Coolant leak from under the car HELP !!!
03-29-2022, 06:16 PM | #1 |
Rep 178
Hi saw this hard plastic hose that runs across the subframe underneath the car. Looks to be cracked and leaking. “Coolant return line.” Is what ECS tuning calls it. Wondering if it’s the right part not sure if that’s correct. Also if you guys have seen any how-to’s?
03-29-2022, 07:21 PM | #2 |
Art Collector
2427
Rep 3,450
That’s one of its names—yes. Coolant crossover pipe is another.
Most cooling system how-tos are: drain, disconnect, replace, refill. No different with this part. There are two bolts holding it to the steering rack that can be a pain to remove, but otherwise it’s just a matter of disconnecting each fitting, which as you probably know can be a real pain. I recently did this job and can’t remember there being anything particularly tricky or noteworthy. This hose connects the heater return line to the coolant expansion tank, thermostat, and in the case of auto transmission cars, it also attaches to transmission fluid heat exchanger. Edit: There’s a third 10mm bolt on the driver side, but I don’t think it attaches to the rack. Can’t remember where it threads into, but you’ll need to remove it too.
When I'm dead, just throw me in the trash.
03-29-2022, 07:59 PM | #3 | |
Rep 178
03-30-2022, 01:14 AM | #4 |
Art Collector
2427
Rep 3,450
Probably about the same. It’s likely (but not certain) the three 10mm bolts are easier to access on the RWD cars, but truthfully it’s not that bad on xDrive. You’ll want a ratcheting box-end wrench though, if I’m remembering right. You can get by with just a regular 10mm though.
