02-27-2022, 09:48 PM | #1 |
Rep 68
Anyone running Godspeed springs?
I drive a 2013 328i xdrive M Sport sedan and I am considering buying Godspeed Traction-S performance lowering springs. Does anyone have any experience with these?
PFA |
03-07-2022, 07:12 AM | #3 |
Rep 1,934
Skip and go straight to coilovers.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
03-08-2022, 08:45 AM | #4 |
Rep 68
I've considered this, but all I would be able to afford currently is BC Coilovers which make me think twice about the quality because they are so cheap. Plus it would be nice to keep my adaptive shocks for awhile until they give out.
I've narrowed it down to Eibach and Godpeed because they lower the front slightly more which helps with the xdrive reverse rake. I'm still open to other suggestions though. |
03-08-2022, 09:17 AM | #5 |
Rep 1,934
Save for 2-3 BC coilovers and get something good. Bilstein b14 and Kw v1 are close to the BC price. If you aren't in a wintery salt area then ST suspension is KW without the stainless coating for cheaper. There are options that aren't much more expensive than BC.
Just skip springs. Short term they will look good but the ride always ends up trash because you are rolling the dice pairing them with any shocks. Coilovers are shocks and springs engineered together which is miles better.
04-17-2022, 02:49 PM | #6 | |
Rep 426
