03-30-2022, 05:27 PM | #1 |
Rep 443
Excellent guide on iX charging
Featured on BIMMERPOST.com Couple of the things I learned: 1. BMW mobile charger and wall charger both limited to 40 amps. IX can go up to 48 amps. 2. Using mobile apps to find and pay for EV charging locations. I didn't realize how many DC charging locations were available until I downloaded and looked. Both the apps mentioned do require submitting your email/phone number before you can use them. 3. Difference in range gain while charging between the IX and I4. BMW listed "up to" rates apply to the I4. Range gain for the IX is ~20% slower. 4. Preloading payment apps for the charging networks in your area to avoid swiping CC problems. Electrify America and ChargePoint are the two big providers for me. |
04-04-2022, 06:31 AM | #2 |
Rep 36
What’s curious is the promo videos on bmw’s site specifically say the bmw wallbox can do up to 11kw. Take a look at the video labelled “charging the iX”: https://www.bmw.ca/en/all-models/bmw...21/bmw-ix.html
04-04-2022, 08:16 AM | #3 |
Rep 4,530
Drives: 2022 iX xDrive50, DGM
The BMW wallbox rating is likely the same as other commercial wallboxes - the issue is the type of circuit on which you would install it. In the US at least, electrical code requires that the circuit breaker should only deliver 80% of the maximum load of the breaker. And most home wiring supports a single circuit maximum of 50 amps - if you use a plug-in wallbox with a 14-50 plug on a 50 amp circuit breaker, the maximum it can deliver is 40 amps. Some wallboxes however support 48 amps, but only if hard-wired into your electrical panel (which can be done) - ChargePoint, Wallbox (the charger) and Juicebox units are all capable of delivering 48 amps (if hard wired), and likely so is the BMW wallbox although any information available is sketchy - hence the 48 amps claim probably.
You CAN install a 60 amp breaker and use a NEMA 14-60 plug with a 48 amp rated wallbox for a plug-in setup (which would be very unusual), but that requires rewiring circuits and significantly more expense, and really not much benefit. Most home charging will occur overnight anyway, and you are unlikely to run your EV down to zero daily so usual charging time with a 40 amp delivery will be 6-8 hours -cutting that down to 4-6 hours is not that much gain with normal charging use case, for a lot more trouble and expense, and certainly not Supercharger territory. An electrician would be a good idea for any of those scenarios, but if anyone was thinking DIY without the necessary pre-wiring, you could theoretically just install a 60 amp breaker and outlet, buy a NEMA 14-60 plug, set their charging unit to 48 amps, and Voilŕ! 48 amps to your car - violating code with the risk of overloading your circuits and burning your house down. So hard-wiring to your panel sounds like a better route if you really wanted or needed 48 amps - more expensive than a plug-in but a bargain in the long run, with some small disadvantages (charging unit not easily swappable for example). Last edited by Paladin1; 04-06-2022 at 08:16 AM.. |
04-04-2022, 08:39 AM | #4 | |
Rep 1,420
Paladin15608.50 |
04-04-2022, 09:12 AM | #5 | |
Rep 1,978
However, the German site does have it here. You can see the PDF with the specs here. My German is a little rusty, but there seems to be several variants of this Wallbox, but the highest amperage it can support is 40A. So unless they plan on making a different one soon, this is what it is. |
Paladin15608.50 |
04-04-2022, 09:43 AM | #6 |
Rep 4,530
Which brings up an excellent point highlighted by Tom in several of his videos - you don't actually need a wallbox to charge up at home. The provided cables and connectors in most cars will support charging through a 14-50 (or 6-50) outlet - another advantage of an outlet. The advantage of wallboxes (some) is that they provide WiFi connectivity, scheduling, flexible power delivery, cost tracking, etc, but much of that is actually provided by your car, including connectivity through an app like My BMW (and some units like ClipperCreek's basically just deliver power). One real advantage for a wallbox is that you have a fixed cable and plug that you just unwind and use, and you can leave the portable cable in your car (they also usually provide some power surge protection). If you use the travel cable as your permanent charger, it would be convenient to purchase another one to keep in the car so you didn't need to unplug it to have a Level 2 cable when you travel - but likely a cheaper solution than a wallbox.
