam kit
      09-24-2022, 12:58 PM   #12
XC3LLR8
Drives: Super73
R8
      05-12-2023, 09:23 PM   #13
hyperpip
Pip
hyperpip's Avatar
21
Drives: 2023 BMW M240i xDrive
Mirror Tap Power Off
Does the mirror tap cut power after a while when car is turned off? I'm using a Uniden R3 wired to the mirror and I waited about 5 minutes and it didn't seem to power off
      05-12-2023, 10:39 PM   #14
XC3LLR8
Drives: Super73
Mirror Tap doesn’t, but you should be able to set R3 to automatically turn off after a certain amount of time…at least you can on the R7 and R8.
I just power mine off manually when I pull into the alley, or elsewhere if I’m out of the car for awhile.
I could disassemble and tap into the correct wire that cuts power with the ignition, but not motivated enough to do that.
      05-12-2023, 10:56 PM   #15
ryo-
Drives: '22 MWM M240i
mine turns off after roughly 7 minutes with the mirror tap (I'm assuming that's when the mirror/lights cut power).
TJZ67201843.50
      05-13-2023, 12:50 PM   #16
XC3LLR8
Drives: Super73
Sounds like you tapped into the correct wire, or at least a better choice than mine. Mine will stay one until the R8 times-out, or of course if I manually turn it off, which I do most of the time.
      05-21-2023, 10:28 AM   #17
TJZ67201
TJZ67201's Avatar
Drives: '23 M240i
Mine too. Someone linked a G20 thread a few posts up. I followed that back in November and it worked like a charm ever since.
Some things to note: power shuts off after 7 to 10 minutes of not using/waking the car. The power will be turned on if you do anything to wake the car. IE: unlock doors, open a door, pop the trunk, shut the hood, etc.
g87
