02-21-2022, 06:30 PM | #1 |
Rep 754
Drives: 2022 M3 Competition
Blackvue Dashcam Battery Mounting
I was inspired by forza1976's post on mounting the Blackvue Power Magic dashcam batteries to the deck lid of his trunk, but I was hesitant to use screws. My wife does a lot of 3D printing so she helped me design a battery cage that could be affixed to the rear decklid using automotive tape in the same location as forza1976's.
Here's the first prototype. We added two little nubs at the end to hold the battery in place once it's slid into the tray. It's about 3mm too narrow, so she's going to tweak it slightly and give it another go. Only another 19hr wait. What do you all think? Any suggestions for improvements? Once this is done she'll be making the file available for use by others that have their own printer.
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
chicagofan0019255.50 mzcp2692.00 forza19763399.00 Professor///M820.00 NightWriter4844.00 Daily_drivX5M261.00 Vinnrox2503032.00 M4Tejas804.00 |
02-21-2022, 08:42 PM | #3 |
Rep 754
Thanks. I'm super excited to give it a shot. I'll report back with an update tomorrow.
mzcp2692.00 |
02-21-2022, 11:28 PM | #4 |
Rep 911
Drives: 2022 G80 Comp x-drive
Just curious, why not mount it in the side cubbyhole where most seem to place it? There’s even an outlet right there iirc.
I don’t even have my car yet, so I am just wondering.
2022 G80 comp X-drive:San Marino Blue/ Silverstone, 826 bicolor, cf roof; exec pkg; shadow lasers; carbon pack; MSS HAS; spacers (15/12); Burger intakes; Unit17 front lip/CS Style spoiler; TLG flappies; full xpel ppf + 15% tint; AWE switchpath exhaust w/mid-pipes; csl strut brace; Eventuri cf engine cover
Gone: 2020 M340i; 2017 F30 340i; 2008 e92 335 |
02-22-2022, 05:45 AM | #5 |
Rep 754
That's where I have it now. I have two batteries and they'll stack on top of each other and just barely squeeze in the cubby. It's workable. Putting them on the trunk deck lid would allow the batteries to be up and out of the way so that the cubby could be used. I had the idea after seeing Forza's post, I'm bored and thought why not try it. What's great is it'll only require auto tape to install. If doesn't work then I'm out nothing.
bmw noob1458.50 |
02-22-2022, 10:45 AM | #6 |
Rep 6,593
Love it, can't wait to see the final product.
tnd720 can you print some for me once we have the source file? |
02-22-2022, 06:52 PM | #7 |
Rep 754
Here's try number 2.
I had to cut out a couple of the supports in the back because they blocked the plugs. DOH. We've adjusted the supports for the 3rd so there will be just 2 vertical supports in the back maybe an inch inside the corners. This is to allow the primary battery plugs. I added 3 layers of 3M automotive tape to the left side and 2 layers to the other two sides to compensate for the contours of the deck lid. I don't think I'll need to do this to the other cage that will go on the right side of the trunk. Here it is attached to the deck lid with and without the battery. I'm leaving the battery in the cage overnight and will see if it's still attached in the morning. I don't have any reason to believe that it won't be. It's got a lot of contact area. I should have the next run sometime tomorrow and I'm going to try to install it equidistant to the trunk light on the right.
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay Last edited by HTTP 410; 02-22-2022 at 07:08 PM.. |
02-23-2022, 11:36 AM | #8 |
Rep 754
Minor setback. The multiple layers of 3M tape didn't hold overnight. It appears that it is was the tape sticking to itself. The final design print will be done this afternoon. In the meantime I need to find a thicker adhesive to fill in the contours of the deck lid. I just tried high strength magnets, but the battery is just too heavy (3lbs).
forza19763399.00 |
02-23-2022, 10:34 PM | #9 |
Rep 911
What about doing the reverse solution…make a cage to create a cover over the batteries where they are so you have a flat surface to make the cubbyhole usable without having to hang the actual batteries?
Or use a bracket to install them in an “L” with one flat, and one vertical against the back wall of the cubby area?
02-24-2022, 07:48 AM | #10 | |
Rep 754
There's just not enough room within the cubby itself. I can get both batteries wedged in there without deforming the ring that's on top of the cubby. The updated design finished last night. I think this cage will provide a lot of flexibility. If you want to attach them together to form a box and zip tie them to the top, you can. If you want to Velcro them to the side of the trunk, like in the other post, you should be able to do that, too. My next attempt is going to be to use high strength neodymium magnets. I have two and trialed it yesterday. I plan to try 4 on each cage and don't think it'll fall down plus it'll clear all of the contours in the deck lid. I won't get them for a few days. I don't really have a backup plan if that doesn't work. Maybe I'll just leave them where they are. I sure am having fun with it though. Keep the suggestions coming!
mzcp2692.00 |
02-26-2022, 07:34 AM | #11 | |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
...and I just saw your last post. Always forget to read last first, then backtrack... |
02-26-2022, 07:43 AM | #12 |
Rep 3,341
What I'm planning on doing is putting some high strength velcro straps through that opening where you can see the padding near the back of the trunk. You may want to consider doing the same thing - just guide it through the boxes.
HTTP 4102141.50 |
02-26-2022, 05:51 PM | #13 | |
Rep 754
02-26-2022, 05:53 PM | #14 | |
Rep 754
to stack the batteries and then mount them to that spot with zip ties. I may still try that.
02-26-2022, 06:16 PM | #15 | ||
Rep 3,341
This is what I was thinking for you: https://www.homedepot.com/p/Master-M...90HD/202526371 One screw through the top into the plastic, one at all 4 corners. Should get you 6lbs of pull |
HTTP 4102141.50 |
02-26-2022, 11:01 PM | #16 | |
Rep 911
What about having one under the cubby liner, and one above the cutout opening, but offset…like a step? ——\____ that could still leave the space on top usable. If you leave one under the opening you could mount the other battery vertical against the side wall inside of a cage to protect it and the wiring. It would kill a couple inches from the cubby, but leave the top of the trunk free. Can you put one battery in/on the other side cubby?
HTTP 4102141.50 |
02-27-2022, 09:11 AM | #18 | |
Rep 754
02-27-2022, 09:15 AM | #19 |
Rep 754
I saw forza1976's post with the two batteries so I blame him for me purchasing a second battery and starting me down this entire path.
The Power Magic Ultra Battery is rated at 24hrs, but battery life is going to vary based on what it's powering, temperature, etc. I'm running the front and rear cameras as well as the LTE module. I'll have to travel once a month or so for work and I'll end up parking the car and letting it sit for a couple of days because the hotel is walking distance to the office. The two batteries should get me about 2.5 days of power without recharging so I think it's a great solution. If people didn't suck we wouldn't need to take these measures.
02-27-2022, 05:57 PM | #20 | |
Rep 1,773
Also, any reason you didn't the the blackvue with the LTE module built in? |
02-27-2022, 06:06 PM | #21 | ||
Rep 6,593
BMWRacer5232520.50 HTTP 4102141.50 |
02-27-2022, 06:09 PM | #22 |
Rep 6,593
I will say that I get more duration on both batteries with 1 channel recording. Typically I find a good spot I can back into at the airport garage. I look for a spot to back up to a wall that has no foot traffic behind. Then I can only worry about the front.
I do wish blackvue would allow for geolocation to set certain camera modes. E.g locations for 1 channel versus 2 channel recording. |
BMWRacer5232520.50 |
