03-07-2022, 01:21 AM | #1 |
Rep 12
Am I too low for xDrive?
I just got KW Street Comfort Coilovers installed on my 328i yesterday, and while I enjoy the drop, I don't want to mess anything up as I've had a friend mess up his transfer case because he went too low. I'm also worried I may mess up my axles.
Here is a picture of the car as it is now: View post on imgur.com According to the person who installed it, it is a 2.0 drop in the front and 1.75 in the rear. From center cap to fender, it is 12.5 all around. Last edited by ChrisF3x; 03-07-2022 at 01:23 AM.. Reason: Picture not showing |
03-07-2022, 01:52 PM | #2 |
Rep 320
transfer case would only be a concern if you are running different diameter tires front and rear.
you have some latitude for lowering. I am lowered over 1.5" and have been for several years. axles and transfer case are still in good shape. i opened my transfer case a couple of years ago and aside from the cheap plastic, everything looked good. |
03-07-2022, 05:33 PM | #4 |
Rep 3,361
Whenever you mod, there is always a risk. That said, there are a lot of bros with slammed x-drives doing just fine on stock turbo level power. It's the high hp slammed crew breaking the slightly more stressed components. the 1.5' thing is more of a guideline vs. hard rule.
e30 4 life!118.50 |
03-07-2022, 07:38 PM | #5 | |
Rep 5,412
Drives: 2015 BMW 335i x-Drive Auto
If you look at the XDrive drops quoted by aftermarket spring makers they don't like to go over 1.5". More than that they must know that they are risking liability. It's the front driveshafts that can snap if an xDrive is lowered too much. It's a shame that you didn't measure first so that you'd know your starting point Great choice with the KW coilovers! Best ride! |
cfm56d7b5948.50 |
03-07-2022, 11:42 PM | #6 |
Rep 4,380
this is a good read...
https://f30.bimmerpost.com/forums/sh....php?t=1514736 i've read enough threads and posts about front half shafts/axles and lowering x-drives, that i'd follow the 38mm guideline if i was planning to. |
03-08-2022, 12:16 PM | #7 |
Rep 12
So essentially, xDrives can't be lowered more than 3 inches? If so i'm only lowered 2 inches in the front so I should be fine. I also am not tuning my car and don't do launches so that also shouldn't be an issue.
03-08-2022, 12:56 PM | #8 | |
Rep 12
03-08-2022, 12:58 PM | #9 | |
Rep 10,322
KW Street Comfort coilovers: a great choice indeed. I had these coilovers on the previous vehicle. About lowering range - it's a question of how much risk you are willing to consider. Anything less than 1.5" will carry less risk. If the vehicle has a tune, then the risk of front drive shafts failing with lowered suspension increases considerably. |
johnung4552.50 |
03-08-2022, 01:27 PM | #10 | ||
Rep 5,412
https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
03-08-2022, 03:09 PM | #11 | |
Rep 12
So I should raise the front by a half inch? I’ll try and get some better pics of the car’s height and post them. |
03-08-2022, 03:35 PM | #12 | |
Rep 5,412
So you should recheck those 12.5" measurements. My car would be sitting on its tires. The stock tire diameter is 26.0" or 13.0" diameter so 12.5" really doesn't sound right. Also you can find the same model at local used car lots and see what they measure stock. |
03-08-2022, 04:08 PM | #13 | |
Rep 12
03-08-2022, 04:17 PM | #14 | ||
Rep 5,412
ChrisF3x2.50 |
03-08-2022, 04:27 PM | #15 |
Rep 12
03-08-2022, 05:04 PM | #16 | |
Rep 12
So it should be a 1.75" drop in the front and 1.625" drop in the rear. Last edited by ChrisF3x; 03-08-2022 at 05:15 PM.. |
03-08-2022, 06:08 PM | #17 | ||
Rep 5,412
How do like the ride on the KWs? I believe the Street Comforts are adjustable. Where in the range did he set them? |
03-10-2022, 02:27 PM | #18 |
Rep 12
Sorry for not replying, was very busy the past couple days, but the very first night I drove it after getting it installed was very stiff and not comfortable at all. After about 2 days though it started to get a lot more comfortable. I don't know if that's just because I got used to it or the settings the installer put or if the suspension just settled but it's very close to stock feel. I saw you mentioned that you had these same coils on a car before, would you mind sharing what settings you had, I might give them a go.
03-11-2022, 09:10 PM | #19 | |
Rep 5,412
03-27-2022, 11:49 PM | #20 |
Great Teacher
1139
Rep 1,320
Drives: 06 e91 325ix
I’m running 1.5” down exactly in the front and 1” down in the rear. Either the rake ruined the aerodynamics or the shafts are more draggy in this position as I lost several mpg freeway.
Have considered raising the fronts 0.25 (couple minute by hand once up on jack) also considered dropping the rear 0.25” to take some rake out. Rear one is more a pain because right now I’m running the supplied kw adjuster spacers, and am full down on adjusters… so to go lower I have to disassemble the rear suspension and take the spacers out and raise the adjusters back up to just below where the spacers were.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
04-18-2022, 10:31 PM | #21 |
Rep 1,372
1.75" seems a tiny bit low. If it was my car I'd go with the popular 1.5" as a lot of forum users on lowered suspension are at this range and have been running their cars for years with no issues.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
04-22-2022, 11:00 AM | #22 |
Rep 317
I'd say you're fine at that height. I can measure my heights and let you know where I'm at with my KW V1s. Been on this setup for over 10k mi. Front has a finger gap, rear has no gap
I haven't noticed any issues besides maybe having very mild bump steer when giving it the beans coming out of a turn. This can be corrected with roll center correcting tie rod ends Last edited by squaredphoto; 04-22-2022 at 09:02 PM.. |
