VTT Crankcase breather. oil turning milky
03-14-2022, 03:54 PM | #1 |
Rep 64
To begin, no my head gaskets not blown lol. I worried when I seen this, instantly drained the oil to find it perfectly clean from both the oil pan and OFH.
Now… I notice it appears that oil is leaking from the actual oil cap (the crank case breather) and dripping down past my injectors, onto the motor. You can see the wetness from around the crankcase breather and where it leaks. In this case it makes sense. Water vapour must be getting past the breather into the oil, creating the milkyness, all while oil leaks out. Has anyone experienced this with the VTT crank case breather? |
03-14-2022, 05:45 PM | #2 | |
Rep 3,219
03-14-2022, 05:55 PM | #3 |
Rep 3,732
I never understood why people insist on messing with the OEM PCV setups on these cars. As shown in this thread.....people cause more bad than good by tinkering with stuff.. As long as it's in good working order, the OEM BMW setup works great !
A new valve cover, OEM flapper valve, and RB PCV valve is all you need.....it works great. Now if you are making 700+HP and 30psi boost....then it's time to start modifying the OEM PCV system. |
03-14-2022, 06:33 PM | #4 | |
Rep 64
03-14-2022, 08:34 PM | #5 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Like all VTT products. Shit.
Also, as said above a correctly functioning VC + rb pcv valve should be plenty for most. You want to go all out, block the head ports, dual catch cans, add both low and high side vacuum, etc. but it costs a good deal and is not needed for 'most' people. How much you want to spend on your PCV system which likely works just fine is up to anyone. You don't have to 100% externalize it.
Navykiller68.00 |
03-14-2022, 08:52 PM | #6 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Good lord put a disclaimer up next time I got physically sick seeing this.
I would also ship this back to VTT, refund or not, in the exact condition you have it in now. Just because.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
03-14-2022, 09:00 PM | #7 | |
Slow.
3782
Rep 7,152
Ask Tony if he still beats women while you are at it and why Chris defends him a simple google search will show his arrest record etc.
03-15-2022, 07:13 AM | #8 |
Rep 1,165
Drives: 09 E92 335i 6MT
OP, put a time frame on your daily commute. Is it less than ~30min one way?
If so, the build up is normal. It becomes exacerbated by these caps. I'm not one to defend VTT, but it's simple why this is happening. You're going to end up with more of this stuff with any kind of oil breather cap. The more cold air touches it, the more buildup you're going to get. This doesn't happen as badly with the stock cap because it has no breather element. Solution is to return the breather cap or start driving for longer periods.
09 E92 335i 6MT / Alpine White / Coral Red / VRSF 7.5" / VRSF DCI / VRSF Catless Downpipes / VTT Charge Pipe / Turbosmart RacePort Gen V / RB OEM Billet Turbos / CD919 Custom Tune / Bilstein PSS9s
Torgus3781.50 |
03-15-2022, 09:55 AM | #10 |
Rep 64
Lmfao believe me, when I opened the oil cap, I basically shit myself. I was in shock. I was happy to see the oil drain nicely tho but man was this disgusting… I contacted them, let's see what they say
03-15-2022, 09:58 AM | #11 | |
Rep 64
Dave92N54530.00 |
03-15-2022, 09:59 AM | #12 |
Rep 64
05-31-2022, 07:17 PM | #13 |
Rep 630
Drives: '09 335 E93 6MT
I'm maybe late to the party, but you checked that your oil filter housing gasket is not mixing coolant and oil?
....if its already been repaired, could be left over coolant from previous gasket failure
Convertible | Manual | M-Sport | MHD Stage 1 + FMIC | 335is Clutch | ER CP | RB Inlets | VRSF 5" Stepped FMIC | M3 F/R Control Arms | KW V3 | Hawk HPS Pads | Stoptech Slotted Rotors | Blackvue DR650-2CH Dash Cam | LCI Taillights
