320d no heat please help
03-07-2022, 02:27 PM | #1 |
Rep 10
Hello, I've tried many forums and Facebook and still don't get much help..
so i have a BMW 320D PRE LCI, 2006 (m47n2) uk. my problem is that i get little heat on the passenger side and freezing cold on drivers side. I've changed my thermostat(Circoli) and water pump(Circoli) last April thinking it was maybe my thermostat stuck open... didn't resolve the problem. I've blanked the egr+cooler off and installed a new radiator too. I've change the coolant, back flushed the heater matrix, and checked the blend doors to see if they're moving when spinning the dual climate control dials which they were moving. I went into the hidden menu to check the coolant temperature and it stay around 86 - 89 °C. I've tried to do the 12m bleed procedure on my car but it doesn't work..., I'm not sure if my car has the electric water pump or not but I've done the steps correct and get nothing. i took my friends car out earlier he has exact same car and his vents were blowing hot air from 45°C. so i am really lost on what to try next. please give me some other advice what to try because its cold over here in the uk, thanks will upload links to videos taken on temperature. |
03-08-2022, 01:20 AM | #2 |
Rep 291
Dont use Circoli stats.... Absolute trash!!. I had to swap out one after only 1 weeks use as it had failed and stuck open!!. Only use genuine BMW stats as all aftermarket ones seem to be inferior quality.
Electric water pump not fitted to your car either.. |
03-08-2022, 10:31 AM | #3 |
Rep 4,108
As you appear to know, you SHOULD get heat with 70+C coolant temp. However, that requires actual coolant flow THROUGH
the Heater Matrix, AND direction of cabin air THROUGH the hot heater matrix. IF the "Hidden Menu 7.00" readout shown on your Instrument cluster is correct (confirm with Infrared thermometer aimed at ECTS location), then the FIRST thing to check is that the "Water Valve" (Y4a) is open. Attached is an ISTA ScreenPrint of the Water Valve wiring diagram (SSP) and the Location of the Valve (Y4a). That is a simple Solenoid Valve which opens or closes by application of 12V+ to Pin #1, Yellow/Brown wire, and Ground to Pin#2, Brown wire. Also attached is screenprint of SAME circuit with "Connector View" of X85, the Two-pin connector at the Water Valve. If Water Valve is opening to allow coolant flow, then either the heater matrix is clogged, preventing flow, OR the "Mixed Air Flaps" which direct cabin air through the heater matrix, or NOT when A/C required, may have issues. INPA or ISTA would allow quick diagnosis of Water Valve & Flap Positions/ movement, but you CAN do it with nothing more than a multimeter and some patch cables IF you understand the system. George |
03-09-2022, 12:11 PM | #4 |
Rep 10
it must be working though due to getting heat from passenger side vents, i will not use circoli in future, thank you for feedback
03-09-2022, 12:22 PM | #5 | |
Rep 10
i know i have the m47n2 engine but the picture u provided is different to i mine only have one soliniod thing on my water valave not 2 like in the picture and it has an impella inside of it. i even disconnected the wire so its always open but still get 1 side hot and 1 side cold, i can take a pic of engine bay if u want to see Last edited by i7iQs; 03-09-2022 at 01:02 PM.. |
03-09-2022, 01:54 PM | #6 |
Rep 248
Isn't that auxilliary circulation pump?
There is a rest button in climate control and when engine is warm but turned off it activates that pump to recirculate coolant to keep cabin warm. I've used it when waiting for someone and it's too cold outside (engine off) but it has lousy brushes that don't last very long. Looks like your center flaps(or one of the flaps) are stuck in one position. BMW uses some nasty black stuff to seal flaps in closed position and in colder period it is not as elastic and gets stuck = flaps that control airflow cannot control the flap. I had similar problem where it would not produce hot even thou engine was 88C (it was showing a flap error). Only blowing slightly warm from both sides. The flap motor was not the problem as i could not even move the flap with screwdriver (while motor was removed). I just scraped off some of the "sealant/glue" and then flap motor could open/close on it's own. It's rather simple procedure, removing center trim to gain access to center flap. Then you can visually see them work or not working. Since only one side is blowing warm air i would suspect flaps problem. In my case the second flap from the left was problematic that should allow air to pass through the hot interior radiator. Last edited by Captain Buumer; 03-09-2022 at 02:19 PM.. |
03-09-2022, 03:03 PM | #7 | |
Rep 10
thank you for your info! |
03-09-2022, 06:14 PM | #8 | |
Rep 4,108
INPA > IHKA (Body | Air Conditioning / Control Panel) > F5 Status > F4 Flap Positions It also allows you to Control (Attempt to Control ;-) the Water Valve: INPA > JBE/JBBF > F6 Activations > F4 Water Valve > F3/F4 On/OFF Those are the Menu Sequences for my 3/2007 build 328xi E91 with "IHKA87" Climate Control Module, and with "JBBF87" JBE/JBBF Module. In each case, you have to connect to the Module which controls the device to be monitored or activated. The Flap Motors are connected to/controlled by the IHKA Module, and the Water Valve is connected to/controlled by the JBE/JBBF Module. If you have issues with INPA setup, there are some clues in the attached pdf: "INPA Tutorial Quickstart", which also shows how to quickly use "Functional Jobs" to get quick overview of Modules and Fault Codes, how to Setup your K+DCAN Cable, and how to save ScreenPrints for future reference. George |
03-09-2022, 11:24 PM | #9 | |
Rep 2,777
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
03-10-2022, 06:31 AM | #10 | ||||
Rep 10
03-10-2022, 08:56 AM | #11 | |
Rep 2,777
but it also can help when you do bleeding
03-10-2022, 11:29 AM | #12 | |||
Rep 10
Hi guys, I'm on inpa rn playing around. Can you check out this video please. https://youtube.com/shorts/S07g5r36FIY?feature=share Anything you need me to try on inpa or ista I can do thanks I think it's the stepper motor on the dash video below. https://youtube.com/shorts/1RMybre68RQ?feature=share |
03-11-2022, 08:04 AM | #14 |
Rep 2,777
replace heater core you mean, because for whole heater dashboard should be removed definitely
03-11-2022, 12:52 PM | #15 | ||
Rep 34
But you don't have to remove the whole dash, as I said. I was able to replace it by removing the steering column, had just enough space to reach it. |
