BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Best light bulbs for garage heat?
      03-03-2022, 04:35 PM   #1
ChrisV_313
Drives: '07 Z4 Coupe 3.0si
Hi all,
I live in Canada and as such my garage gets DAMN cold in the winter. I currently use four 175W Phillips incandescent IR heat bulbs to introduce some heat and keep things a few degrees warmer. I leave these lights on pretty much 24/7.
I know a lot of lights emit UVA and UVB light, could this be damaging my cars' paint/plastics long term? If so, are there better heat-emitting bulbs to use which do not emit UV rays?
Thanks
      03-03-2022, 05:15 PM   #2
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
https://www.homedepot.ca/product/dim...rey/1000116310
Where is your panel?
Insulate your garage if it's not. Mine is, and my doors are too, and it never gets below 5C in the garage.
I just use the heater when I need to do work out there or buzz my hair in the winter.
      03-03-2022, 05:45 PM   #3
Burrcold
Drives: 2024 M3 Comp xDrive
Agreed, insulate your garage and it will pay for itself pretty quickly in utility savings. I did all the walls and garage door, and use a space heater if I need to work on any of the cars in the winter.
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
      03-03-2022, 07:57 PM   #4
kpm
Drives: 2009 E90 335d Monaco Blue
1985 325e BMW  [0.00]
2009 328i  [0.00]
1991 BMW 318is  [0.00]
2009 BMW 335d  [0.00]
My garage is insulated but can still drop below freezing at times. I use a Delonghi oil filled radiant heater to crack the chill. Programmable timer with set point down to 5 deg C. Keeps garden hose from freezing, saves seasonal transport of liquid auto and garden products to basement and only consumes energy when absolutely needed.
      03-03-2022, 08:42 PM   #5
My oversized double insulated garage is actually my cave man that I share with the 911 and has been doubling up as my day office for the last 2 years..
I got the oil radiator on timer (05:00- 16:00), a hanging square box heater kept at minimum overnight that I crank up 30 minutes before going in, a electrical fireplace for ambiance and I ran a vent from the house.
Yes, yes bylaws crapola... The 911 is rolled out 20' down the driveway before its started so the only obnoxious odors is when I let go one
      03-03-2022, 09:13 PM   #6
dscabra
dscabra's Avatar
5428
Drives: GMC Denali
A gas heater is far more efficient than light bulbs for heating your garage. I have one of these in my garage and in my shop. It costs about a dollar a day to keep each at 50 degrees in the winter.
      03-04-2022, 01:41 AM   #7
x622
Forced Induction Connoisseur
x622's Avatar
1315
Drives: 23 X5MC / 23 720s / 25 M4CS
2025 M4 CS  [0.00]
2023 BMW X3MC  [0.00]
2023 Mclaren 720s  [0.00]
2005 Honda S2000  [0.00]
2023 BMW X5MC  [0.00]
1964 Ford Mustang  [0.00]
1968 Pontiac GTO  [0.00]
None of the above. Buy a S9 and plug it in when you want heat and at least make some money when you're mining.
Oy vey, look at all these shekels
      03-04-2022, 09:53 AM   #8
grannyknot
grannyknot's Avatar
1011
Drives: 2008 Z4M coupe
As mentioned above, insulation is the best bang for your buck. Light bulbs are an inefficient to heat a space, you would be better off using that electricity to power an oil heater.
Natural gas and propane are still the cheapest sources of power, I use an 8ft propane fired infra red tube heater on the ceiling with a small fan mounted in front of it to circulate the heated air around the shop.
I also glued 1/4" plywood to the concrete floor and that really helps knock the cold down.
On the really cold days I pull out the BBQ propane tank and fire up the convection heater, 15 min of that and the place is toasty warm.
I have so many cracks and gaps in my old garage that fresh air exchange is never a problem.
2008 E86 M coupe
      03-04-2022, 07:47 PM   #9
zx10guy
Drives: 2013 135i
I got a 3000W electric heater and installed it in the ceiling of my garage. Fortunately, the main electrical panel is along that same wall in the garage. So I have a 30A 220V breaker feeding power to the heater. I decided to do some redneck engineering and used a baseboard heater thermostat to allow me to turn on and off the heater from ground level. It's also nice I can set the temperature and forget it. The heater has a fan to blow the air through the heating elements. It can warm up my 2 car garage in the dead of winter within about 10 to 15 minutes.
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
