04-07-2022, 09:54 PM | #1 |
Rep 3,075
Drives: 2023 iX M60 Oxide
M60 boost mode
We will probably need to wait for thorough reviews to describe how this works, but given the info we have as peak HP and torque, I worked out this table.
What got me thinking about this is just how much torque the M60 has in non-boost mode (I'm using this term for lack of an official one). While the HP is not far off from the xDrive50, it maintains a 185ft-lb torque advantage. This seems to point to the max power coming on much earlier. Last edited by sor; 04-07-2022 at 10:02 PM.. |
04-10-2022, 11:27 PM | #2 |
Rep 3,075
Re-reading this press release (and particularly the table at the bottom), it actually reads as though the 610 HP is called "Sport Boost" and is available in Sport Mode. The 811 ft-lb of torque is available during Launch Control.
It's not clear that these two peaks are the same - it's possible they are offering 811 ft-lb for launch but the "Sport Boost" feature is available whenever you floor it in sport mode. Notably it does *not* mark the max output as Launch Control, only "Sport Boost". This would be very similar to the e-tron implementation where you get about 10 seconds of extra power when you initially floor it, which with a 3.x second 0-60 is more than enough to perform by maneuver you need to. "With Sport Mode engaged to unleash 610 bhp and Launch Control activated to release all 811 lb-ft of instantaneous torque, the BMW iX M60 will hit 60 mph from a standstill in only 3.6 seconds" "Max combined output / Sport Boost : 532hp/610hp" "Max combined torque, Launch mode: 811lb-ft" https://www.press.bmwgroup.com/usa/a...23-bmw-ix-m60-–-the-best-of-three-worlds:-i-x-and-m?language=en_US |
Paladin15610.00 |
04-11-2022, 09:40 AM | #3 |
Rep 4,530
Drives: 2022 iX xDrive50, DGM
Briefly considered the M60. You do get the above - but you're not going to track it. Or even significantly improve performance or usability over the 50 on city streets or the highway, unless you like sitting on a deserted stretch and continually launching it to feel that extra second of reduction from 0-60. It's not like the 50 won't put you in the passing zone before you need it. But you do get that extra second. Plus Parking Assistant Pro. Plus some "M" badges. Other than that, it appeared to me the 50 and the 60 are identical - identical interior, identical exterior. Down to the same Lumbar Delete on the passenger seat. What you lose compared to the 50 is:
- About $7k (in the US) for essentially the same options and configuration - About 15% of the range - which is sort of the major point for an EV to many And actually, the price difference (which is surprising considering the "M" premium for gasoline models) is not that significant to me - but the range most certainly is. It would be attractive to gain the extra features of PA Pro versus Plus (jumping off the line for a second of gain in an EV has zero meaning or utility for me) but cranking it down to an e-Tron level for range, mmmm, no. Just no. |
slampert162.00 |
04-11-2022, 09:55 AM | #4 | |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
I've stopped buying M/AMG models and now prefer to buy the highest non performance model, because those cars are better for day to day driving. For performance just buy a sports car for weekend use.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
04-11-2022, 09:57 AM | #5 | |
Rep 3,075
It's not about tracking the car, it's about the day to day feel of the car being fun to drive. I didn't track the i4 during the demo but both my passenger and I were grinning - and I don't even drive like an asshole exceeding the speed limit or weaving in and out of cars. I agree that the xDrive50 has a lot of power compared to my e-tron and is "plenty" for daily driving. It's a fantastic car and I understand the vast majority of forum members here are getting it, so my opinion might not be popular. Also I admit I'm being extremely picky here. I'm just hoping (probably baselessly) that I can get both the fun and the utility in the same package. I'm still skeptical the range will be much different compared to an xDrive50 when driven and equipped identically. There can be significant differences in range based on options, the M60 has everything by default and the xDrive50 doesn't. |
Paladin15610.00 |
04-11-2022, 10:51 AM | #6 |
Rep 4,530
May you not be disappointed! . Essentially overclocking (what appear to be) the same motors though will likely extract a greater penalty than the estimates indicate - depending on use. And if you're not going to use the boost frequently, it begs the question of why. So real world could very possibly be worse than advertised, with the additional penalty when charging of topping off a substantially larger battery pack than competitors with similar range. Physics is a bitch. Time will tell though, and we probably won't know actual numbers until at least the end of the summer, if then.
04-11-2022, 11:26 AM | #7 |
Rep 1,450
Doesn't the M60 come with wider tires? If so, that could be the reason for most of the range penalty. Tesla performance cars can often achieve the same range as non-performance models if you equip them with the same wheels and drive them within the non-performance power band (i.e., accelerate slowly).
I wonder if the iX M60 will be similar. |
04-11-2022, 11:34 AM | #8 | |
Rep 169
My iX50 is scheduled for production in mid May. Switching to the M60 would have added at least another 6 months onto the wait time.... |
Paladin15610.00 |
04-11-2022, 11:40 AM | #9 |
Rep 169
04-11-2022, 11:55 AM | #10 | |
Rep 1,450
Motor Trend said the M60's motors are three phase synchronous AC w/ double inverters to handle the added power. Not sure if these are different motors than in the xDrive 50 or just have some artificial electronic limits removed. |
slampert162.00 |
04-11-2022, 02:14 PM | #11 |
Rep 3,075
Anything that adds weight or uses energy. Think about the hardware and power involved in driving assistants, for example, that aren't present in a base model.
slampert162.00 |
04-12-2022, 06:30 PM | #12 |
Rep 1,450
I thought the iX M60 used a different motor than the rest. At least Motor Trend seems to think so:
https://www.motortrend.com/news/bmw-...ech-deep-dive/ |
04-12-2022, 06:35 PM | #13 | |
Rep 3,075
I'm just thinking there are something like a dozen or more options that the M60 comes with by default that the base xDrive50 doesn't, and those have to represent some level of power use and weight that could also skew the range results if the xDrive50 added them. That's really only relevant though if someone is thinking they'll option up an xDrive50 instead of getting an M60 for range reasons. |
04-12-2022, 06:44 PM | #14 | |
Rep 1,450
There's also this from BMW's iX M60 launch materials:
sor3113.50 |
04-12-2022, 07:01 PM | #15 | |
Rep 3,075
Yeah, they also say the suspension is "M-specific", but everyone seems to think it's a tune. If it is different suspension hardware that could contribute to range differences as well.
04-12-2022, 07:38 PM | #16 |
Rep 1,450
04-12-2022, 09:08 PM | #17 | |
Rep 169
While I don't (yet) have a shred of empirical evidence to back up my thinking, I've been assuming that the difference in range (factoring out tire size) between a base model and loaded iX50 would be negligible. If that's true, then doesn't it follow that the 15% loss of range between a loaded iX50 and the M60 must be primarily attributable to the powertrain and related hardware and SW enhancements, and not the option packages...?? I think it will be interesting to see how these questions resolve once we gather more battery consumption / range tracking data.... |
04-12-2022, 09:22 PM | #18 | ||
Rep 3,075
Things like 30 speakers and a 1kw boost to speaker amplifier, HUD hardware and powering it, whatever is required for rear wheel steering and air suspension, surround cameras, seat ventilation, radiant heating hardware, headlight upgrade, driving assistant sensors and hardware, and whatever else. These could all be negligible to real world range, I don't know. My sense is that they're responsible for at least some of the difference between the M60 and base xDrive50 range estimates. I also don't think the M60 is officially rated yet. When it is we might at least see the wheel differences. |
