bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      03-13-2022, 08:51 PM   #1
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
Steering Intervention updated - not good
One of the most annoying features in the so called "Intelligent Safety Systems" is steering intervention under lane keeping.
The checkbox for this kept your setting in memory so turning if off would keep it off but now it comes on each ignition cycle.
From a conversation with a Master Tech this is as a result of an update from BMW in the later firmware revision.
As a result we need to turn to Bimmercode and I’m sure it will need to be done in expert mode
Does anyone know the code for this either to add it to memory setting between ignition cycles (like the stop start) or maybe change the speed at which it comes in
Hope there’s a solution out there, maybe Bimmercode might include it in the next update
      03-14-2022, 08:05 AM   #2
jga2022
Belgium
30
Drives: BMW G42 M240i 2022
I totally agree, this is very annoying, I hope to be able to turn this off permanently
      03-14-2022, 03:00 PM   #3
jpcoop
Drives: 2022 M240i xDrive
Huh? What software version? I turned this off the day I bought the car and it has stayed that way since
      03-14-2022, 03:05 PM   #4
P_Chris
P_Chris's Avatar
157
Drives: 2022 M240i
2022 M240i  [0.00]
Same here.
2022 M240i
      03-14-2022, 03:20 PM   #5
DaveDee
DaveDee's Avatar
532
Might be one of 2 possibilities
It's regional
or
Yours might be a pre November version of the firmware. I was advised yesterday by a BMW Senior Tech that BMW have now changed this setting in all new firmware.
      03-14-2022, 04:51 PM   #6
Vudumonkey25
Vudumonkey25's Avatar
Drives: BMW M240i x Mercedes CLS550
Is it possible your under a guest key and not your profile?
Mines been off since day 1. November pick up
It remembers everything.
I really hope a new firmware doesn't change that
      03-14-2022, 04:57 PM   #7
DaveDee
DaveDee's Avatar
532
It might be regional but I suspect not. The firmware I have was late November and there’s another just been released.
Bimmercode has not released an update for a while so here’s hoping it might be included in the new update, I saw similar posts in the G20 forums, some have it in memory others don’t
I had a M235i before this and it retained the setting between ignition cycles
Bimmercode is really the best answer, and hopefully will bring official support for the BMW G42in the next release
      03-14-2022, 05:26 PM   #8
DaveDee
DaveDee's Avatar
532
Just for comparison my Firmware version is : 11/ 2021.61
      03-14-2022, 09:21 PM   #9
xcelir8bmw
xcelir8bmw's Avatar
Drives: 2022 BMW M240ix
Mine is off from day 1 and I see no Bimmercode options.
      03-14-2022, 09:34 PM   #10
jpcoop
I’ll check next time I’m in the car but I’m 97% sure it’s older than that (I took delivery in early December)
      03-15-2022, 08:11 AM   #11
Vudumonkey25
Checked my firmware it's 07/2021.55
      03-15-2022, 08:47 AM   #12
P_Chris
P_Chris's Avatar
157
Drives: 2022 M240i
2022 M240i  [0.00]
I have 11/2021.61 and it stays off.
2022 M240i
      03-15-2022, 02:38 PM   #13
DaveDee
DaveDee's Avatar
532
If that's the case it could be regional, good news for USA and users of Bimmercode. Should be an easy fix if it is regional
Thanks for that info
      03-16-2022, 04:13 PM   #14
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
If you can't turn it off, try turning down the intensity, that helps a lot.
      03-16-2022, 04:42 PM   #15
DaveDee
DaveDee's Avatar
532
Thanks for that, yes I’ve done that.
Been onto Stephen at Bimmercode too, I hope it doesn’t filter across to you guys too.
We have a few things like that on Right Hand drive cars, Stop start (which fortunately can be coded out) I think because of odd legislation they have in the UK other RHD countries inherit the coding for those countries as our market is nowhere the size of the US market
      06-18-2022, 07:08 PM   #16
Evilmoretea
Drives: BMW 2 Series (G42)
As a result we need to turn to Bimmercode and I'm sure it will need to be done in expert mode
Hope there's a solution out there, maybe Bimmercode might include it in the next update
Any update on this. Just picked Uk my car today and hate that I can't have the steering intervention save as off under individual!
      06-19-2022, 12:45 AM   #17
allfitat55
Australia
121
Drives: 2022 M240i
2022 BMW M240i  [0.00]
Ditto on this Aus region mine resets on Inginion restart. I was doing a BMW club drive went to take the 1st corner and the steering intervened stuffing that corner. I really don't want this muscle memory where need to remember to turn it off every time I start the car.
      06-19-2022, 12:56 AM   #18
DaveDee
DaveDee's Avatar
532
I’ve contacted BMW on this and even suggested it could cause a danger to cyclists when you cross a line to give them space, the car could correct right back into them but they didn’t see the funny side and are standing firm on keeping it in according to a BMW Tech I know
Given it’s still selectable to memory in USA it will be a regional thing so I’m sure there’s a solution.
Bimmercode have not indicated interest but there could be a local coding solution and I’ll follow through on that.
      06-19-2022, 06:08 AM   #19
allfitat55
Australia
121
Drives: 2022 M240i
Let me know if you need any help pretty Geeky being in the IT industry. happy to help test and dev
DaveDee532.00
      06-19-2022, 06:13 AM   #20
DaveDee
DaveDee's Avatar
532
Thank you I'm sure it will be in the advanced area in Bimmercode as you have access to pretty much everything there that is editable. I'm not in that level of IT but I'm sure there are a few who can do that. One of our friends here is an Aircraft Engineer and coder and the go to guy for difficult stuff like that so I'm going to ask him to have a look and see what happens.
If it can be done with stop start and other menus it's just a matter of knowing where to look
      06-19-2022, 04:38 PM   #21
allfitat55
Australia
121
Drives: 2022 M240i
Look like the G20 owners are getting it done via BMW with OTA pending. Not sure if this will filter down to G42 or our region. https://g20.bimmerpost.com/forums/sh...1755297&page=5
      06-20-2022, 05:19 AM   #22
bmwloverm2
Drives: BMW M240i 2022
Got my G42 on friday and I can confirm this is happening to me too.
And i confirm this is ANNOYING AF... each time i forgot to disable it, i have to disable it after it acts while i'm driving, so i have to disable it during the drive which i hate it....
g87
