02-27-2022, 01:22 PM | #1 |
Rep 35
2014 435i awd vs rwd ride height
Is there a difference in springs and ride height on xdrive cars vs rwd?
I have a 435i xDrive m sport with EDC. Front fender gap is huge, was wondering if stock rwd front springs would bring it down a bit. I don't really want to lower the car all around, thought maybe just these front springs would be a compromise. thanks ian
2014 435i xDrive
02-27-2022, 02:35 PM | #2 |
Rep 787
Yes, rwd is lower. You can't lower too much on x drive cars because it strains the axles to the point of failure, but oem springs don't lower substantially, so you should be fine on them. I have a set of rwd, m- sport springs that just came off my '15 335i. I was planning to list them for sale when I got back home in a couple of weeks. The x drive car is a bit heavier than RWD, so these might not be ideal, and I can't personally guarantee they would fit your car, but someone else might be able to chime in here to confirm.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
02-27-2022, 03:06 PM | #3 | |
Rep 35
Thanks Ian |
02-27-2022, 04:14 PM | #4 |
Rep 2,055
The problem with only installing shorter springs at the front is that spring rate will likely be different (due to the reduced travel in which to control the mass of the vehicle) which will alter flat ride and might not give the ride characteristics you're after. From what I've seen most of the spring packs provided aftermarket keep a similar F/R height relationship so if you're looking to drop the front, and in doing so increase the rake angle which will move the roll centre forwards and improve turn in, you can only do this via coilovers which is likely not the route you'd want to go down!
02-27-2022, 05:44 PM | #5 | |
Rep 35
If i was to just try some m sport rwd car front springs, i wonder how much drop thst would accomplish. |
02-27-2022, 10:03 PM | #7 |
Rep 35
02-28-2022, 05:12 AM | #8 | |
Rep 2,055
I've also driven cars which have mismatched springs before which have worked well, but only because the rates and ride frequencies have been worked out. I've been in a lot more that drive terribly. The issue with mis-matched spring rates is that you end up with ride frequencies that can be at odds with each other. At best this can give head bobbling over uneven roads (bad enough to make you feel a little queasy), or at worst it can completely destroy the handling balance of the car. If someone has the data on what rate the standard RWD front springs are vs the AWD items then that will allow you to decide whether it's going to work. I suspect they're going to be too stiff to match to the rears. |
02-28-2022, 10:01 AM | #9 | |
Rep 35
thanks Ian
2014 435i xDrive
02-28-2022, 10:39 AM | #11 |
Rep 4,380
just do it "right", with Eibach 5-22 and F80 bump stops.
https://f30.bimmerpost.com/forums/sh...1901058&page=2 |
dmanb2b2134.00 |
02-28-2022, 11:26 AM | #12 | |
Rep 35
I had read through that thread before. Good info in there.
2014 435i xDrive
dmanb2b2134.00 |
02-28-2022, 11:50 AM | #13 |
Rep 4,380
with the adaptive dampers you currently have...
like @psyki https://f30.bimmerpost.com/forums/sh...0&postcount=35 https://f30.bimmerpost.com/forums/sh....php?t=1765870 . Last edited by alohasurftoad; 02-28-2022 at 11:55 AM.. |
dmanb2b2134.00 |
03-02-2022, 03:59 PM | #14 |
Rep 3,361
