Misfires and bunch of codes
04-04-2022, 03:10 PM | #1 |
Rep 78
After researching the site, I was unable to find similar situation. Over the weekend, I changed the value cover gasket and plugs. I went to test out and it was fine for about 5 min. And then I pushed a little hard and got misfires. I checked everything and pull back old plugs, still same issue.
revs fine in neutral, but in gear after 2k rpm it’s boggs and wants to shut down. Have a ton of codes. Trying to see what I should check first. It’s an 07 335i with 80k miles. HPFP replaced back about 10 years ago and fuel regulator last year. Everything is stock except battery. Codes 29CC - combustion misfires, several cylinders 29DC - cylinder injection cutout 2AAF - fuel pump plausibility 29CF - combustion misfire, cylinder 3 29CE - combustion misfire, cylinder 2 29CD - combustion misfire, cylinder 1 29D9 - misfire at low tank fill level 2C7B - oxygen sensor behind catalytic converter, signal D6DO - ring-break diagnosis has been carried out E18F - MOST ring set point/ actual configuration does not match 9CBF - communication with step motor controller on the left disrupted
335i Coupe - Monaco Blue/ Saddle/ Walnut
Ordered: 2.5.07 - Prod Date: 3.14.07 - Production Completed: 3.20.07 - Shipped on Integrity: 3.27.07 - Docked: 4.10.07 - Deliveried: 4.16.07 Last edited by mvbmw; 04-04-2022 at 04:18 PM.. |
04-05-2022, 09:11 AM | #2 |
Rep 216
I typically find that these cars are very ground sensitive. Being you changed spark plugs I would start by making sure all connecting plugs to coils are secured and well seated. With fcp euro life time warranty, I always change coils when I change sparks plugs.
mvbmw3.00 |
