04-05-2022, 09:17 PM | #1 |
Rep 17
Front end clicking noise video
Hi Guys,
You may have seen my newbie post in the other thread. Side note here from me as I try to figure out what this noise is. Anyone here had the same noise and fixed? https://www.dropbox.com/s/fxuy9fgbxv...Noise.MOV?dl=0 Thanks in advance |
04-05-2022, 09:48 PM | #2 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3566
Rep 4,249
You need friction discs installed between the brake rotor and wheel bearing hub. There is an SIB for this concern. It only affects lightweight brake rotors.
04-05-2022, 10:18 PM | #3 |
Rep 341
I have the same issue and my dealership installed friction discs and I am still having the same issue.
Edit: I lied I have a clicking noise that happens when I turn the steering wheel right or left. Even when driving in low speed or standing still and turning the steering wheel. |
04-05-2022, 11:17 PM | #4 | |
Rep 17
OR any one have photos of these discs? I thought all Msports came with these discs so surprised its not more common complaint on here? |
04-05-2022, 11:18 PM | #5 | |
Rep 17
04-05-2022, 11:39 PM | #6 |
3566
Rep 4,249
They're literally just a thin metal ring. Maybe 0.3mm or smaller in thickness. Cars do not come with them from factory. This friction ring is meant to fix a ticking noise heard from axle when turning at slow speeds and not braking
04-05-2022, 11:40 PM | #7 |
3566
Rep 4,249
The lightweight rotors have a rounded hat versus a squared hat. You can kind of see the little circle pins in the rotor hat
04-06-2022, 05:32 AM | #8 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
Hope this fixes it for you mate!!
