04-13-2022, 08:36 AM | #1 |
Rep 597
Lowered M240i xDrive on MSS Springs
Hey guys!
We visited the guys down at Evolve Automotive a few weeks back to have some lowering springs installed. However these springs aren't your usual spring kit. For those not aware of MSS Automotive, they're fairly new to the market and have designed a new adjustable lower spring that offers a much more compliant ride than you'll find with the traditional lowering spring, in addition with the added benefit of height adjustability. We've made a video on them here:
Currently Driving: '23 G87 M2, '22 BMW M240i xDrive, '18 F87 M2, '98 E36 318is @AUTOID | WWW.AUTOID.CO | SALES@AUTOID.CO |
04-21-2022, 08:18 AM | #2 |
Rep 94
Where can I buy these?
***EDIT*** I found the link and purchased. 3-4wk wait. Will show when installed. Added 17mm spacers to the front and 12mm to the rear and now we just need to hug the rubber ***EDIT 2*** Just watched the video! (Purchased just based on the pictures haha) Jack@AUTOID my Ig is Jdm240i let me know if its possible to expedite that order. Gotta stunt on people for the spring meets here Last edited by JDM_240; 04-21-2022 at 06:48 PM.. |
04-23-2022, 11:51 PM | #4 | |
Rep 1,464
Drives: BMW X5M Comp
04-25-2022, 06:23 AM | #5 | |
Rep 597
It's all relative. Compared to coil-over they're good value. Compared to a standard lowering spring, could be considered expensive. But the ride quality is so much better than a normal lowering spring. Like, noticeably better.
DaveDee532.00 |
04-25-2022, 06:35 AM | #6 |
Rep 1,464
Thanks for the info Jack. I'd also have to comment on value, they are worth everything you pay for these, also probably worth a mention the springs are made by Eibach to the specifications for MSS Engineers and are excellent quality. Many here fit them to X3M and X4M without lowering just to give a more compliant ride
I'll be putting a set on mine |
04-25-2022, 06:46 AM | #7 | |
Rep 597
04-25-2022, 10:55 AM | #8 |
Rep 1,807
Not a fan of changing the spring rate on electronically-controlled adaptive suspensions. I'll be curious about a long term update.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
04-25-2022, 07:27 PM | #9 | |
Rep 1,464
Probably fair to say that other mods like tuning, supercharging and many others would have far greater consequences. Unfortunately all the cars we love these days seem to come from factory with wheels that dont have enough poke and suspension that has huge arch gaps. Theres an interesting link here from Evolve automotive on the effects of MSS suspension from a diagnostic point of view rather than a personal recommendation, might be worth a watch even though its on an RS3 its more about data than opinion |
Ravenseal2883.00 xcelir8bmw405.50 |
06-20-2022, 04:14 PM | #10 |
bmw tech
473
Rep 365
Whats the part number for this?
Lehigh Valley Motors
193 Front Street Hellertown, PA 18055 484.214.6464 Mainentance-Repair-Performance |
r33_RGSport13042.00 |
06-20-2022, 04:46 PM | #11 |
Rep 1,464
06-21-2022, 01:01 PM | #12 |
Rep 18,751
This is the correct part#
https://www.rgsportshop.com/index.ph...roduct_id=2263
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
06-26-2022, 06:04 AM | #13 |
Rep 17
So are these adjustable from stock height down to 30mm less? I'd like to be able to keep it at stock during the winter so I'm not getting buried and then slightly lower it when there's no snow. These retain the factory adaptive damping too, correct?
06-27-2022, 03:13 AM | #14 | |
Rep 1,464
They are adjustable after being setup but you will need an alignment every time you change the height as it will affect the steering geometry. Being springs only the factory adaptive dampers are not affected |
07-01-2022, 09:31 PM | #15 | |
Rep 202
For the G42 it is 02abmwg28 |
07-01-2022, 10:01 PM | #16 | ||
Rep 18,751
Have you consult with the MSS owner about it? Because I have.
07-02-2022, 06:59 PM | #17 |
Rep 356
07-04-2022, 04:08 AM | #19 | |
Rep 202
I also ordered, received and installed the kit... ... which was 02aBMWMG28 Last edited by BeemerBaron; 09-26-2022 at 09:53 AM.. |
07-04-2022, 11:04 AM | #20 |
Rep 18,751
Not going to argue. You are an end user, I am a reseller who work closely with MSS.
You'll be given answer that they wanted you to hear.
07-05-2022, 05:40 AM | #21 |
Rep 202
07-05-2022, 08:22 AM | #22 |
Rep 18,751
What do I know? Since you are an expert now.
