03-28-2022, 08:51 PM | #1 |
Rep 14,143
Drives: G82 M4C X-Drive
G82 with a Lightweight Front Splitter installed
I don't believe I've seen too many G8X's with the Lightweight Front Lip, so here is mine, installed today at EAS!
I decided to go with the Lightweight due to the cost of replacement, durability, and corner clearance for my steep driveway. I previously had an F80 M3 CS that constantly scrapped the corners going up my driveway. I've also had to replace it due to going off the road on the track, so hopefully off-track excursions will be less painful! It's not as flashy and fancy as most other aftermarket front lips, but I like it's clean, subtle design that still provides some aero advantages, that hopefully works well to increase airflow efficiency under the car. As with most proper front lips, the undercarriage factory spoiler under the factory front lip is removed to facilitate installation, and decrease airflow resistance.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 03-28-2022 at 11:35 PM.. |
9
03-29-2022, 09:11 PM | #3 |
Rep 14,143
Thanks! I stopped tinting my cars years ago, I prefer letting the light in!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
M4Tejas846.00 |
03-29-2022, 11:11 PM | #4 |
Rep 101
Where did you get it from? I was checking this one before since is black and my cara doesn't have the carbon fiber package. I know the brand is in europe, right?
03-29-2022, 11:15 PM | #5 | |
Rep 14,143
03-29-2022, 11:18 PM | #6 | ||
Rep 101
jmg18872.00 |
04-01-2022, 12:55 PM | #8 |
BimmerPost Supporting Vendor
8300
Rep 18,868
Here's a shot of the underside if the Lightweight lip, only slight trimming of the rubber seal is needed - no drilling or cutting.
Should also work with most oil cooler guards as well, we'll start test-fitting as soon as we get the Turner units in stock.
04-01-2022, 01:00 PM | #10 |
8300
Rep 18,868
GoodGuyAvi1500.50 jmg18872.00 M4Tejas846.00 nathanm4684.50 Laguna01///M31400.50 manuelf353.50 JTO245279.00 SwissMTNAlien236.50 |
04-01-2022, 09:15 PM | #12 |
Rep 435
I was able to fit it with fall line oil cooler guard.
04-05-2022, 09:09 AM | #13 |
never could compete with Lloyd Braun
5279
Rep 5,387
Looks good! I have zero CF on my car so I'm thinking of maybe going with something like this instead of going down the rabbit hole of a CF front lip, then inlets and diffuser etc.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
jmg18872.00 |
04-08-2022, 05:22 PM | #16 | |
8300
Rep 18,868
The ABS plastic construction is nearly indestructible. Here's a video of installation, definitely DIY:
jmg18872.00 Tall Tom Cruise1013.50 |
04-08-2022, 05:31 PM | #17 | ||
Rep 14,143
I want to assume their products are track tested, but again, that's just words. I've reached out to them to provide more insight as I too am curious!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 04-08-2022 at 05:39 PM.. |
04-09-2022, 09:21 AM | #18 |
24477
Rep 191,451
Looks good
04-13-2022, 07:53 PM | #19 |
Rep 212
Question
From the installation video, it seems rubber spacers angle the front edge of the splitter downward, and it leaves an opening, while the trailing edge is buttoned-up tight to the bumper cover. If that's the case, what happens to leaves and other debris that find their way into that opening?
I already have crap pressed-up against the lower edge of my front radiator that's almost impossible to access. I'm just wondering if this is another opportunity for more debris to pile-up ? Thanks for any insight as I am seriously considering this mod. |
04-14-2022, 10:00 AM | #20 | ||
Rep 14,143
Tall Tom Cruise1013.50 tom @ eas8299.50 |
04-14-2022, 10:56 AM | #21 |
Rep 570
04-14-2022, 01:42 PM | #22 | |
8300
Rep 18,868