04-04-2022, 10:10 AM | #7 | |
Rep 1,978
04-04-2022, 12:19 PM | #8 | ||
Rep 200
If you're planning on using the BMW charger that comes with the car, keep in mind that NEMA outlets wear out over time particularly when repeated insertion and removal of NEMA plug occur. It is recommended that plug-in EVSE remain plugged in. If you'll be leaving it plugged in all the time this won't be an issue. While I was using my BMW-provided charger on my X5 40e, however, I found that it worked fine when it was first plugged in and got dodgy if I didn't unplug it for a few days and would only work again after being unplugged for a day. Hopefully the new one with the IX will be better. |
Paladin15608.50 |
04-04-2022, 02:04 PM | #9 | |
Rep 1,081
If I understand the different levels for this wall box 48 amps is 11kw, and 40 amps 9.6kw. I thought I heard that’s about a 20% difference in charging performance he measured between the 2 (5.5 hours to 7 hours). So the additional cost may not be worth a 20% increase in charge time for some people. I have not seen the estimate yet but I would assume a 50 amp circuit to feed 40 amps is going to be less than a 60 amp circuit to feed 48 amps. How much I don’t know yet but I would pay a little more to have 20% better performance. |
04-04-2022, 03:26 PM | #10 | |
Rep 4,530
04-04-2022, 04:09 PM | #11 | |
Rep 169
Outstanding thread OP, and thanks for all of the outstanding and totally useful follow up posts. A reminder of how good these discussion boards can be when free from the vitriol and hate....
What would you guys recommend for a wallbox that is built to withstand outdoor use and which has the best feature set (even if somewhat redundant with the iX)?? |
LittleJoe1065.00 |
04-04-2022, 04:34 PM | #12 | ||
Rep 200
04-04-2022, 04:42 PM | #13 | |
Rep 4,530
https://www.nemaenclosures.com/blog/...2-differences/ Example: |
slampert162.00 |
04-05-2022, 07:59 PM | #14 |
I know a thing or 2 about a thing or 2...
3104
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
I needed my house upgraded from 100amps to 200amps. So, with my i4 coming, I thought it was a perfect opportunity to install a permanent wired charging unit. I went with the ChargePoint which is rating at 50amps. My electrician did the upgrade, installed a 50amp circuit, 240v outlet, and ran the wire to my garage. It will be interesting to see if I get the true 11kW @ 50amps.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
TechCTU786.50 |
04-05-2022, 08:15 PM | #15 |
Rep 169
I've now watched several of Moloughney's charger reviews, and while they're a bit formulaic, they're very helpful.
A couple of months ago, I had an outdoor 240V / 50Amp circuit with a Nema 15-40 tap installed. While watching the reviews, I noticed that every plug in 40Amp charger with a Nema 15-40 tap had only a 12" feed line. I assume this must be a code requirement. The short feed line complicates my charger installation. I hate to ask, but am I flirting with disaster if I install a 24" 50amp rated feed line?? |
04-05-2022, 08:31 PM | #16 | |
Rep 1,081
04-05-2022, 11:48 PM | #17 | |
Rep 4,530
slampert162.00 |
04-06-2022, 12:46 AM | #18 | |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
I have a 50A circuit and my ChargePoint runs at 40A
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
Haywood3104.00 Blastphemy49.50 |
04-06-2022, 03:01 AM | #19 |
Rep 364
I think the 11kw is for european version where we have a three-phase 230V system (up to 240V in fact) into houses.
Apparently you can even get a 22kw version but at least for me (and most in sweden) that would require an update from the regular 25A input to something like 50+ A whcih is crazy expensive... |
04-06-2022, 07:56 AM | #20 | |
Rep 6,766
Blastphemy49.50 |
04-06-2022, 08:12 AM | #21 |
Rep 4,530
04-06-2022, 09:52 AM | #22 |
Rep 10
id kill for one of these.
