03-04-2022, 11:03 AM | #1 |
Rep 1,082
IX Range - Tire Size
It seems when getting the sport package you can't select the highest range tire size (20" - 324miles).
If you go with 21" (default included with sport package) you lose 19 miles 5.8% (Range 305 miles). If you go with 22" you lose 9 miles 2.7% (Range 315 miles). The 22's would seem the way to go but only come in performance tires not all seasons. Has anyone heard anything about all seasons or winter tires affecting range on the 22"? If so, may just go with the 21". What are others doing? |
03-04-2022, 11:25 AM | #2 |
Rep 4,530
Drives: 2022 iX xDrive50, DGM
22" are more expensive, sometimes harder to find and have fewer varieties (as you point out, no AS, at least readily available). On a normal car, 22" are for looks, not for substantial performance improvements - a difference of 10 miles range is not significant. The most practical choice is 20", but not available for the Sport package (a 20 mile difference becomes more important). I'm not hung up on the size of my tires for optics - I don't actually see them while driving. And yes, even different tread will impact range I imagine. I picked 21" because it was essentially all there was for AS.
03-04-2022, 10:42 PM | #3 |
Rep 200
I went 22" because of the range penalty on the 21" and also for the looks. Not the size, but the wheel design. The range thing is more of an excuse to be honest ;-) Being in Canada I always make the seasonal change to winter tires so performance tires on the 22" work for me. I'll likely go with a 20" wheel package for winter. My SA told me that my X5's winter wheels won't work on the IX because they changed the bolt pattern. Seems like a shyte thing for them to do. Has anyone else heard the same or can anyone confirm the bolt pattern change?
TechCTU786.50 |
03-05-2022, 07:31 AM | #4 | |
Rep 1,082
03-05-2022, 08:11 AM | #5 | ||||
Rep 200
TechCTU786.50 |
03-05-2022, 08:29 AM | #6 |
Rep 1,082
Looks like Tire rack has the ix 50 listed now. They have all 3 sizes listed in performance, all season and winter.
Is there anything preventing 20" wheels with the sport package? Is there an issue with the brake caliper clearance? Or is it just cosmetic? |
03-05-2022, 09:29 AM | #7 |
Rep 200
I believe 20" are OK for everything except the M60 where you need 21" minimum. If you look at the pic I posted above, it shows the 20" wheels with blue (ie sport package) calipers and specifically states the 20" don't fit the M60. No such disclaimer for Sport package. No disclaimer for 21". But I also observe that the tire in the 21" pic is a Michelin while the description states Goodyear, so probably best to confirm with your dealership's parts department.
TechCTU786.50 |
03-05-2022, 12:51 PM | #8 | |
Rep 1,978
I played around a little at willtheyfit.com and they don't seem to be too far off in terms of fitment compared to X5 standard sizes, but they are not identical. The iX wheel/tires are a little taller overall so depending on the exact sizes you got on your winter wheels and tires for the X5 this may fall within the range of acceptable differences. Maybe the tires won't be ok, but I didn't see anything that would suggest that the wheels would not be reusable. I would however say that you should definitely talk to a good tire/wheel shop as I am 100% not an expert in this area.... surely don't trust an SA for this kind of info. |
03-15-2022, 11:46 AM | #9 |
Rep 153
Just heard direct from a dealer that just had training from BMW HQ on the iX that the range penalty for the 22” rims is 100miles…. Makes sense since on a Tesla the penalty is about 50miles for 21”
Also I have a black on black iX50 coming. First one my dealer gets. |
03-15-2022, 11:56 AM | #10 | |
Rep 200
03-15-2022, 01:38 PM | #11 | |
Rep 1,978
(you can use the german site to see these numbers) The US site using EPA numbers shows 20" gets you 324 miles, 21" gets you 305 miles, and the 22" magically get you 315 miles. So whoever told you there is a 100 mile penalty is full of crap. |
03-15-2022, 02:30 PM | #12 | |
Rep 1,082
I suspect because the 22" tires weigh less and are summer only in US market. |
03-15-2022, 03:04 PM | #13 | ||
Rep 200
03-15-2022, 03:50 PM | #14 | |
Rep 4,530
03-20-2022, 10:55 PM | #15 |
Rep 380
08-08-2022, 11:14 AM | #17 |
Rep 25
With 21" iX50 Sport package I get the following real range (Highway driving 110-120 km/h, careful, efficient mode):
Summer (20 degrees C): 520 km or 325 miles (zero SOC left at stop) Winter (just above freezing, 0-2 degrees C: 430 km or 268 miles Had a flat tire and had to wait a couple of weeks for a spare so had to use 20" winter-tires on a few longer trips. They reduce 30km (18,7 miles) of highway range in summer time. |
TechCTU786.50 |
08-08-2022, 03:37 PM | #18 | |
Rep 339
Driving an iX 40 loaner with 22 inch and it is more economical on my home work travel than my Model x with 20 inch 8.5 kw versus 6.5 for th iX I was not expecting this … |
08-09-2022, 04:19 PM | #19 | |
Rep 7
The 22s are very summer only tires though, I will be swapping to winters earlier than in the past as I don't want to find out what it's like driving on these in snow. |
08-10-2022, 08:52 AM | #20 | |
Rep 42
So I went with the sports package and 22” wheels… |
TechCTU786.50 |
08-10-2022, 10:12 AM | #21 | |
Rep 1,082
08-10-2022, 10:46 AM | #22 | |
Rep 595
Drives: F15 X5 50i, G30 M550i, iX 50i
