04-09-2022, 05:24 PM | #1 |
Rep 25
Drives: 2020 BMW X3M
X3M Stage 2+ Pure Turbos Full E85 on KW v3
Featured on BIMMERPOST.com it is a long list of modifications and i will include most of them Engine/Turbos/Fuel System #custom made downpipes #stage 2+ pure turbos #fuel it secondary LPFP #PFS BMW S58 Port Injection Kit 900CC #Ethanol Content Sensor #ReFlex 0-10 Bar Pressure Sensor #ReFlex Plug-n-Play Ethanol Sensor Harness #ReFlex PLUS: Advanced I/O Integration #Custom Blow Off Valve Suspension #KW V3 Coilovers Brakes #M4 Comp Calipers on X3M Rotors #X5M Brake Pads Styling #EVENTURI CARBON FIBRE INTAKE SYSTEM #RKP F97 Pre-LCI Carbon Front Lip #Autotecknic Replacement Dry Carbon Fiber Fender Trims #RW Carbon Carbon Fiber Side Skirt Extensions #BMW M Performance Carbon Front Grille Set Ecutek unlock and custom mapping Will Update with Dyno results and overall testing with full transformation in next videos! some installation process |
24
Vettethret661.50 Max Well4813.00 Chi-X4M36.50 bear1m87.00 thestimp990.00 SearsTurnSix62.50 BrockDM2051.50 JP.BSB9.00 BuiltMyWay104.00 E92TiAg335i218.00 LimiX4m40152.50 ashokgadeking95.50 whoismorggan555.00 RustyBitz1573.50 Kingpin4386.50 6speed_M25479.00 AndyinHou479.00 russell21147.00 Tru Vic339.50 AZM40i259.50 F85MTuNED1623.50 D-Pat Murph303.00 ILLMATIC2313.50 Chubbiejones894.50 |
04-09-2022, 06:16 PM | #2 |
Rep 1,716
Drives: 22 X3MC MBB - C-17 Globemaster
I want one....I'd go pure turbos if I drove more than 50miles a week..
Mikes1298535.50 |
04-09-2022, 06:32 PM | #3 |
Rep 4,401
Drives: 2022 F97 X3M Comp LCI
lmao nice
sick build. can't wait to see the results!
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
dwing712.00 |
04-09-2022, 06:52 PM | #5 |
Rep 25
04-09-2022, 07:20 PM | #6 |
Rep 38
**Subscribed**
Why M5 brakes pads? And X4M rotors? Are they different from X3M? Or did you install new / newish rotors to bed with the new pads? How do the coilovers ride compared to stock? |
04-09-2022, 07:33 PM | #7 |
Satin black X3M Competition
114
Rep 36
**Subscribed**
Very interested in a similar build hopefully soon after finding more new parts. Specially for fuel as I'm already running out of fuel now. Good luck
Bootmod3 OTS Stage1 E30
10.75@127.86 |
04-09-2022, 10:08 PM | #8 |
Rep 25
04-09-2022, 10:10 PM | #9 |
Rep 25
X5m brake pads, calipers from m4 comp, stock x3m rotors, m4 brake pads are smaller than x5m because rotor stock on x3m comes 395mm if i am not mistaken and 375mm on m4
Tru Vic339.50 |
04-10-2022, 02:35 AM | #10 |
Rep 4,057
Looks like a pretty sick build. And just to be clear the G80 calipers will fit on the factory rotors. But... you will need the brackets from the X5 M to make it work. So if you but the calipers from the M5 or M3, it would work. Trust me, I found out the hard way. If you want a plug & play OEM BMW brake upgrade, the X5 M calipers are the ones you need.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
04-10-2022, 07:49 AM | #11 |
Rep 372
Good luck with the build. Cant wait to see some results and 9s
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten 2008 BMW 135 - 10.9 @ 131 2016 BMW X6 |
04-10-2022, 10:17 AM | #12 |
formerly rdougherty85
513
Rep 468
It's ridiculous that a vehicle can reach those sort of numbers with such a relatively low cost to upgrade... but I'm a fan lol
Suppose I'd be worried about all of the plastic on the top of our engines, the transmission, drivetrain, etc. Not sure there's been much testing done at those sort of power levels, but someone's gotta do it! Best of luck, following... |
RustyBitz1573.50 |
04-10-2022, 12:11 PM | #14 | |
Rep 25
trying to find some ceramic rotors to have more trust to the brakes |
Kevin_The_Clean13432.00 |
04-10-2022, 12:13 PM | #15 | |
Rep 25
04-10-2022, 12:17 PM | #16 |
Rep 25
04-10-2022, 12:26 PM | #17 | |
114
Rep 36
Good luck with the build ,
10.75@127.86 |
04-14-2022, 02:31 AM | #20 |
Rep 4,057
iWrap_cars Nice build here. Simply wish you would've shown more photos of the bigger 6-piston calipers. And just so you know, the M3 & M4 calipers won't fit the F97 without the proper brackets. Only the X5 M calipers with fit these cars as a true plug & play.
04-14-2022, 11:21 PM | #21 |
Rep 133
What about driveshaft/axels? I heard some ppl's snapped on launch control on an e70 tune with stock turbos, around 700whp. Any plans for this?
04-15-2022, 11:32 AM | #22 |
Rep 372
I know of only one person who shredded a drive shaft. That can be mitigated by lowering peak power from launch. Not ideal but a solution till dss makes better stuff. Also the car that broke it made closer to 800WHP.
