BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography D80 is broken, fix or replace?
      12-04-2008, 01:42 PM   #1
Sniz
Sniz's Avatar
710
Drives: e92 335 - gone // e36 M3 turbo
not sure what is happening, but my D80 starting having a very laggy shutter during a cold day of shooting, then started falshing a 'ERR' message and the shutter is pinned shut. If I look through the viewfinder, all I see is black, and yes my lens cap is off!
I need to find out how much it would cost to fix, or should I just replace it?
      12-04-2008, 03:26 PM   #2
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Drives: SGM E92 335i, AM E90 335i
I'm assuming the warranty is past due. You should find out if Nikon would take a look at it before they fix it? Or I can recommend searching on a Nikon forum, it might be a common issue. gl!
      12-04-2008, 11:15 PM   #3
Subw00er
Bates '08 Interlagos Launch
Subw00er's Avatar
Drives: 440i xGC, ZL1, JCW
get a d60. The software/interface in the d80 is behind now. I have a d40x and a d80 and I only use the d40x (d60 is the new version).
      12-04-2008, 11:33 PM   #4
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
I'm not sure if he'd ever be able to get used to the dinkyness of the d60. Its so small, smaller than a Xti and those are tiny compared to my 40d.
      12-05-2008, 01:34 AM   #5
kuvesh
kuvesh's Avatar
Singapore
26
Drives: e92 335i juiced
if under warranty, get it repaired.
if not, get the d90. it can also take video.
HAMANN FRONT APRON, SIDES, ROOF SPOILER & QUAD DIFFUSER | VORSTEINER VRS TRUNK | CSC3 ON 19” ADVAN RS | BREMBO GT BBK | BASTUCK QUAD | KW V2 | JB3 v1.3s beta | BMW PERFORMANCE STEERING WHEEL | M3 SIDE MIRRORS | M5 SMG SHIFT KNOB | BLACKOUT GRILLS | PARTIALLY SMOKED LIGHTS | WINDOW TINT
      12-05-2008, 01:48 AM   #6
TWiTCHY
TWiTCHY's Avatar
Drives: '13 AW E92 M3
Get it fixed if you're worried about not being able to use your older lenses on a newer Nikon. If you don't own any "old lenses" then I would go ahead and replace it.
Older lenses' autofocus sometimes don't work on the newer D60. I'm not sure if the compatibility issue was fixed on the D90.
      12-05-2008, 05:24 PM   #7
Sniz
Sniz's Avatar
710
if I get a new body it will be the d300 or d700 <3
      12-06-2008, 07:09 PM   #8
The_Blob
The_Blob's Avatar
512
Drives: 2008 E92 335i
Have you ever dropped the camera? Fixing the camera is expensive, it's better to buy a new one.
      12-07-2008, 05:06 AM   #9
Big Windy
Big Windy's Avatar
Drives: None
if the warranty is up, replace. D90 or D300.
      12-17-2008, 11:05 AM   #10
Alarbus
Drives: '15 F30 & '19 F36
All Nikon lenses should work, the only issue would be that you can't put a Dx lens on a film camera. Nikon's product continuity is unparalleled.
The downside with digital cameras is that it's very rarely worth it to repair. If you look at the body only option from some place like B&H or Adorama, it'd probably be a wash.
      12-30-2008, 12:34 PM   #11
Sniz
Sniz's Avatar
710
thats what i'm thinking, sucks.......not really in the budget these days to buy a 1 - 2 grand body.
      12-30-2008, 12:41 PM   #12
jpsum
jpsum's Avatar
Drives: 2010 TSX
How many actuations does your D60 have so far? It might just need a new shutter.
The shutter should last at least 50,000 actuations.
      12-30-2008, 02:32 PM   #13
Sniz
Sniz's Avatar
710
its a D80, and for some reason the darned thing started working today! hit the reset in the menu and then hit the shutter release and presto.....it works!
We'll see how long it takes to break this time.
