02-18-2022, 06:23 PM | #1 |
Rep 217
Air suspension sag
Came home today and noticed my wife’s 45e was sagging on the drivers rear wheel. Anyone experienced something similar?
She’s been out of town for five days and the car has not been driven, I’m assuming there may be a slow leak? I started the car and reset the air suspension by turning it off and then on and it fixed the issue for now. Pic attached. |
02-18-2022, 06:33 PM | #3 | |
Rep 4,246
When the vehicle is parked for long periods of time, it can lower itself and is not a malfunction.
02-18-2022, 06:39 PM | #4 |
Rep 217
02-18-2022, 07:10 PM | #5 | |
Rep 4,246
The front two air struts are jointly controlled and the rears separately. If it's the one, get it checked out to see if it reoccurs, since you mentioned it's all are back to normal after driving. And definitely have it checked out if there's was a Check Control message. Did you get a Check Control message? "Leakages After longer stationary periods, the vehicle may reach a low level due to leakage. To prevent damage due to reduced underbody clearance, the driver receives a corresponding Check Control message." Leakages are equalized within 32h via a wake-up control. For this, the vehicle wakes up at various time intervals and adjusts the ride height if necessary. Troubleshooting will entail: • Adjusting and note maximum storage pressure of the pressure accumulator with assistance of workshop information system ISTA • Deactivate air suspension (workshop mode) • Search for leak (check components using leak detection spray) • Determine storage pressure again after some time and check plausibility They'll also check the Electrical Height Control (EHC) unit which monitors the air suspension components and stores faults that have occurred: - Pressure sensor - Functional check of the pressure sensor - Pressure accumulator - Filling and draining of the pressure accumulator - Vehicle level - The following levels can be set: Terrain ride height, High ride height, Normal ride height, Dynamic ride height, Sport ride height, Load ride height - Ride height adjustment - Start-up of the ride height sensors - Compressor cycle - Functional check of the compressor - Air spring - Filling and draining of the individual pneumatic strut assemblies - Status values - Output of all system-related status values such as pressures and ride height - Delete transport mode - Reset the transport mode If the communication to the EHC control unit fails, they'll run the standard checks (global test module). If there is an internal control unit fault, the following behavior is to be expected: - Fault memory entry in the control unit for the electronic height control (EHC) - Check Control message in the dashboard
02-19-2022, 10:48 AM | #8 | |
Rep 217
It's only two months old, so no warranty issues. |
02-19-2022, 01:43 PM | #9 |
Rep 1,531
My wife’s is 2 years old and so far no issues. Sounds like a possible defect?
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
02-20-2022, 07:22 AM | #10 |
Rep 14
Blake, I had the same problem and at the same corner of my 45e. Dealer inspected and ordered a new air shock which put the vehicle out of commission at the dealership for nearly 60 days (in Georgia, this qualifies as a lemon law vehicle due to days out of service). The dealer was returning the vehicle to me when a warning light came on for the hybrid control and the box was ordered. This would require the 45 to be out of service an additional 30+ days waiting on parts. BMW and the dealer worked with me and I should take delivery of a 2022 model at the end of March. Side note, I’ve been in an X3 loaner for this period of time. Dealer has been fantastic. Definitely is it the dealer as I was told I couldn’t drive the 45 for safety reasons. Best of luck and keep us posted.
02-20-2022, 08:17 AM | #11 |
Rep 362
Definitely take it in. Something is up.
Can lead to air compressor failure from continuous refilling. The air bags usually last ⅘ years until they leak.
Dont be humble, give me that rumble. 2022 F95 X5MC, 2020 G05 40i, 2016 F86 X6M (sold), 2014 328ix F30 (totaled), 2009 e91 328ix (sold), 1997 740i e38 (nikasil fail)
1230vani660.00 |
02-20-2022, 09:30 AM | #13 |
Rep 4,246
With the G05's air suspension, if there is an issue with the air strut the entire unit is replaced.
The "bag" forum members are referring to is a U-type bellows sealed in the pot and isn't serviceable. "The U-type bellows or the shock absorber cannot be replaced separately."
02-20-2022, 10:23 AM | #14 | |
Rep 362
I'm going to look under my f95 as I'm curious. Good luck. Probably need a new strut. 2 pics from the tech doc for G05. One from f85/6.
02-21-2022, 03:56 PM | #15 |
Rep 540
It is definitely not normal. I had the exact same issue with our previous F15. At first, I didn't much of it since it raised and leveled itself after turning on the ignition. However, the issue resurfaced in a more frequent manner. It turned out that there was a slow leak in the system. They ended up replacing both of the rear suspensions. This was why I deviated away from air rides with our G05.
If it is still under warranty, there is no point of sweating. Take it in. |
SmartSaves462.00 |
02-21-2022, 07:59 PM | #16 |
Rep 289
This is air bag leak and needs to be fixed ASAP otherwise the air pump will overworked and break prematurely. There are rebuild and aftermarket option that meets or surpass OEM.
02-25-2022, 07:43 AM | #17 |
Rep 4,468
Removing & replacing air suspension
Question: For those who buy and keep their X5's beyond warranty...If at some point beyond warranty the air suspension system fails and you would like to replace the air shocks with non air shocks, like an X5 that came from the factory without air suspension, what sort of job would it entail...aside from the mechanicals of removing the air shocks and bolting up the non air shocks?
- Will the normal non air shocks mount in the same places as the air shocks? Are they dimensionally equivalent? Including mounting holes, brackets and connected suspension points? - Can the air suspension electronics simply be unplugged, coded out, etc so it doesn't throw codes or make the X5 inoperable? - Whaddayathink? Doable? |
02-25-2022, 07:57 AM | #18 |
Rep 30
I don't have the exact problem, as I don't notice a difference in suspension height when sitting for a long time, but I do notice that my car is not 'level' through each setting.
It seems the rear is always lower. It is a 2019 under warranty, and the dealer said everything is normal. Should I push the issue? |
02-25-2022, 02:08 PM | #19 |
Rep 217
Update. I took it in, they had it all day, inspected it for leaks, hooked it up to the computer for fault codes.
Dealer is claiming there is no leak and they can't replicate the issue... |
02-27-2022, 05:06 PM | #20 |
Rep 77
What was their reaction to the pictures?
Past X5's - '01, '04, '08, '12=X5D
02-28-2022, 10:01 AM | #21 |
Rep 217
They placed them in the service record file. My wife is going out of town in two weeks, so I'll let is sit a few days again and see what happens.
Assuming it sags again (I'm pretty confident it will), I'm going to take it in and make them keep until its fixed, I'll make sure to get a loaner this time. I highly doubt this was a one time occurrence, there must be a leak somewhere in the system. |
Nikita4441.00 |
02-28-2022, 11:08 AM | #22 |
Rep 77
suggestion: get a yard stick and take a pic with the yard stick against the fender at what is assumed normal height, and then if it sags, take another with the yard stick for comparison/proof.
Good luck.
Marty in NY2815.00 |
