Bimmerpost
4 Series
Marketplace Vendors Classifieds Wheels and Tires Goodyear Eagle F1 Asymmetric 3 2 225/40/R19 2 255/35/R19 RF Max Performance NEW!
      04-03-2022, 12:18 PM   #1
RLL RACER
Drives: BMWM8TurnerM6(2)M3's(1)Bavaria
BIMMERPOST / Classifieds
Asking Price:
USD 1.00
Or Best Offer
Item Interest
WELCOME!
HERE WE HAVE A SET OF 4 OFF SET
GOODYEAR F-1 ASYMMETRIC 3
RUN FLATS!
P.M. ME WITH ANY QUESTIONS!
*AS YOU MAY KNOW THERE IS A RUBBER AND TIRE SHORTAGE IN THE U.S.PRICES AT TIRE RETAILERS ARE SKY HIGH! GET THESE AT A GREAT PRICE BEFORE THEY ARE GONE!
**BEST PRICE IN THE U.S. IS RIGHT HERE!**
**EVEN MAKE A SOLID BEST OFFER**
THESE ARE..
SPRING/SUMMER/FALL.. HIGH PERFORMANCE TIRES.
RATED #1 BY THE WAY!
THESE ARE BRAND NEW!
MINT CONDITION!
THE OFF SET
SIZES ARE..
(2) FRONT 225/40/R19
(2) REAR 255/35/R19
*PLEASE CHECK YOUR CARS TIRE SIZES BEFORE ORDERING.
*THESE FIT MANY CAR BRANDS WHEELS!
THESE WERE ON A BRAND NEW 2021 BMW 3 SERIES.
THE CAR WAS DRIVEN OFF OF THE BMW CORPERATE FACTORY CUSTOMER DELIVERY SEMI. THEN THE CAR WAS DRIVEN INTO THE FACTORY TEAM RACE SHOP, ABOUT 50 FT AWAY FROM THE SEMI TRAILER, WHERE THESE TIRES WERE TAKEN OFF ON THE HOIST, AND LASTLY ALL SEASON TIRES WERE PUT ON THE FACTORY RIMS.
THE GOODYEARS WERE BAGGED AND SEALED.
THATS IT!
THESE ARE PERFECT AND HAVE BEEN STORAGE IN THE ORIG BMW TIRE BAGS IN A CLIMATE CONTROLLED BUILDING.
THESE ARE SOME AWESOME TIRES ON TRACK OR WINDING ROADS IN WET OR DRY.
GOODYEAR REALLY DID THE TRACK RESEARCH ON THESE HIGH PERFORMANCE RUN FLAT VERSIONS.
ALL PRO!
CHECK THE SPECS AND REVEIW BELOW!
THESE ARE SHIPPED TO YOUR DOOR WITH FREE SHIPPING AND TRACKING & INSURNACE.
WOW!
BEST PRICE OUT THERE, IS RIGHT HERE!! BEATING OUT TIRE RACK AND DISCOUNT TIRE AND ALL THE REST!
YOU CAN EVEN BEST OFFER ME!!!
THESE WILL BE SHIPPED IF NEEDED, IN THE ORIG TIRE BAGS AND IN TIRE BOXES FOR ADDIONAL PROTECTION.
I HAVE THESE SAME TIRES ON 2 OF MY OTHER CARS THAT ARE IN A WARM CLIMATE. I HAVE TRACKED AT HIGH SPEEDS AS WELL, AND THEY ARE IN THE TOP 2 TIRES FOR THIS CATAGORY!!
WITH GOODYEARS NEW TIRE DEVELOPMENT TEAM. THEY MAKE THE BEST PERFORMANCE RUN FLATS OUT THERE,
YOU WOULD NEVER KNOW THE DIFFERANCE!
*ACCEPT IF YOU HAD A PUNTURE. THE REST WOULD BE STRANDED, YOU WOULD KEEP DOWN THE ROAD
YOU WILL FIND THESE TO BE SOME OF THE BEST TIRES FOR YOUR HIGH PERFORMANCE DRIVING NEEDS.
THANK YOU IN ADVANCE FOR YOUR ORDER!
DRIVE ON! RACE ON!
With over 120 years of experience creating tires for every imaginable application, Goodyear knows what it takes to excel when the rubber meets the road. The Goodyear Eagle F1 Asymmetric 3 is a prime example of their relentless pursuit of excellence.
