BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Front differential Oil change - anyone DIY yet?
      03-01-2022, 11:02 AM   #1
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
I got a message from my dealer who said the "Car called them" and said it needed an oil change and a differential oil change for the front differential.
Anyone DIY this yet??
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      03-01-2022, 11:38 AM   #2
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
PDF of service
600 ml of fluid. Don't over fill.
Looks pretty straight forward.
Mike
Egrunt553.00
      03-01-2022, 11:54 AM   #3
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
as per this, the Front, Rear and Transfer case oil is supposed to be changed every 90,000 km. So why is my car asking for only the front? This is very odd.
Mike
Egrunt553.00
      03-01-2022, 12:50 PM   #4
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Wow — 2 year oil change interval. And I thought 1 year was a long time.
      03-01-2022, 01:30 PM   #5
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
I've been doing my oil changes every 5000.....I'm old school...
The PDF for the front diff says 600 ml, but the PDF for the rear diff has a 'broken' link to a table. So I have to figure out the proper volume of fluid for the rear diff. I have that special oil already for the rear. Front uses less fancy fluid. LOL.
Mike
      03-01-2022, 02:14 PM   #6
micvite
Drives: 2009 mazda RX8
Mike
I'm guessing you're past 3/36? Lol dm me your vin and I'll run it through the bmw maintenance program and give you the specs for everything (perks of owning a shop lol)
      03-01-2022, 10:09 PM   #7
Demon Barber
Drives: 2018 M5, 2022 911 Turbo S
Mike
Rear diff requires exactly 1 liter of Hypoid G4 fluid, part number 83-22-2-447-362. Apparently, filling to the edge of the fill plug would be overfilling. I plan on doing my front and rear diff, transfer case, and transmission fluid changes myself this spring. Already purchased all the materials.
      03-02-2022, 04:37 AM   #8
99540
Drives: 21M5comp;20x4mcomp;95m3;03cob
I actually went to have secondary dp installed and shop noticed front diff fluid seeping and lower oil pan gasket seeping/leaking. They said diff looked to be over fill and There was oil stains all over the bottom of the pan. After my last oil service I noticed oil drops on my garage floor the next day, took it back they said spillage and cleaned it up. Now it's at the dealer for this, they are waiting on approval to change the gasket. Any thoughts on what would cause lower oil pan gasket to leak. Over fill of oil? The car is really babied with couple pulls here and there. 9k miles on it.
Thanks
      03-02-2022, 04:41 AM   #9
micvite
Thanks
Could just be a botched install honestly, or could just be leaking from so.ewhere else like say front diff that was over filled or from filling oil up top and spilling everywhere.
      03-02-2022, 04:46 AM   #10
99540
Thanks
Gotcha thanks! it's been a week and waiting for bmw to approve the gasket change, annoying. The lead foreman wants to change it out of precaution and I guess bmw claims it's not possible it can be leaking so they did the dye test, not sure of the results as I'm too pissed to call back.
      03-02-2022, 05:43 AM   #11
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Excellent, was hoping to find printed proof of this volume. I actually have several bottles of the Hypoid G4.
Interesting update in the Manual says now to use the G1.
File Type: pdf Final drive oil - new oil quality from 07 2011.pdf (57.9 KB, 182 views)
      03-02-2022, 05:49 AM   #12
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
The section on the front diff SPECIFICALLY says 600 ml. Second picture.
The section on the rear diff has no such specification, only that the stuff comes in 1 liter bottles. So I can see how the techs would overfill using the old school, fill until it runs out. This is shown on videos, but APPARENTLY not supposed to are done with the M5????? ODD.
Mike
      03-02-2022, 05:53 AM   #13
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
I have 4 of these (500 ml each) so I'm good to go for the next two changes LOL. Unless it's true that the G1 "Should be used"
I'll bet if you ask the dealer they will have no idea which is now the correct oil to use in the rear.
Mike
Maverik2594144.50
      03-02-2022, 07:41 AM   #14
micvite
The g1 is for non m vehicles ( says it in the pdf) the thing with ista is it gives you the info for every car and you have to piece together what's for what lol...
      03-02-2022, 08:02 AM   #15
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
you appear to be correct but the bulletin is contradictory.
I have the G4 and plan on using that for the rear. I am getting other materials together. The transfer case is much more involved though, as per the PDF you need to disconnect the drive shaft to have access to the drain plug. Nice design.
Mike
      03-02-2022, 08:35 AM   #16
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
This the kind of BS that just pisses me off.
The 'F90 Complete Vehicle' PDF has this....
SPECIFiCALLY calls out the volume of fluid for the front differential but neglects such information for the Transfer case and Rear Differential. Lame....
Mike
      03-02-2022, 08:44 AM   #17
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
F )U*(__()_)*()_&_* I found it...my bad.
1 liter.
LOL
      03-02-2022, 10:21 AM   #18
micvite
Mike
yeah Like i said ista gives you a bunch of stuff when you search the service manuals lol... half of it has nothing to do with your car and you have to sort through it lol...the part where it says f90 blah blah just states that's the car that was selected and thats about it, not that this particular page pertains to it
      03-02-2022, 10:26 AM   #19
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Everything ordered, engine oil, filter, air filter, carbon air filter, diff fluid for front, 14 mm wrench, 4 new plugs, transfer case fluid and plug, oil transfer pump...$$557.....
Mike
      03-02-2022, 10:33 AM   #20
AHall
Drives: 1993 Nissan 240sx
Mike
Step by step with pictures please.
      03-02-2022, 10:38 AM   #21
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Certainly LOL.
Mike
      03-05-2022, 08:01 AM   #22
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Bought all the supplies from FCPEuro. What is with their INSANE warranty?...I return the oil and filter (engine oil and diff oil etc) and pay the return shipping and they send a new setup for free? WHAT THE HELL? It's real. But it's insane. LMAO
Mike
https://www.fcpeuro.com/products/5-8...arwrench-80546
m5post
