2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums AUSTRALIA SLI retrofit
      04-09-2022, 03:22 AM   #1
F10_Newbie
Drives: BMW F10LCI 528i
SLI retrofit
Hi
Anyone had any experience retrofitting SLI (Speed Limit Info) ?
I have a 2013 (Aug) F10LCI with 5AS
      04-09-2022, 08:39 AM   #2
Hoa
It is a very simple retrofit for you. Depending if your vehicle have the proper camera already or not. If it does, all you need to do is add 8TH to your vehicle. If it doesn't, you will need to swap camera and then code.
To check if you have the proper camera, open the plastic cover for your rear view mirror. It should look like the attached photo.
      07-08-2022, 07:59 PM   #3
Aussie_550i
Australia
12
Drives: 2011 550i, 2017 430i
Can Bimmercode add 8TH or does it have to be done via e-sys?
Also, would this camera then allow for lane change, etc? I'm also guessing that this would require other coding?
      07-09-2022, 10:10 AM   #4
Hoa
I am guessing you don't have the camera at all? If you don't, you will have to add a lot of parts. You will need ESYS to load FSC certificates.
You will need the following:
Windshield (to mount camera w/heating)
KAFAS2 module
Wire harness
Camera
Driver Assist button
Dashboard (if you want to mount the button properly)
FSC certificates
Vibrating motor and control unit
Clock spring (if you don't have the right one)
Rear view mirror, duct and cover
5post
