02-21-2022, 03:33 PM | #1 |
Rep 1,232
Compared width of pilots 4s vs Pzero for spacer size calculations
So I kept reading up on Rubbing issues and spacers with different brands. I wanted to know the true difference in actual width of the tires so we can calculate rubbing issues with the spacers and what is true difference. Here are the specs and major differences from tire racks testing:
P-zero Tread width of 9.2 inches Pilots 4S Tread with of 8.9 inches If there is a .3 inch difference that in millimeters is 7.62. I would divide that in half because it is split on both sides of the tire. So the P zero tires need roughly 3.8mm of clearance on the fender then the Michelin or another way to say it is you can run a 3.8mm bigger spacer on the Michelin which makes sense why a 12mm spacer rubs on a the p zero but 15 mm front spacer doesn’t on the Michelin… Anyone see anything I missed? |
02-23-2022, 02:19 PM | #2 |
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Interesting to see that the Pzeros are wider, lighter (and have stiffer sidewalls). That Michelin marketing budget though...
04-27-2022, 03:48 PM | #4 |
Rep 278
From what I'm seeing some are running 12mm and 15mm up front with the Pirellis with no rubbing (I suppose that depends on how low the car is, and if trimming plastic at all - but seems folks can get it to work).
Sounds like its possible to run 15mm in the rear as well. |
04-28-2022, 08:21 AM | #5 |
Rep 655
i have 12mm future classics on all 4 wheels. had 963m and michelin all seasons on, swapped back to the factory setup for summer, 826m and pzeros and i 100% rub. mostly notably when reversing out of parking spot and have wheel turned all the way
04-28-2022, 05:40 PM | #6 |
Rep 278
Do you rub just in front? Lowered at all?
04-28-2022, 11:50 PM | #7 | |
Rep 655
