View Poll Results: Where should I put it | |||
Location #1 - Top Mount | 4 | 100.00% | |
Location #2 - Side Mount | 0 | 0% | |
Location #3 - Compartment Side Mount | 0 | 0% | |
Location #4 - Someplace else!! | 0 | 0% | |
Voters: 4. You may not vote on this poll |
02-22-2022, 05:36 PM | #1 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
Blackvue Battery Location
I've been trying to find an ideal place to mount the blackvue extended battery. One of the most obvious locations would be within the small box in the bottom right side of the trunk. I didn't like the fit, and noticed that it could fit in a variety of different locations. I'd appreciate your thoughts through the poll & comments as to where you think it would be the best:
Option 1: It's hanging, so I'd assume this may cause rattle/vibration. Also if I stuff my trunk the wires could get dislodged. Option 2: It's out of the way, and I could hide the wires in the little storage bin. I guess the caveat is the same, with a full trunk it could be against something. Option 3: I think this is the best spot, especially since the velcro I'm using sticks well to the carpet. I could also anchor it to the little metal piece, but if the velcro starts to fail over time, or isn't as sticky to the trunk mat, it's going to end up in the compartment anyway. I appreciate your insight to this, or whether you had a better spot. I already checked out the battery compartment, and it just seems too cramped for this thing in there. |
02-22-2022, 05:42 PM | #2 |
Rep 6,593
Top, tried the side and didn't like the clutter in the cubby.
Professor///M820.00 |
02-22-2022, 05:47 PM | #3 |
Rep 6,593
@HTTP 410
02-22-2022, 06:10 PM | #4 |
Rep 3,341
02-22-2022, 06:58 PM | #5 |
Rep 754
Drives: 2022 M3 Competition
Check out my thread here on a custom 3D printed cage for the Blackvue batteries.
https://g80.bimmerpost.com/forums/sh....php?t=1901190
2022 M3 Comp BGM/Fiona Red, Executive, Drivers Assistant Pro, Parking Assist, 826M black wheels
(SOLD) 2018 M2 BSM LCI, DCT, Executive, Drivers Assist, CarPlay |
02-22-2022, 07:13 PM | #7 | |
Rep 3,341
Thanks everyone for all of the suggestions |
HTTP 4102141.50 |
02-22-2022, 07:14 PM | #8 |
Rep 754
I'm going to make the files available for free once I'm done. I'll post links to them in the other thread.
02-26-2022, 12:03 PM | #9 | |
Rep 3,341
Ultimately I picked option 3 for now, and it's due to another accessory I have in the trunk. Here's the setup: I have high strength velcro straps around the unit, and it adheres to the back of the box, along with the side wall making it very stable. I have about 3 different cables that I run through the fuse panel section, which includes the dashcam wire, the excess battery cable, and the wire to my emergency light. Instead of a traffic triangle or flares, I have a LED emergency light that I mount in the trunk of my vehicles. I realized that I can simply use the blackvue outlet for when I need to use it - and that will actually help for if I'm ever stopped without power to the vehicle. So as a result of that wiring, I kept it in the compartment on the side. Here's what that looks like: Ignore that it's off center, I have to fix it. With the blackvue battery where it is, I can easily swap the plug if the vehicle is ever disabled (or if I roll up on an emergency). |
02-26-2022, 05:45 PM | #10 | |
Rep 754
Where'd you get the high strength velcro? Gotta link?
02-26-2022, 05:47 PM | #11 | ||
Rep 3,341
That's what I used |
HTTP 4102141.50 |
02-26-2022, 05:55 PM | #12 | |
Rep 754
02-26-2022, 07:55 PM | #14 |
Rep 754
Here's the file on Thingiverse - https://www.thingiverse.com/thing:5264839
02-26-2022, 08:10 PM | #15 | |
Rep 6,593