The Eagle F1 Asymmetric 3 from Goodyear is an ultra-high performance summer tire that is engineered to provide highly responsive handling and exhilarating performance.
The Eagle F1 Asymmetric 3 features a solid center rib and an asymmetric tread pattern for responsive handling and powerful grip in wet and dry conditions. Some sizes also feature Goodyear’s Sound Comfort technology, which delivers a quiet, comfortable ride not normally associated with ultra-high performance tires.
Goodyear Eagle F1 Asymmetric 3 Features
Drive with confidence knowing the asymmetric tread design and summer-only tread compound offers powerful grip in turns and enhanced wet traction
Remain one with the road thanks to the quick response and on-center feel supplied by the solid center rib
Get the very most out of your high-performance vehicle with a tire specifically designed and tuned for ultra high-performance suspension systems.
Goodyear Eagle F1 Asymmetric 3 Treadwear and Warranty
The Goodyear Eagle F1 Asymmetric 3 is backed by a six-year limited warranty against manufacturer defects.
The Eagle F1 Asymmetric 3 is Goodyear's Max Performance Summer tire developed for the drivers of sports cars, sports coupes, muscle cars and performance sedans. Featuring an advanced construction designed to work in conjunction with high-performance suspension systems, the Eagle F1 Asymmetric 3 offers precise steering and feel in warm dry and wet conditions. Goodyear's warranty states that "ultra high-performance summer tires are not recommended for winter use, and tread or shoulder cracking on those tires resulting from winter use will not be covered under our warranty," so like all summer tires, the Eagle F1 Asymmetric 3 is not intended to be stored, serviced or driven in near-freezing temperatures, through snow or on ice.
The Eagle F1 Asymmetric 3 features a summer-only tread compound designed to provide superior traction through enhanced road adhesion. This compound is molded into an asymmetric tread design featuring a solid center rib for responsive steering and solid on-center feel. The tire's outer shoulder is focused on achieving maximum dry traction through turns and the inner section and four wide-circumferential grooves improve wet-weather grip and hydroplaning resistance.
The internal structure of the Eagle F1 Asymmetric 3 includes a body of polyester cord supporting twin steel belts reinforced with spirally wrapped polyamide to enhance tread stability and high-speed capability.
Limited sizes of the Eagle F1 Asymmetric 3 are available with Goodyear's Sound Comfort technology, which involves the manufacturer adhering a layer of sound-absorbing foam to the inner liner of the tire to reduce cabin noise in the vehicle. These sizes are identified on the Specs page and in the search results.
Max Performance Summer run-flat tires provide temporary self-supporting run-flat mobility for a distance of 50 miles at up to 50 mph, even after a puncture has allowed complete air pressure loss. They are designed for serious driving enthusiasts who want a combination of a performance appearance, competent handling and Z-speed rated (or higher) durability with enhanced dry and wet traction. Often used as Original Equipment (O.E.) on powerful sports cars, performance coupes and high performance sedans, Max Performance Summer run-flat tires are not intended to be driven in near-freezing temperatures, through snow or on ice.
Goodyear's warranty states: "Ultra high-performance summer tires are not recommended for winter use, and tread or shoulder cracking on those tires resulting from winter use will not be covered under our warranty."
O.E. Max Performance Summer run-flat tires are typically purchased as direct replacements for worn-out pairs/sets of the vehicle's original tires. They can also be used for other vehicle applications in complete sets of four or axle pairs if available in an appropriate size, load range and speed rating to match the existing O.E. run-flat tires' performance category and specifications.
NOTE: Run-flat tires are only recommended for vehicles that are originally equipped with self-supporting run-flat tires and equipped with a tire pressure monitoring system.
SIZE UTQG MAX.
LOAD MAX. INFLATION PRESSURE TREAD DEPTH TIRE WEIGHT RIM WIDTH RANGE MEAS. RIM WIDTH SECT. WIDTH TREAD WIDTH OVERALL DIAM. REVS. PER MILE COUNTRY OF
ORIGIN*
225/35R19
88Y XL
300 AA A 1,235 lbs 50 psi 10/32" 20 lbs 7.5-9" 8" 9.1" 7.9" 25.2" 828 DE
255/30R19
91Y XL
300 AA A 1,356 lbs 50 psi 10/32" 22 lbs 8.5-9.5" 9" 10.2" 9.1" 25.1" 833 DE
g20
