04-20-2022, 04:17 PM | #1 |
Rep 33
Labor time for Intercooler & Charge Pipe
Hello all,
I just got a Mad intercooler and a ER charge pipe and wanted an estimate of install time for a shop. Want to make sure im not getting ripped off. Thank you |
04-20-2022, 05:26 PM | #2 | |
21695
Rep 8,690
Better yet a flat rate As long as they are experienced it will go smoothly You have to complete remove the intercooler anyway to do the ChargePipe so it's not that difficult
F87source7349.00 |
04-20-2022, 10:45 PM | #4 | |
Rep 7,510
I don't think 1 hour is enough for a quote because getting it on the lift, and removing all the million screws, transfer O-rings and properly lube it. I would say it is a bit over an hour but shops don't charge fractions of hours so you might have to pay for the full 2 hours. But if you can do flat rate that would be best.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
04-20-2022, 11:52 PM | #5 | ||
Rep 33
04-20-2022, 11:55 PM | #6 | |||
21695
Rep 8,690
04-20-2022, 11:56 PM | #7 |
Rep 7,510
1 Hour might not be realistic for a shop though, because they'll have to bring it in, put it on the lift which takes time, then document everything on their computer system as well as search for tools. Then if it is an unfamiliar platform they might look at the shop manuals on how to do the job properly (i.e. verify exactly what they have to remove and what torque specs).
So at most I would say 3 hours. If everything was set a side and ready to go then like an hour with a shop that is familiar with the task. 5.5 hours might be alot.
///M TOWN21695.00 |
04-20-2022, 11:57 PM | #8 | |
21695
Rep 8,690
04-21-2022, 10:05 AM | #9 |
Rep 332
Drives: 2018 BMW M2
I went through the exact install and headache of finding a shop. I got mine done for 500 front a smaller shop and they did a great job. I was also quoted 1400 from a very reputable shop in the Dallas area. The real disconnect here is the ETA for install, which they quote 3.5 hours. Total nonsense. What you need to do is find a shop that doesn't run off the ETA for install and find a shop that just gives you an all in price based on experience.
04-21-2022, 01:01 PM | #10 | |
21695
Rep 8,690
For anybody willing to do it themselves here's some brief instructions… You have to remove the under bumper plastic You have to remove the stress plate from underneath the engine starting w/ all the corresponding little screws and bolts From there it's removing the two clips from the charge pipes on either side hot and cold Than you remove two screws pretty small actually, and the whole intercooler drops out like a bread drawer Then you remove the clip from the throttlebody and any corresponding attachments and you drop that sucker from down below The rest is just re-installing the new ChargePipe putting the new Intercooler in place installing two screws and reattaching the hot and cold side When reassembling, BMW as a manufacturer, recommends that you replace the Bolts on the stress plate - They"re one time Torque to yield Bolts ‼️
Dabozo635.00 |
04-21-2022, 09:39 PM | #11 |
Rep 60
Shops quote by the book time. if BMW book time says it takes 5.5 hours that is what the shop is going to charge for. The shop can probably get it done in 2 hour. that's the business, if shop charged by how fast they get it done.. they would all be bankrupt.
chris7197381.50 |
04-21-2022, 11:27 PM | #12 |
21695
Rep 8,690
IMO anything over 3 hours is truly an absolute rip off
OP maybe get a quote from your dealership Bunch of opportunist out there
04-26-2022, 04:28 PM | #14 |
Rep 7,510
Race core or the standard stepped core?
04-26-2022, 06:10 PM | #15 |
Rep 647
///M TOWN21695.00 Sundinisagod113.50 |
04-26-2022, 06:16 PM | #16 | |
21695
Rep 8,690
Nice to hear That's the way it's suppose to be Give your shop a shoot out deservingly
04-27-2022, 03:34 PM | #17 | |
Rep 8
04-29-2022, 05:41 AM | #18 |
Rep 1,592
The process isn't terrible but it does vary depending on which intercooler and chargepipe you do. Getting the CP lined up was the most annoying part by far. However for a shop I'd likely expect them to quote around 3 hours to be safe and an honest one would charge you actual time when they do it faster. Beyond 3 hours is pretty nuts to me, try ACM, their hourly is high but they work fast.
05-01-2022, 08:48 AM | #19 |
Rep 289
05-01-2022, 09:26 PM | #20 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
installation labor charge was $715, including labor on front brace trimming for my Wagner Tuning competition evo III intercooler kit
05-12-2022, 01:42 AM | #21 |
Rep 195
Labor times
