03-27-2022, 07:32 AM | #1 |
Rep 95
Ordered Hawk 5.0 front pads but they don't have the little holding arms...
So I ordered these front pads from Tirerack at this forums suggestion, but they don't have the little arms that the spring holds onto. However; they do have the small holes implying that there are to be arms mounted to them. I haven't found any of the arms for sale anywhere. Was I supposed to remove them from the old pads? Did I order the wrong pads?
03-27-2022, 10:32 AM | #3 |
Rep 95
do the non-M front brakes appear very similar but without the "things" -- I may have just been dumb and not ordered the correct pads. Its somehow difficult Since my calipers are gray. I assumed those to be the non-m, not realizing that they are in fact the dual piston Ms?
Yeah these are what I ordered: https://www.ecstuning.com/b-hawk-par...hb765b.664~hk/ On Tirerack they fit my car, on ECS they do not. Edit pt2: I'm unable to find these at any reasonable cost. Are they ~$350 for front pads alone or am is there a gas leak in my house? I'm leaning towards the latter as there is no possible way pads for the street can be so expensive. https://www.ecstuning.com/b-hawk-par.../hb765b.664kt/ I may just have to have Hawk 5.0 for my rears and something completely different in the front. That's disappointing. Last edited by GENAU; 03-27-2022 at 10:49 AM.. |
03-27-2022, 11:18 PM | #6 |
Great Teacher
1139
Rep 1,320
Drives: 06 e91 325ix
From what I have seen online, hawk don’t ever have the counterweights. Hope that helps
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
1bad14-F3030.50 |
03-29-2022, 07:31 AM | #7 | |
Rep 95
They do make them but they're crazy expensive. |
03-29-2022, 07:51 AM | #8 |
Rep 16,199
That's not unusual. I get the OEM part number at realoem.com. I plug that in at the website for the manufacturer I'm interested in to get their part number, then google that part number to find the seller with the lowest price.
03-29-2022, 11:00 AM | #9 | |
Rep 895
AFAIK, the fronts fit either the grey or blue Brembos, but there’s a different rear set for grey vs blue. I have no idea why you’re finding these Hawk 5.0 street pads without the arms attached. I thought only the Hawk race pads were sold without arms. |
04-03-2022, 06:42 AM | #10 |
Rep 95
I don't entirely blame them for it either to be honest. I guess that I have the two piston M-sport front brakes, but the standard rear brakes? Technically they could have been right and this would have been correct for a 440ix with "standard" front brakes? I'm honestly lost on what is standard and M-sport at this point. I thought having the front and rear gray calipers meant I had standard single piston front brakes but I guess that wasn't true.
06-08-2023, 12:49 AM | #11 | |
Rep 6
Drives: 2019 BMW 440i Xdrive GC
I have the same part number hawk 5.0 pads and plan on doing the install Friday however I just noticed they don't have the counter weights. Did they work for you? I have the 370mm front disks with blue 4 pistons brembo |
10-02-2023, 11:23 PM | #12 |
Rep 440
Drives: 2014 435i
Just as a refresh I had the same issue. Tire rack recommended pads to me, 765B.664, same ones recommended on the forum but no counter weights.. so confusing. They are same size, fit in the calipers but are lacking those arms and can’t fit the rattle clip as a result too.
INSTA: roxy_F32
10-11-2023, 12:13 PM | #13 | |
Rep 54
10-11-2023, 09:59 PM | #14 |
Rep 1,372
Hawk expensive? My oh my. So innocent.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
10-11-2023, 10:04 PM | #15 | |
Rep 1,372
10-11-2023, 10:28 PM | #16 | |
Rep 54
10-15-2023, 01:30 PM | #17 | |
Rep 1,372
I used the purple before but ended up switching to orange. I can't recall purple being bad but orange definitely worked and I've stuck with it since. I'm not a pro so I will pretty much follow anything that looks like official instructions. BMW illustrates a circle of grease on the backing plate for each piston and a little bit on the top and bottom of the backing plate to allow it to freely move back and forth horizontally. To the best of your ability clean the edges of the caliper where the pad will touch the caliper (top and bottom). As for the 'Slather the complete sh*t out of the pad with grease' method, do not do that. The grease is both helper and harmer of the problem. Great for reducing friction but also wonderful for capturing brake dust and other road crap, which lowers friction. One last thing. When was the last time you change the retainer clip? BMW says 4 years. Good luck.
10-16-2023, 12:19 PM | #18 | |
Rep 54
Tags |
brake pads, hawk 5.0 |
