BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography How WIDE do you want it?
      12-06-2008, 09:28 PM   #1
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Drives: SGM E92 335i, AM E90 335i
I've been eyeballing several wide angle lenses for a while now and I'm slowly getting closer to purchasing one...
I've narrowed it down to:
-Canon 10-22mm
-Tokina 11-16mm
I can't choose... I've heard the Tokina is sharper but the Canon is wider.. and I would be mainly shooting landscape/ architecture so the extra width could really help.. What do you guys think? And also whats the gripe about buying used lenses? Do you guys recommend it at all? I'm assuming that if I find one in mint condition, it wouldn't be a problem. Thanks in advance.
      12-06-2008, 09:41 PM   #2
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
and also the tamron/ canon 17-50mm, do you think I would need the extra range though?
      12-06-2008, 10:41 PM   #3
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
i have a tokina 10-18mm
      12-06-2008, 11:27 PM   #4
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Hows that? Any samples?
      12-06-2008, 11:29 PM   #5
E90ice
E90ice's Avatar
223
Drives: 2008 335xi Coupe
No, sorry
      12-07-2008, 12:03 AM   #6
UdubBadger
2011 135i  [7.46]
2008 328xi  [8.76]
hold on i'll find some
      12-07-2008, 12:08 AM   #7
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Originally Posted by E90ice View Post
No, sorry
gtfo chirs!
      12-07-2008, 12:11 AM   #8
UdubBadger
2011 135i  [7.46]
2008 328xi  [8.76]
10mm
12mm
18mm
      12-07-2008, 12:30 AM   #9
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
10mm
12mm
18mm
oooo I like the first one thanks! I'll have too look into it.
      12-07-2008, 12:57 AM   #10
vachss
Drives: Z4 Coupe
I've had the 10-22 for a few years now. Good lens and I'd recommend it, but the corners are somewhat soft. I've heard that the 11-16 does better in this regard, and I'd get one if I wasn't planning to upgrade to full frame early next year. Here's a few random 10-22 scenic shots, the first couple at 14mm, the next couple at 10 and the last the obligatory Z4 shot at 14. I certainly don't find the 10-22 to be "too wide" on a crop frame body.
      12-07-2008, 01:05 AM   #11
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
So you recommend getting the 11-16 instead? nice pictures btw
      12-07-2008, 01:10 AM   #12
vachss
Drives: Z4 Coupe
If I were buying another ultrawide for crop format today, yes I'd probably choose the 11-16 over the 10-22, both for the potentially better sharpness (though I might want to cherry pick a good copy) and the times I've wanted f/2.8 in a wide lens. In fairness though, I haven't shot with an 11-16 and am just going by reviews I've seen.
      12-07-2008, 01:19 AM   #13
snipersix
snipersix's Avatar
Drives: Retired 2017 F87 M2
2017 BMW M2  [0.00]
I got a tamron 11-18mm with 77mm UV filter for sale
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue|
      12-07-2008, 01:45 AM   #14
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
Pm'd you
      12-07-2008, 02:19 AM   #15
TWiTCHY
TWiTCHY's Avatar
Drives: '13 AW E92 M3
10mm
12mm
18mm
My lens at 10mm does not look like that. Is it because I have a cropped frame or something?
      12-07-2008, 04:53 AM   #16
spectrumphoto
Just another peanut in the Turd!
spectrumphoto's Avatar
Drives: g16M850;f30M550;f80M3-ED;e90M3
Canon 14mm f2.8L USM Rectilinear lens is the only way to go...
      12-07-2008, 05:09 AM   #17
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
That is so out of my league and budget its not even funny.... one day..
      12-07-2008, 10:35 AM   #18
UdubBadger
2011 135i  [7.46]
2008 328xi  [8.76]
most likely
      12-07-2008, 11:33 AM   #19
vachss
Drives: Z4 Coupe
most likely
Assuming what you have is the 10-17 Tokina Fisheye zoom then I would think the reason the shots from his lens at 10mm don't look like yours is more likely the difference between Fisheye and rectilinear distortion.
      12-07-2008, 03:13 PM   #20
TWiTCHY
TWiTCHY's Avatar
People have been telling me that because the D60 doesn't have a full-frame, 10mm is most likely seen as 15mm instead because it has a 1.5x crop factor or something. Agh!
      12-07-2008, 03:41 PM   #21
vachss
Drives: Z4 Coupe
While that's true as far as it goes, the fact of the matter is that full frame ultrawide angles are almost always longer than 10mm (the Sigma 12-24 is the widest fullframe lens I know of). The zooms that range down to 10-11mm are typically designed to work only with crop frame cameras and replicate the effect of conventional full frame ultrawides that go down to 16-18mm.
So you're not missing something by using a crop frame camera with a 10mm lens. Rather, you are using a specialized crop-frame lens that is allowing you to do what an conventional ultrawide angle lens will do on a fullframe camera.
      12-07-2008, 09:29 PM   #22
asdflkijd
Aberry is a scammer
asdflkijd's Avatar
so.. still trying to decide between a canon 10-22mm or a tokina 11-16.
